EEPROM query: easy for you, a mystery to me!
Results 1 to 5 of 5
    Mar 2014
    England
    Default EEPROM query: easy for you, a mystery to me!
    I do not understand how I can *apparently* write to 8-bit EEPROM addresses *above 1k* on an 18F46K22.
    Unbelievably to me, the following code works just fine, writing and reading back at address 7500.
    My ignorance is clearly deeper than I thought! Can anyone shed light on this mystery?
    Thank you!
    promtest:
    y var word
    z var word
    y = 7500
    write y, 100
    read y, z
    lcdout 254,1
    pause 200
    lcdout 254,128, #z
    Default Re: EEPROM query: easy for you, a mystery to me!
    also just try to read @ ...
    332
    1356
    2380
    3404
    4428
    5452
    just my two cents ...
    Check the manual for the difference between bytes and words.
    What Alain is trying to make you figure out is this:
    The EEPROM adress "bus" is 10 bits for adressing locations between 0 and 1023. Only the two least significant bits of the high byte are actually used, look:
    1356: 0000010101001100
    2380: 0000100101001100
    4428: 0010000101001100
    7500: 0001110101001100
    See the lower ten bits marked in green? Which adress are you really accessing? Yes, 332.
    Mar 2014
    England
    Thank you everyone for showing me this patience.
    I have spent days delving successfully in code memory and my confidence was building: suddenly I was confused, in mystery-land again and not happy to be there!
    /Experimenter
  1. Sound command query.
    By billys7 in forum General
    Last Post: - 9th June 2014, 10:27
  2. Query - 16F628A direct to USB
    By Ray_VT in forum USB
    Last Post: - 4th August 2009, 20:30
  3. ADCIN query
    By muddy0409 in forum mel PIC BASIC Pro
    Last Post: - 24th June 2009, 12:48
  4. Easy "Unloading" of EEPROM ?
    By Glenn in forum mel PIC BASIC Pro
    Last Post: - 6th January 2009, 03:20
  5. Led Timer Query
    By sphinxifm in forum mel PIC BASIC Pro
    Last Post: - 13th January 2008, 15:17
