+ Reply to Thread
Results 1 to 16 of 16
    Quebec, Canada
    Default NeoPixel (WS2812B) Demo
    In a previous thread (http://www.picbasic.co.uk/forum/showthread.php?t=18431) I've posted an example how to use those addressable RGB leds (WS2812B) aka NeoPixel. I've optimized the code and made a set of include files.
    The NeoPixels can be used with almost any PIC running at 20MHz. The only limit is the available RAM: you need 3 arrays, one for each colour (RGB). The size of each array is the number of leds to control. With a large number of pixels I suggest using a PIC18F. See PicBASIC manual for more information on arrays limits.
    A PIC running @20MHz is more than enough to make almost any animation. The values are pre-computed and then streamed in one shot. You have plenty of time to compute the next sequence unless you want to build a video screen!
    Two gamma correction files are supplied for better fades in or out. One is for PIC18F and one for the others.
    Ref.: https://learn.adafruit.com/led-trick.../the-quick-fix
    See NeoPixelDump.pbp for instructions.
    The demo code show you how to run them on PIC12F683. Now the only limit is your imagination! Be creative!
    Demo code:
    '*  Name    : NeoPixelDemo.pbp                                  *
    '*  Author  : Michel Jasmin                                     *
    '*  Notice  : NO Copyright (c) 2014 Michel Jasmin  ;)           *
    '*          : No Rights Reserved                                *
    '*  Date    : 2014-11-29                                        *
    '*  Notes   : Demo how to use WS2812B (neoPixels) on            *
    '*          : a PIC12F683 @20MHz                                *
    #IF __PROCESSOR__ = "12F683"
            __config _HS_OSC & _WDT_OFF & _MCLRE_ON & _CP_OFF
    #ELSE
        #MSG "Wrong Processor selected!"
    #ENDIF
    DEFINE OSC 20
    DEFINE NO_CLRWDT 1  ' Don't waste cycles clearing WDT
    '------------ Const -------------------------
    NEO_NUM     CON 18  'Number of pixels
    '------------ Variables -------------------------
    NeoGreen    VAR BYTE[NEO_NUM]
    NeoBlue     VAR BYTE[NEO_NUM]
    NeoRed      VAR BYTE[NEO_NUM]
    NeoPixel    VAR BYTE            'Looping variable
    NeoPixValue VAR BYTE            'Value to be bit-banged
    '------------ ALIAS -------------------------
    NeoPin      VAR GPIO.2
    '-----------  Initialization -------------------------------
    Clear   ' Clear RAM before entry
    ANSEL = 0
    CMCON0 = 7  'Comparator disabled
    CCP1CON = 0
    WPU = 0
    TRISIO.2 = 0 'NeoPin
    NeoPin = 0
    GOSUB NeoInit
    '-----------  Main program -------------------------
        GOSUB NeoPixelDump
        GOSUB NeoPixelRotate
        PAUSE 50
        GOTO Main
    NeoInit:
        'Init values for 18 leds string.
        FOR NeoPixel = 0 TO (NEO_NUM - 1)
            IF NeoPixel < 3 THEN
                NeoGreen[NeoPixel] = 0
                NeoBlue[NeoPixel] = 0
                NeoRed[NeoPixel] = 64
            ELSEIF NeoPixel < 6 THEN
                NeoBlue[NeoPixel] = 64
                NeoRed[NeoPixel] = 0
            ELSEIF NeoPixel < 9 THEN
            ELSEIF NeoPixel < 12 THEN
                NeoGreen[NeoPixel] = 64
            ELSEIF NeoPixel < 15 THEN
        NEXT
    NeoPixelRotate:
            NeoGreen[NeoPixel] = NeoGreen[NeoPixel + 1]
            NeoBlue[NeoPixel] = NeoBlue[NeoPixel + 1]
            NeoRed[NeoPixel] = NeoRed[NeoPixel + 1]
        NEXT
        NeoGreen[NEO_NUM - 1] = NeoGreen[0]
        NeoBlue[NEO_NUM - 1] = NeoBlue[0]
        NeoRed[NEO_NUM - 1] = NeoRed[0]
    INCLUDE "..\_Include\NeoPixelDump.pbp"
    NeoPixelDemo.zipNeoPixelDemo.zip
    Default Re: NeoPixel (WS2812B) Demo
    Joyeux Halloween! LOL
    Nice work.
    Where can I get the file NeoPixelDemo.ZIP as well as the INCLUDE file? I would like to try them.
    EN82fn
    Sep 2009
    Scroll down code and you will find link, or click here
    http://www.picbasic.co.uk/forum/atta...7&d=1417555928
    That is really nice piece of code, even if i cannot understand the include asm file.
    Have anyone used it with a 16 or 24 led WS2812 ring? (not the B version)
    I've tried with the pic currently have 18F26K22 at 64 Mhz. On a 16 ring or 24 ring, i cannot set up all the led's to be functioned.
    when i set
    NEO_NUM     CON 16  'Number of pixels in Cyrcle
    Only 8 out of 16 LED are functioned.
    In case i increase the number, to 29, only 14 LED's are working, then no matter what number i use.....30+, still 14 LED's are light.
    The last two LED's are not working. Have been test it with 24 ring as well, and the last 2 LED's are not working.
