ICD3 with PBP
Results 1 to 5 of 5
Thread: ICD3 with PBP
    New Jersey
    Default ICD3 with PBP
    I have an ICD3 that's been collecting dust. Every time I attempt to use it, I try for a little while, get sidetracked with something else and don't go back to it for some time. Then the cycle repeats.
    Now I need to use it. I searched the forum and see that there isn't much information on it. I know it can be used with ASM but how can I view the PBP code? I can't use the built-in ICD that's supplied with MCSPX because both I'm using both USARTS on my PIC.
    Can someone point me in the right direction?
    Default Re: ICD3 with PBP
    you need to do idc debugging within mplabx . I can only get it to work using some pic18 devices , it seems everything else needs a debug header of some sort . the headers are not cheap
    New Jersey
    I'm using an 18F87J50. What exactly do you mean when you say:
    Also, how do you see your PBP code in MPLABX?
    idc should read icd a typo
    start here
    http://www.picbasic.co.uk/forum/showthread.php?t=18520
    New Jersey
    Thanks, I think this is what I was looking for. Seems complicated.
  1. PBP File Extension: .BAS vs .PBP
    By nedtron in forum mel PIC BASIC Pro
    Last Post: - 13th February 2006, 06:48
