Turn off analog comparators so your pins can be used for digital I/O.
CMCON = 7
PULSOUT toggles the pin twice, so the initial state of the pin determines
the logic of the pulse.
LOW 0 ' We want a high-going pulse or low-high-low with pulsout.
	@ DEVICE MCLR_OFF,INTRC_OSC,WDT_OFF,PROTECT_OFF
Define	OSCCAL_1K 1  ' Load factory value into OSCCAL
CMCON = 7                  ' Turn analog comparators off
X VAR BYTE
LOW 0        ' Setup GPIO,0 to output a high-going pulse with pulsout
    FOR X = 1 to 50
    pulsout 0, 100
    pause 15
    NEXT X
    FOR X = 1 to 50
    pulsout 0, 200
    pause 15
    NEXT X
    goto Main
 You may want to tweak the pulsout periods, but that should get you started.
Make sure you use a separate power supply for your servo. Using the same PS as the PIC will cause problems.