    If anyone have experienced the same, would be nice to share your comments.
    given that the include files expect a 20mhz clock what steps have you taken to compensate for running at more than 3 times the expected speed
    Ooops havent seen that. I might try a 20 Mhz crystal then. Should be easier.
    I used 4Mhz crystal to 4xPLL and it worked. I couldnt see in the datasheet of the PIC18F26K22 any 20Mhz configuration.
    The code is really good. thanks the Author: Michel Jasmin
    May i ask something?
    Could i use all this code as a secondary code?
    I'm thinking to use it only as an effect when the PIC is powered up, the RGB led ring to do its pattern.
    But the main program not to be affected by this code.
    DT has given to us the interrupt function of a flashing LED without disturbing the main program.
    But i really dont know how to import all this code or how to use this DT's interrupt method here.
    Could anyone guide me? Thanks a lot.
    using that code it takes about 1mS to send data to 24 ws2812's . so if your main program can tolerate 1mS gaps in processing every 50mS it would work ok
    if you used a more modern chip with a clc module then you could adapt my code
    found here :-
    http://www.picbasic.co.uk/forum/atta...5&d=1508279203
    that updates the leds as a background interrupt driven process with very very little overhead
    see this thread for that and other more efficient possibilities
    http://www.picbasic.co.uk/forum/showthread.php?t=23399
    what have you tried ?
    Many years ago, i did a simple RFID reader program.
    What it does is to read the RFID tag and if the ID number is stored in the PIC's ram, then it will make a port high.
    That is the whole program.
    I haven't tried anything yet to embed the above RGB code. What i would like to do with this code, is to work on the backround as an effect, when:
    The RFID tag is valid: to light the RGB ring in Green, then to continue working on the backround.
    The RFID tag is not valid: to light up the RGB ring in LED.
    I will try without interrupt and i will add the RFID code inside the main of the RGB code. Will let you know.
    this is the addition to the main:
    serin2 rfid,84,[WAIT($02),str BUF\10]
    Check_List:
      FOR tagNum = 1 to 3       ' scan through known tags
        FOR idx = 0 TO 9		' scan bytes in tag
        READ (((tagNum-1)*10) + idx), char	' get tag data from table
        IF (char <> buf(idx)) THEN Bad_Char		' compare tag to table
        NEXT
        GOsub Tag_Found			' all bytes match!
    Bad_Char:					' try next tag
      NEXT
    Bad_Tag:
      tagNum = 0
        FREQOUT porta.3, 1000 */ $100, 115 */ $100	' groan
    Sep 2008
    Maine, USA
    Michel,
    I just wanted to thank you for doing all the heavy lifting on this code. I have been coding using PicBasic for over 20 years, but never got into assembly and include files. I appreciate that I can "stand on the shoulders of giants" like you! I'm doing some very simple chasing and fading of NeoPixel circles from AdaFruit and got it going very quickly thanks to you. -- I did forget to remember that I needed to connect an external 20MHz XTAL OSC at the beginning since I usually use the internal OSC. But I saw the wrong timing on my logic analyser and figured it out after some head scratching.
    "Do or do not, there is no try" Yoda
    Quebec, Canada
    Quote Originally Posted by tekart View Post
    Michel,
    Thanks tekart! I've made another one to work @32MHz so I can use it with a PIC16F15325 with it's internal oscillator. With this chip I can control 80 pixels which is more than enough for most projects!
    NeoGreen    VAR BYTE[80]bank9
    NeoBlue     VAR BYTE[80]bank10
    NeoRed      VAR BYTE[80]bank11
    NeoPixelDump:
        ' 32MHz = 125ns inst cycle
            NeoPixValue = NeoGreen(NeoPixel)
            INCLUDE "..\_Include\NeoPixelBitBang32MHz.pbp"
            NeoPixValue = NeoRed(NeoPixel)
            NeoPixValue = NeoBlue(NeoPixel)
        NEXT
    Have fun!
    Sep 2008
    Maine, USA
    Michel,
    The project I'm working on just got more complex. I was originally using 3 PIC12f683s to run 3 different NeoPixel strings (well circles from Adafruit actually). But I need them all to synchronise. I was doing dumb sync signal passing from one to the other, but that is not working out due to all the different timings I need to do. SO my question is, is it practical to modify your code so I can drive 3 separate strings from 3 I/O pins on the 683? I'm struggling with how I would do that. Is it practical? It would allow me to control everything with nested loops in one controller and just switch which string I'm addressing.
    Quebec, Canada
    Michel,
    Yes I think. "NeoPin"is an alias on a pin so it should work if you declare it as a byte and then reassign it on runtime to a pin number...
  1. PIC to WS2812B / WS2811 IC
    By comwarrior in forum mel PIC BASIC Pro
    Last Post: - 19th January 2018, 19:37
  2. Simple Array Demo
    By Archangel in forum Code Examples
    Last Post: - 15th February 2010, 04:46
  3. PicBasic Pro Demo
    By nbrucew in forum mel PIC BASIC Pro
    Last Post: - 26th August 2009, 19:10
  4. Nested For Next Loop Demo
    Last Post: - 8th June 2009, 08:57
  5. Demo version...
    By simransingh in forum mel PIC BASIC
    Last Post: - 21st November 2007, 21:10
Members who have read this thread : 29
