Remove Text Formatting
Loading...
+ Reply to Thread
Results 1 to 3 of 3
    Feb 2012
    PERTH AUSTRALIA
    Default DT lOW PRIORITY INTERRUPTS - ASM WARNING
    HI GUYS
    Was giving DT low priority interrupts a run , but i get a ASM warning , of " found call to to macro in column 1 ( INT_CREATE_L)"
    is this normal when using these ?
    cheers
    Sheldon
    Default Re: DT lOW PRIORITY INTERRUPTS - ASM WARNING
    i get that fairly often when i cut and past in the ASM section for dt ints , there is an illegal white space character in there somewhere that chokes mpasm. best solution delete whole section and retype it . make sure that only lables are in line chr pos 0 also.
    Feb 2012
    PERTH AUSTRALIA
    thanks richard
    yep that was it , something ill keep in mind for next time
    cheers
    sheldon
  1. Replies: 4
    Last Post: - 24th January 2014, 20:38
  2. DT_INTS-18 ASM Interrupts
    By JustinS in forum General
    Last Post: - 23rd July 2013, 11:03
  3. Quadrature encoder and ASM Interrupts. questions..
    By godfodder in forum mel PIC BASIC Pro
    Last Post: - 17th March 2013, 15:45
  4. asm interrupts
    By Macgman2000 in forum mel PIC BASIC Pro
    Last Post: - 18th September 2008, 05:00
  5. ASM Interrupts with BASIC code?
    By Desterline in forum mel PIC BASIC Pro
    Last Post: - 31st October 2003, 20:21
