Where To Get Started With ADC (Pic 18f2550 / 4550)
+ Reply to Thread
Results 1 to 7 of 7
    Cool Where To Get Started With ADC (Pic 18f2550 / 4550)
    • Hello everyone, i was wondering if any of you would be as kind as to give me some pointers on where to start with ADC with one of these particular chips (18f-2550/4550)
      basically i need to understand how ADC works since im trying to build a USB Throttle cuadrant for a flight sim, i know the USB aspect of things (ive made a 32 button "Joystick" with no axis that works fine) but i have no idea on how to do the following using PBP3:
      ---conifgure Fuses for ADC operation (configuration bits)
      ---recieve analog input from Pot and turn it into a digital value (this would be an axis)
      ---have a second analog input for a second axis
      • (i already know how to make the descriptor and comm. with the pc via HID class)
        any guide or well commented code would help me greatly, i appreciate any input and thanks for the time.
        Scumari's examples here : http://www.picbasic.co.uk/forum/showthread.php?t=11950
        are helpful but i dont understand how the ADC conversion works in that program,
        if someone by any chance can explain or "comment" this code i would really appreciate it.
        JSAGS
    Default Re: Where To Get Started With ADC (Pic 18f2550 / 4550)
    JSAGS you will get a better response by posting the code you are having issues with along with a schematic of your setup . posting the same question over and over again under different headings will not solicit more responses. adc is a big subject ,you need to show us what you know and what you have tried so a suitable targeted response can be given .
    a good start is to read the pbp manual
    Oct 2009
    Utah, USA
    From one of the GREATEST programmers to grace this forum... (may he rest in peace)
    http://www.darreltaylor.com/DT_Analog/
    dwight
    Dwight
    Oct 2011
    These are the registers used with the A/D converter
    PIC 18F2550
    Select the A/D inputs with the ADCON1 register. So to select AN0 and AN1 as analogue inputs with voltage references of PIC supply and PIC 0v set ADCON1 = %00001101
    AN0 and AN1 must be made inputs with the TRIS register.
    Next set the ADCON2 register. For a 10 bit result (0 - 1023) set ADCON2.7 to 1 (right justified). The A/D result will be in registers ADRESH and ADRESL. For an 8 bit result (0 to 255) clear ADCON2.7 to 0 (left justified). The A/D result will be in register ADRESH. The A/D converter needs a fixed time to settle and do the conversion. Set the rest of the bits according to the table in the datasheet for clock speed used.
    The pic has only one A/D converter so it must be connected to the relevent A/D pin by the ADCON0 register and the converter turned on. So to select AN0 and turn the converter on, ADCON0 = %00000001. To select AN1, ADCON0 = %00000101. If you make AN3 analogue then AN0, AN1, AN2 will also be analogue input, see the datasheet.
    To start the conversion set ADCON0.1 to 1.
    Wait for the conversion to finish with for example
    WHILE ADCON0.1 = 1 : WEND
    The result will be in ADRESH/ADRESL for 16 bit results or ADRESH for 8 bit results depending on the setting of the format in ADCON2.
    Hope this will get you started
    Phil
    Thread moved to FAQ, good info.
    Thanks for all the good info guy ill hope this gives me the kickstart i need (after midterms XD )
    thanks a lot for the input again, i managed to build my joystick, but eventually ran into some trouble again, please see these thread if you guys care to help me out a bit more i would really appreaciate the help..
    http://www.picbasic.co.uk/forum/show...244#post129244
  1. 4550 osc
    By MyBuddy in forum mel PIC BASIC Pro
    Last Post: - 23rd October 2009, 16:32
  2. Need help PIC 18F2550 with DS 1302
    By christina86 in forum mel PIC BASIC
    Last Post: - 28th December 2007, 01:05
  3. getting started with a PIC 18F4550
    By bigbear in forum General
    Last Post: - 16th October 2006, 02:31
  4. need help just started with pic basic pro
    By houa in forum mel PIC BASIC Pro
    Last Post: - 1st September 2005, 08:32
