Pic18f2550 HID Keyboard
Results 1 to 21 of 21
    Jun 2007
    Default Pic18f2550 HID Keyboard
    Dears ,
    many Thanks For The Useful Info I Found Here To Achieve My Project , But Only I have One Concern i Cant Deal With It .
    i Can Connect The Pic To My Pc And Recognized , But When I Try To Send The below Character Or Any Other Character Its Repeated Forever I Don't Know Why .
    Bufferout[0] = 0
    Bufferout[1] = 0
    Bufferout[2] = $33
    Bufferout[3] = 0
    Bufferout[4] = 0
    Bufferout[5] = 0
    Bufferout[6] = 0
    Bufferout[7] = 0
    Output : ";;;;;;;;;;;;;;;;;;;;;;;;; . . . Forever"
    while :
    1st byte = modifier keys (i.e. ctrl, alt, shift)
    2nd byte = reserved
    3-8 = keys pressed ( 0x04 = a, 0x05 = b, ...)
    Default Re: Pic18f2550 HID Keyboard
    I don't see how someone can help with seeing all your code.
    Dec 2010
    You need to set the value, then send it, then clear it after it is sent once. Everytime you receive a poll, you will respond with whatever you have in the array. If your character is still there, you send it again.
    Jun 2007
    Dear Demon ,
    You Are Right , But Am In Work Now And i Cant Provide thE Full Code From Here , Anyway I Will Provide It ASAP ,And Thanks Again I Remember Last Time You Helped Me .
    Dear Charlie ,
    Can You Explain In Details Please , I Will Be Thanks If Code Is Provided , Many Thanks For Your Reply .
    Jun 2007
    Here Is My Code & USB Description attached .
    all i need is when i make portb pin 7 high then pic send char ";" .
    DEFINE OSC 48
    @ __CONFIG _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
    @ __CONFIG _CONFIG1H, _FOSC_HSPLL_HS_1H
    @ __CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_512_2H
    @ __CONFIG _CONFIG3H, _PBADEN_OFF_3H & _MCLRE_OFF_3H
    @ __CONFIG _CONFIG4L, _LVP_OFF_4L &_XINST_OFF_4L
    USBBufferSizeMax con 32 ' maximum buffer size
    USBBufferSizeTX con 32 ' input
    USBBufferSizeRX con 32 ' output
    ' the USB buffer...
    USBBuffer Var Byte[USBBufferSizeMax]
    USBBufferCount Var Byte
    ' * main program loop - remember, you must keep the USB *
    ' * connection alive with a call to USBService every couple *
    ' * of milliseconds or so... *
    usbinit ' initialise USB...
    ProgramStart:
    if portb.7 = 1 then
    USBBuffer[0] = 0
    USBBuffer[1] = 0
    USBBuffer[2] = $33 ; 33 = ";"
    USBBuffer[3] = 0
    USBBuffer[4] = 0
    USBBuffer[5] = 0
    USBBuffer[6] = 0
    USBBuffer[7] = 0
    gosub DoUSBIn
    gosub DoUSBOut
    goto ProgramStart
    ' * receive data from the USB bus *
    DoUSBIn:
    USBBufferCount = USBBufferSizeRX ' RX buffer size
    USBService ' keep connection alive
    USBIn 1, USBBuffer, USBBufferCount, DoUSBIn ' read data, if available
    ' * wait for USB interface to attach *
    DoUSBOut:
    USBBufferCount = USBBufferSizeTX ' TX buffer size
    USBOut 1, USBBuffer, USBBufferCount, DoUSBOut ' if bus available, transmit data
    if portb.7 = 1 then
    USBBuffer[0] = 0
    USBBuffer[1] = 0
    USBBuffer[3] = 0
    USBBuffer[4] = 0
    USBBuffer[5] = 0
    USBBuffer[6] = 0
    USBBuffer[7] = 0
    ....clear buffer...
    By the way, your buffer is 32 bytes long but you only use the first 8 bytes.
    Jun 2007
    I Told Them , Demon Is My Hero , I Will Try Today And Feedback , Many Thanks .
    Just noticed something else, only send when you have to:
    if portb.7 = 1 then
    USBBuffer[0] = 0
    USBBuffer[1] = 0
    USBBuffer[3] = 0
    USBBuffer[4] = 0
    USBBuffer[5] = 0
    USBBuffer[6] = 0
    USBBuffer[7] = 0
    gosub DoUSBOut
    ....clear buffer...
    Hi there,
    Is that your entire code?
    Shouldn't be also something like: " include KBDDESC.ASM " in the main code ?
