PK3Err0040: The target device is not ready for debugging
Results 1 to 4 of 4
    Jul 2014
    Question PK3Err0040: The target device is not ready for debugging
    hello, everyone
    I am developing application using PIC18f4620
    My framework: MPLAB IDE v8.70, mcc18 v3.31, and Microchip PICkit3
    - The first, I set pickit3 as programmer (in mplab ide, I seleced "Programmer>select Programmer>PICkit3"):
    Now, I programed it (programmer>program). it was successful.
    and then I ran it. My application ran correctly.
    - Now, I want to use PICkit3 for debugging
    + close PICkit3 in Programmer mode (Programer>select Programmer>none)
    + Set PICkit3 as Debugger (Debugger>select tool>PICkit3)
    + I recompiled application with DEBUG mode (Project>Build configuration>Debug)
    + reprogram application (Debugger>program)
    + now, I run debugging (Debugger>run or press "F9"):
    the following error raised:
    "PK3Err0040: The target device is not ready for debugging. Please check your configuration bit settings and program the device before proceeding."
    I solved this problem as following:
    - recheck PICkit3's debug support for pic18f4620 through "Select Device" window (configure>select device...): in debuggers, PICkit3 led indicator is green. So pic18f4620 is supported by pickit3
    - My configure code is:
    #pragma config WRTC = OFF //Configuration Register Write Protection
    #pragma config DEBUG = ON //Background Debugger Enable
    #pragma config WDT = OFF //WDT disabled (enabled by SWDTEN bit)
    #pragma config OSC = HSPLL
    #pragma config BOREN = OFF //Brown-out Reset is Disabled
    #pragma config PBADEN = OFF //PORTB<4:0> digital on Reset
    #pragma config LVP = OFF //Low Voltage ICSP is disabled
    I don't understand why it is false.
    Please suggest me the solution. thank you very much!
    Sep 2009
    Default Re: PK3Err0040: The target device is not ready for debugging
    #pragma looks to me as C, this is basic forum...
    MCLRE must be ebnabled, PWRT disabled, code protect disabled.
    Thats what I thought, I also don't know what "mcc18 v3.31" is? Maybe Microchip "C" forum is the place for the correct answer?
    EN82fn
  1. Target Device does not match selected device
    By queenidog in forum FAQ - Frequently Asked Questions
    Last Post: - 25th June 2011, 00:24
  2. ICDWarn0020: Invalid target device id
    By pravec065 in forum General
    Last Post: - 4th August 2008, 13:43
  3. Target device does not match
    By krohtech in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2008, 04:20
  4. PIC18F4620 not Target Device
    By kiwipiper in forum mel PIC BASIC Pro
    Last Post: - 17th October 2007, 19:42
  5. Target device <> Selected Device????
    By deepgfishing in forum mel PIC BASIC Pro
    Last Post: - 20th June 2007, 21:18
