Quick PIC16F874A question
Results 1 to 4 of 4
    Jan 2010
    Default Quick PIC16F874A question
    I am looking at this PIC and notice in the pinout description that on PortC, the buffer type is a Schmitt Trigger, but the description classifies it as a digital I/O. I just want to make sure that these pins will work like a TTL for on/off, unlike the 628A where A.4 is an open-drain and requires a pullup resistor.
    I know I've answered my own question, but I just want to be 100% positive.
    Tony
    Default Re: Quick PIC16F874A question
    a Schmitt Trigger is a type of input circuit and therefore refers to the input buffers for the port , portc on that chip has no open drain pins .
    porta.4 however is open drain
    Jan 2010
    But it will work like a TTL I/O, will it not? The digital I/O comment I am questioning, even though it is a Schmitt trigger.
    if the chip is powered from a 5 volt supply then as a input device its logic level thresholds will be similar to any ttl device with a Schmitt trigger input stage and therefore be ttl compatible and as a output its drive capability is well within the ttl family fanout range.
    google Schmitt trigger if you don't understand . (Schmitt trigger is a input feature it has no relevance to the output stage at all)
  1. A quick question.....
    Last Post: - 17th December 2010, 14:25
  2. Quick DS18B20 question
    By gti_uk in forum General
    Last Post: - 21st June 2009, 17:24
  3. PIC16F84A - Quick question
    By samuelbarber in forum mel PIC BASIC
    Last Post: - 29th June 2005, 14:32
  4. Interrupt Quick Question
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 25th January 2005, 05:51
  5. quick question
    By Srigopal007 in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2004, 01:45
