Thermal Printer
Results 1 to 4 of 4
Thread: Thermal Printer
    sara736's Avatar
    sara736 Guest
    Default Thermal Printer
    Hi everyone, I read that PIC can be interface with thermal printer with RS232(interface)...but to make sure can anyone suggest where (link) I can get one? And do all printer(thermal printer with Rs232 interface) have the same ESC/POS command set?
    Mar 2006
    China
    Default Re: Thermal Printer
    Hi
    Of course a PIC can connect to a serial thermal printer. Most printers come with either USB , parallell or rs-232 and very few have more than one interface. When using a PIC the rs-232 is the obvious choice. You only need a MAX232 or a MAX3232 (if you have a 3.3v pic) and then it is enough to connect the TX and RX (if you want to poll the printer status) and Ground. Most printers can work in either text mode (using internal font set) or graphic mode (where you need to format every little pixel yourself an send this data to the printer. Text mode is easier and usually prints faster, plus using less codespace in the PIC.
    We are using Epson TM-88 III or IV versions or a TM-90. The TM-88 IV is fast as hell to print. Most Epson printers have an internal memory area where it is possible to upload picture logos using a PC (TMF logo software). This will allow you to get graphic mixed with text and still not need to handle the actual logo in the PIC. You just tell the printer to "print logo nn". The result is a mix of text and graphics, most POS machines uses this way since it is fast to print.
    Most printers have a removable communication board in the back so it is easy to change so if you have a printer with USB just get a serial board and plug it in.
    Ebay is a good place to start looking, just make sure you get a rs-232.
    Different brand and models of printers uses deferent command codes. Even Epson TM-88 and TM-90 does use exactly the same command set but most parts are similar. You can find Epson command set on internet and if you really really look you can find their programmer's reference guide which is gold.
    Why not use a standard printer by use of the Serial to Parallel-Printer Converter IC?
    Else a mini serial dot matrix printer.
    Or browse CUSTOM AMERICA Inc.
    Also How to print to HP laserjet 1100 series using PIC without PC?
    Or try some code:
     - 20th January 2004 23:06
    bitmaniac
    Junior Member
      Serial 2 Paraller PRinter Converter
    HI! I don't know if this is what you want but give it a try
    THANKS HARRISON PHAM ,for the codding!
    'Serial to Parallel Printer Converter for Generic Printers
    'By: Harrison Pham March 30, 2003
    'PIC: 16F84 at 4mhz
    ' PIC Printer (DB25 Connector)
    ' Pin A1 Pin 16 (Init)
    ' Pin A0 Pin 1 (strobe)
    ' Pin B0 Pin 2
    ' Pin B1 Pin 3
    ' Pin B2 Pin 4
    ' Pin B3 Pin 5
    ' Pin B4 Pin 6
    ' Pin B5 Pin 7
    ' Pin B6 Pin 8
    ' Pin B7 Pin 9
    ' Pin 17 to gnd (Printer Select)
    ' *Pin 14 to gnd (if needed for autofeed feature)*
    ' Pin 18 to gnd (gnd)
    init con A1
    strobe con A0
    char var byte
    trisb = $00 'set portb to all outputs
    high init 'clear init line
    high strobe 'clear the strobe line
    portb = %11111111 'put all data lines high
    pause 1000 'pause for a second
    low init 'init the printer
    pause 500 'pause 500mill seconds to let printer init
    high init 'clear the line
    serin A2,N9600,[char] 'get characters with serial
    if char = 13 then 'if detected a cr then insert cr and lf
    PortB = 10 'lf
    low strobe 'tell printer to read in byte
    pauseus 200 'wait 200usec for printer to read in byte
    PortB = 13 'cr
    low strobe
    pauseus 200
    high strobe
    portb = char 'set portb to the char byte
    low strobe
    pauseus 200
    high strobe
    Norm
    Mar 2006
    China
    I like thermal printers because they dont need any inc or ribbons to work. Just throw in the paper roll and start printing. Bad thing is that the text will fade after some time ..
    Also the printout is cheap and good looking.
  1. Interfacing to thermal printer
    By tacbanon in forum FAQ - Frequently Asked Questions
    Last Post: - 24th April 2013, 00:27
  2. Replies: 20
    Last Post: - 25th May 2012, 15:37
  3. Thermal printer
    By jonas2 in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 16:35
  4. PIC to Printer
    By mychangl in forum mel PIC BASIC Pro
    Last Post: - 17th June 2008, 00:22
  5. Using a TC74A0 with PBP(Thermal sensor via I2C)
    By navaismo in forum mel PIC BASIC Pro
    Last Post: - 1st November 2006, 18:25
