Is modedefs.bas still required for pbp3 ?
Results 1 to 8 of 8
    Feb 2012
    PERTH AUSTRALIA
    Default Is modedefs.bas still required for pbp3 ?
    just looking to trim stuff from programs that may not have the need for the files and wondered if the modedefs.bas is required for pbp3 still ?
    Default Re: Is modedefs.bas still required for pbp3 ?
    I'm still on 2.60C and haven't used it.
    EDIT: When I use a segment of code that uses it, I just copy the specific variables in my program.
    Modedefs.bas is just a file full of alias s and is not required at all. You could write the particular alias or just learn which mode to use, or look it up.
    Feb 2012
    PERTH AUSTRALIA
    i have included it for shiftin/out and some serial stuff , adding the alisis can be done in the program , but by including it does the same , but if pbp3 has these built in then i can drop the alias lists
    Jun 2009
    Sc*nthorpe, UK
    Quote Originally Posted by longpole001 View Post
    From the manual for PBP3
    The Mode names (e.g. MSBPRE) are defined in the file MODEDEFS.BAS. To use them, add the line:
    Include "modedefs.bas"
    to the top of the PICBASIC PRO program.
    which tells us that they are not included in PBP3. As Archangel said in #3 use the mode numbers instead of the mode alias to save space.
    I am not certain using the mode numbers will change the size of the compiled code by much or any, it will reduce the source code size. I simply have not compared them.
    The file does not contain any runtime code what so ever. Including it does in no way change the size of generated .hex file so there's nothing to be gained by not including it if you're aiming to reduce the footprint of the actual .hex
    Feb 2012
    PERTH AUSTRALIA
    thanks guys
  1. Modedefs.bas
    By mrpeja in forum mel PIC BASIC
    Last Post: - 24th March 2010, 12:56
  2. Modedefs.bas
    By Richardco in forum mel PIC BASIC Pro
    Last Post: - 25th November 2005, 10:58
  3. modedefs.bas
    By jrudd in forum mel PIC BASIC Pro
    Last Post: - 21st March 2005, 18:16
  4. Modedefs.bas
    By NavMicroSystems in forum mel PIC BASIC Pro
    Last Post: - 5th March 2004, 23:47
  5. Help Required
    By lester in forum Forum Requests
    Last Post: - 19th July 2003, 23:16