    Rui
    Jan 2012
    Grid EN19MV
    Wouldn't it shorten things to do this:
    if portb.7 = 1 then
        FOR i = 0 to 7
             IF i = 2 then
                 USBBuffer[i] = $33 ; 33=";"
                 USBBuffer[i] = 0
        NEXT i
        gosub DoUSBOut
    ....clear buffer...
    -Stephen Hawking
    Jun 2007
    Many Thanks , Its Working Now , And The Code Is Down , But Any One Knows How Can I Include Multimedia Keys (Play,Stopn, Mute . . .etc) , i know i must add it to usb descreptor but i never knows how , i read alot without luck .
    DEFINE OSC 48
    INCLUDE "DT_INTS-18.bas"
    INT_LIST macro
    INT_Handler USB_INT, _DoUSBService, ASM, yes
    INT_CREATE
    endasm
    USBBufferSizeTX con 8
    USBBufferSizeRX con 8
    USBBufferIn var byte[8]
    USBBufferOut Var Byte[8]
    DataToSend var byte[8]
    asm
    SendUSB macro array
    variable i=0
    while i<8
    MOVE?BB (array+i),(_USBBufferOut+i)
    i+=1
    endw
    L?CALL _DoUSBOut
    endasm
    SwHwInit:
    GOSUB DoUSBinit:
    Start:
    clear
    if portb.7 = 1 then
    DATATOSEND[1] = 0
    DATATOSEND[2] = 0
    DATATOSEND[3] = $51 ; if i change it to be "80" >> volume up, it didnt work .
    DATATOSEND[4] = 0
    DATATOSEND[5] = 0
    DATATOSEND[6] = 0
    DATATOSEND[7] = 0
    gosub DoUSBOut
    clear
    DATATOSEND[1] = 0
    DATATOSEND[2] = 0
    DATATOSEND[3] = 0
    DATATOSEND[4] = 0
    DATATOSEND[5] = 0
    DATATOSEND[6] = 0
    DATATOSEND[7] = 0
    @ SendUSB _DataToSend
    gosub dousbin
    goto start
    DoUSBIn:
    @ INT_DISABLE USB_INT
    USBService
    USBIn 1, USBBufferin, USBBufferCount, Timeout
    Timeout:
    @ INT_ENABLE USB_INT
    DoUSBOut:
    WaitPC:
    USBService
    USBOut 1, USBBufferOut, USBBufferCount, Waitpc
    usb_device_state var byte EXT
    CONFIGURED_STATE CON EXT
    DoUSBinit:
    usbinit
    repeat
    usbservice
    until usb_device_state = CONFIGURED_STATE
    DoUSBService:
    usbservice
    @ INT_RETURN
    Sep 2009
    Jun 2007
    Sorry , But Didn't work i tried it , Beside its just multimedia keybad not full qwerty & Media Keyboard .
    You forgot element zero (length of 8 is from 0 to 7):
    DATATOSEND[0] = 0
    I can't help you with the keyboard command, sorry.
    DoUSBinit:
    usbinit
    repeat
    usbservice
    1. That PAUSE can screw up USB.
    2. DT INT takes care of USB INIT for you.
    3. You shouldn't have to write your own assembler routines for USB, they should be available in DT INT.
    4. I didn't see ReEnterPBP-18.bas included.
    I recommend read Darrel Taylor's posts from this point:
    http://www.picbasic.co.uk/forum/show...0434#post80434
    Download that file and look how he does things.
    Jun 2007
    I just forget to past it here but already found in my code , thanks for mention
    Jun 2007
    Thanks Robert ,
    Already Did Now But , Doesn't Help In My Situation (Multimedia & qwerty Keyboard) .
    Hi all,
    I don't mean to turn my question into an off topic but,
    can someone explain me how the descriptor works without being included in the main program ( my question above ) ?
    Rui
    Jan 2006
    Toronto
    I am confused, you asked how to add multimedia keys so he linked to my HID multimedia keypad and u simply say it doesn't work and its not a full keyboard. What exactly do you want then?
    I do use Darrels interrupt routines in mine as they work way better for this type of job but did not include the actual files as I just thought it was better to get them from Darrel.
  1. USB HID is slower than often using PIC18f2550
    By Ahmadabuomar in forum mel PIC BASIC Pro
    Last Post: - 16th November 2010, 15:05
  2. HID Keyboard Example
    By apitaru in forum USB
    Last Post: - 6th August 2010, 17:27
  3. PIC18F2550 Newbie
    By JeffnDana in forum mel PIC BASIC Pro
    Last Post: - 26th April 2007, 16:13
  4. Replies: 3
    Last Post: - 18th January 2006, 15:12
  5. USB, PIC18F2550 and VB
    Last Post: - 27th November 2005, 19:37
