Hi there,
Here's one more thread about multiple interrupts use (...) but after hours of reading, I still can't find THE information I'm looking for or in other words, the info I can understand.
I know Darrel made everyone's life much easier with his routine, but I would like to understand how multiple interrupts are to be handled "in a perfect world".
I have made a program (see code hereunder) where I have involved two interrupts: TMR0 and an IOCB (Interrupt on Change) on PORTB.6 .
As the TMR0's interrupt seems to work perfectly (= it toggles every second as it has to), the IOCB will work too but in a fuzzy way. In fact, the IOCB will sometimes light the IOCB_LED shortly, sometimes this LED will remain ON, sometimes it won't even light.
Maybe I need to trigger the rising or falling edge of the push-button's action and also if and how to debounce it especially in an interrupt handler.
Does my interrupt handling routine make sense? How can it be done a cleaner, simpler way?
Any info?
Code:' PIC 16F690 @ __config _FCMEN_OFF & _IESO_OFF & _BOR_OFF & _CPD_OFF & _CP_OFF & _MCLRE_OFF &_PWRTE_OFF & _WDT_OFF & _INTRC_OSC_NOCLKOUT '------------------------------------------------------------------------------- ' Registers 76543210 OPTION_REG = %00000101 'PORT A&B Pull-Ups / TMR0 prescaler OSCCON = %01100000 'Internal RC set to 4Mhz - not to be used with XTal INTCON = %00101000 'INTerrupts CONtrol ANSEL = %00000000 'Disable analog inputs Channels 0 to 7 ANSELH = %00000000 'Disable analog inputs Channels 8 to 11 ADCON0 = %00000000 'A/D Module is OFF CM1CON0 = %00000000 'Comparator1 Module is OFF CM2CON0 = %00000000 'Comparator2 Module is OFF WPUA = %00000000 'Weak pull-ups IOCA = %00000000 'interrupt on change TRISA = %00000000 'Set Input/Output (0 to 5) PORTA = %00000000 'Ports High/Low (0 to 5) WPUB = %01000000 'Weak pull-ups PORTB = %00000000 'Ports High/Low (4 to 7) IOCB = %01000000 'interrupt on change TRISB = %01000000 'Set Input/Output (4 to 7) TRISC = %00000000 'Set Input/Output (0 to 7) PORTC = %00000000 'Ports High/Low (0 to 7) DEFINE OSC 4 '------------------------------------------------------------------------------- ' Variables Ticks VAR BYTE Ticks = 0 Old_bits VAR BYTE New_bits VAR BYTE P_Button VAR PORTB.6 TMR0_LED VAR PORTA.4 'indicates a TMR0 INTerrupt IOCB_LED VAR PORTA.5 'indicates a IOCB INTerrupt '——————————————————————————————————————————————————————————————————————————————— ' Start program '——————————————————————————————————————————————————————————————————————————————— ON INTERRUPT GOTO ISR MAIN: Old_bits = PORTB ' do some things here GOTO MAIN '------------------------------------------------------------------------------- ' Interrupt routine '------------------------------------------------------------------------------- ISR: DISABLE ' TMR0 IF INTCON.2 = 1 THEN INTCON.2 = 0 TICK_INT: Ticks = Ticks + 1 IF Ticks < 61 THEN DO_NOTHING Ticks = 0 TOGGLE TMR0_LED DO_NOTHING: ENDIF ' IOCB IF INTCON.0 = 1 THEN INTCON.0 = 0 New_bits = PORTB IF (New_bits.6 <> Old_bits.6) THEN 'PORTB.6 has changed TOGGLE IOCB_LED ENDIF Old_bits = New_bits ENDIF RESUME ENABLE END
