How to read CONFIG1
Results 1 to 9 of 9
    Default How to read CONFIG1
    chip = PIC16F1933
    if i put the register name
    CONFIG1
    in a statement PBP3 is not happy and will not compile
    i am trying to debug something and i want to examine a few bits, just want to print a byte or word to my serial LCD to ponder what may be going on
    is there a way to read CONFIG1 ? in PBP3
    (in the MEL programmer software mePROG the config looks as expected)
    will post more in another thread about the issue i am chasing
    Default Re: How to read CONFIG1
    You either set the configs in the inc file or in your code. If you are relying on something else then you can have trouble.
    Sep 2009
    yes i know, i just want to read CONFIG1, is that not possible ?
    Maybe you should read that link again.
    If that's not what you want, you'll have to give more details.
    Hi
    i assume you mean the 4093 link above ? (the posts crossed at the same moment)
    now i have read it, says it is only for 18F, i have 16F
    what i was wanting was simply to inspect these 2 bits in CONFIG1 as i was having trouble with the mode functioning properly:
    in CONFIG1 WDTE <4:3>
    since one can access most any register in PBP by its name i was surprised that CONFIG1 was not available, perhaps there is some good reason
    i imagine i could discover where it is in memory and looks that way (i assume it is a fixed location ?)
    The CONFIGxx names are used within PBP and are listed in the include files.
    The individual registers are used by Microchip and are described in the datasheet.
    I suggest reading the register directly (check datasheet to see if readable). This will be much more efficient and easier to implement.
    Unless the PIC has CFGS you cannot read the fuses (otherwise known as config registers). This appears to be a PIC18 only thing. Unless you have a suspect PIC or programmer they are what you last wrote to them.
    BTW always a good idea to check for an errata if your PIC wont do as it's told.
    Quote Originally Posted by towlerg View Post
    thanks for that confirmation about not being able to read those registers in a 16F, too bad about that
    i did read the errata and did not spot a related issue, peda is helping me on another thread here that is related to what started this
  1. 16F886 (illegal opcode CONFIG1)
    By MOUNTAIN747 in forum General
    Last Post: - 29th May 2015, 19:35
  2. Acessing Config1 Register in PIC16F88
    By mychangl in forum mel PIC BASIC Pro
    Last Post: - 15th February 2014, 16:09
  3. 16F1825 CONFIG1 AND CONFIG 2 questions
    Last Post: - 19th May 2013, 03:01
  4. Replies: 6
    Last Post: - 14th October 2005, 19:41
  5. Trying to read PortC
    By BobK in forum mel PIC BASIC Pro
    Last Post: - 9th November 2004, 10:16
