how to access and set bits in a byte array?
Results 1 to 10 of 10
    Default how to access and set bits in a byte array?
    Hi all
    i have a byte array
    bArrRGBData VAR byte[4]
    i want to first check some individual bits across the entire array and then depending on their state set some other bits across the entire array individually depending on the outcome of the IF tests,
    but i can't figure out the syntax
    when i wrote
    bArrRGBData[0].1
    it was rejected
    so i tried
    bArrRGBData.1
    and PBP liked ok that but when i wrote
    bArrRGBData.8
    PBP was not happy either
    to state the overall goal (as there may be another way to skin this cat) there are 4 bytes in the array holding some pre-existing values,
    the byte is constructed of bit pairs
    i want to set a few bits in each array byte depending on the values of the bits in the bit pairs
    i realize i could copy to a byte variable then examine the bits there, then set the bits in that copy and then copy back to the array but that seems not only like a lot of work but a lot of code,
    any tips much appreciated as it seems there should be a better way
    Default Re: how to access and set bits in a byte array?
    bArrRGBData.0[offset]
    thanks
    ok i think i get that
    but
    bArrRGBData.0[8]
    starts at the 9th bit (?), but what does it return ?
    oh
    maybe i have a bit var
    bitvar = bArrRGBData.0[8]
    is that how to do it ?
    and is 9th correct? i.e. the [offset] starts counting from 0 ?
    thanks for your help
    pretty much
    bArrRGBData.0[8] is bit 0 of bArrRGBData[0] bit 0 + 8 bits , ie bArrRGBData[1] bit 0
    you can place it in any var but its value can only be 0 or 1
    can also be used as a logical value ie.
    if bArrRGBData.0[8] then dosomething
    doanotherthing
    just a warning pbp does not ckeck the boundary conditions of this type of indexing
    if you were to
    go
    bArrRGBData.0[41] =1
    there is no error message and anything in the next ram/register position from bArrRGBData[4] would be wrecked
    pretty much
    doanotherthing
    thanks for you help, am removing some rust here due to inactivity
    what bothered me for a bit (pun intended) was whether this would by syntax return a single bit, i realize now that the .0 portion says that and explaining that bArrRGBData.0[8] is equivalent to bArrRGBData[1] bit 0 is just what i needed
    i also understand the risk about overrunning the allocation
    how about these cases
    MyWordArray VAR WORD[8]
    what does the following do exactly ?
    MyWordArray = 0
    does it set the first byte of the Array to 0 and leaves the rest as was ?
    what if there is a word variable used instead
    AWord VAR WORD
    AWord = 0
    MyWordArray = AWord
    now are the first 2 bytes set to 0 ?
    just curious ....
    MyWordArray = 0
    I would not expect that to compile as "MyWordArray" is a pointer to a memory address.
    MyWordArray[0]=0 is the correct syntax to set the first word in the array to = 0
    MyWordArray[1]=0 for the next word
    AWord VAR WORD
    AWord = 0
    MyWordArray = AWord
    MyWordArray[0] = AWord is whats required
    out of curiosity I had a look at what happens when you access an array just by using its name with no index []
    and pbp addresses the first var in the array as the type of var specified in the array declaration .
    I would not recommend the practice though
    '*  Notice  : Copyright (c) 2014 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 7/2/2014                                          *
    '*  Notes   : 16f1825                                                 *
       __config _CONFIG1, _WDTE_ON    & _FOSC_INTOSC   &_MCLRE_ON    &_PWRTE_ON
       __config _CONFIG2,              _LVP_OFF
          DEFINE OSC 32
       osccon=$70    '32 mhz
             anselA=0        'dig i/o
             ANSELC=0
           TRISA= %11111110
         APFCON0.7=0
                  so var porta.0
    so=1
    pause 4000
                 myarry var word[8]
       myarry[0]=$ffff
       myarry[1]=$ffff
       serout2 so,84,[ "ready ",13,10]
        pause 4000
        serout2 so,84,[ #myarry[0]," ",#myarry[1],13,10]
        myarry=0
    result
    ready
    65535 65535
    0 65535
    thanks Richard, that is what i wanted to know, yes agreed is probably best to avoid
  1. How do I check (or set) a group of consecutive bits within a byte?
    Last Post: - 2nd April 2012, 08:13
  2. Problem with bits in byte array....
    By HenrikOlsson in forum mel PIC BASIC Pro
    Last Post: - 19th October 2011, 06:27
  3. Access array in PBP and .asm
    By JEC in forum mel PIC BASIC Pro
    Last Post: - 6th September 2008, 00:35
  4. reading first four bits of a byte
    By kamet in forum mel PIC BASIC Pro
    Last Post: - 2nd January 2007, 08:50
  5. Word array behaving like byte array.... wierd
    By forgie in forum mel PIC BASIC Pro
    Last Post: - 2nd August 2005, 15:43
