Flash erase byte routine
Results 1 to 21 of 21
    Feb 2012
    PERTH AUSTRALIA
    Default Flash erase byte routine
    Hi guys ,
    i am trying to do a erase byte routine for flash
    The FLASH as i have learned is not the same as EEProm in that you cant just change bytes values as you may like to on the fly , changing byte to $FF requires your do a complete sector erase , depending on the chip and the size the sector erase can range from 4k bytes to 64k bytes at a time.
    chip i am currently using has a sector erase of 64k bytes
    I would like to have a routine that allows for a byte changes 1 to 256bytes at a time on the same sector/ page/ byte.
    the current routine inputs give the 24bit start address , length of data of the bytes to be changed , and the data in the buffer
    for easy naming i have broken the 24bit address in to 3 bytes named , sector/page/bytes for the 8mb chip i am working on sector size is 0-15, pages = 0-255,bytes = 0-255
    method of approach i have is
    1. erase temp swap sector 0
    2. copy all data of sector/page/bytes to sector 0 EXCEPT the bytes that are to be changed
    3. write the new bytes to correct location in sector 0
    4. erase original sector
    5. copy sector 0 to orginal sector
    sounds simple , the only problem i have is item 2
    whats a good approach
    cheers
    Sheldon
    Jun 2009
    Sc*nthorpe, UK
    Default Re: Flash erase byte routine
    Hi Sheldon,
    Have you got the data sheet so that I can do some reading?
    Feb 2012
    PERTH AUSTRALIA
    should be doable just break job up to small lumps
    say you have a 1k ram block spare
    step 1 erase a temp sector (64k) on the flash
    1. read a k of old sector data
    2 . does this k need to updated?
    if yes update this 1k block
    write this block to temp sector
    3 repeat step 2 63 more times (for each 1k block)
    4 erase old sector (now copied to temp with updates)
    5 copy temp sector back to old sector
    just had a look at your data sheet
    looks like 256 byte blocks may be more appropriate
    and 100,000 write cycles , how often will you be doing this
    still think raspberry pi a more fitting machine for this type of work
    Jun 2009
    Sc*nthorpe, UK
    Reading the data sheet and your code example makes me think this statement is not true.
    and a write to any location is possible. But I will keep reading
    Yes, they can be programmed one byte at the time at any arbitrary memory location. However, "programming" means changing (or not changing) a "1" to a "0". You can't change a "0" to a "1".
    So, before you can program a location it needs to be erased ("reset" to $FF). Erasing is done either sector by sector or the entire chip (bulk).
    Jun 2009
    Sc*nthorpe, UK
    Yes I understand now. I was having difficulty finding the write command in the data sheet but as you explained the program command is used.
    Feb 2012
    PERTH AUSTRALIA
    yep have a look in the example of the code i have posted in the examples , but hendrik is correct the large bulk and sectors erase options suck for a byte change when the location has been written before
    even with this routine its a time pain but Flash are large chips/cheep and if time is a worry then sram /eeproms are probably a option better suited , but there are time when only a few bytes changed option is very nice to have on flash chip
    i am thinking maybe 2 x for, next loop based on the selected location for the change , eg , if selected page/byte is x then copy data to x-1 , and next loop x +1 , this is then done for lower address to lentght of data changed then set upper address
    Hi Sheldon,
    Looking at the datasheet for your device it specifies a sector erase time of 3 seconds(!) and a bulk erase time of 20 seconds (!) - is that really correct?
    The one I've been playing with is the SST25VF080B from Microchip, which is an 8Mbit SPI flash memory device with "only" 4k sectors. It specifies a sector erase time of 25ms and a chip erase time of 50ms (50ms vs 20s for a chip erase).
    Using the SST25VF80 instead of the M25P80 should allow you to get the overall performance up due to the smaller sector size and cosiderably faster erase time - provided the 3second sector erase time is indeed correct. Then, of course, using bit banged SPI is really slow compared to using the MSSP module.
    Feb 2012
    PERTH AUSTRALIA
    yes i have seen better chips and will change to them , the routines work for all the same size chip , ill how much i can get the SST25VF080B for ,
    but ill also try W25Q80BV - have ordered 200 of these at 6c each + freight
    these when they arrive they have a 4k erase space option , and have 25ms time to do it , plus other optionsthat come from the Q series of flash .
    be it 4k or 64k , a routine to change say 1- 256k bytes in the same sector/page on the fly is really nice routine to have on hand on these chips and would be easy enought o change to the size that best suites your needs
    http://www.adafruit.com/datasheets/W25Q80BV.pdf
    Jun 2009
    Sc*nthorpe, UK
    Quote Originally Posted by longpole001 View Post
    be it 4k or 64k , a routine to change say 1- 256k bytes in the same sector/page on the fly is really nice routine to have on hand on these chips and would be easy enough to change to the size that best suites your needs
    We need to start on the routine or have you started?
    Your approach in #1 is to copy sectors to be changed to sector 0. The routine will read from the sector 0 into say byte variables these will then be changed if required and written to Flash. This will be repeated for the whole 4k.
    Any thoughts?
    Feb 2012
    PERTH AUSTRALIA
    yep steve i was thing something like this
    1. erase sector 0
    2 write the changed bytes to sector 0 for page / byte /length data
    3. using the address and number of byte to change length( assumes 1- 256 bytes contiguous) get the all OTHER pages/ bytes in orginal sector and write to sector 0
    so need to find value of entered page address and read into the buffer (256kb) , then write
    a. input page + 1 (data above the input page) for next loop 1 -
    b. input page -1 ( data below the input page) for next loop 2
    c. allow for input page location = 0 or 255 - so for next loop 1 only
    this then copy of all pages EXCEPT that which need to change
    If the input length was 255 then sector 0 has copy of the completed changed data
    if length <255 bytes change then
    then use the input length and byte start address value to read / write
    a. read bytes start address + length + 1 - for next loop1 - ( read the bytes above that dont need to change)
    b. read bytes start address + length - 1 - for next loop2 - ( read the bytes below that dont need to change)
    c. allow for input bytes location + length of 0 or 255 - so for next loop 1 only
    this then copy of all bytes except that which have been changed
    now do a sector erase of the orginal sector
    now read/ write each page back from sector 0 each page
    not easy but as hedric said the smaller the sector erase size the less time it takes
    Apr 2011
    Welches, Oregon
    Sorry to interrupt... I'm just following along for the sake of understanding how this is managed.
    Do I read you right? Using sector 0 as a scratchpad? Reading X sector to 0 WITH changes, then erasing X sector, then writing sector 0 to X? Finally, erasing sector 0, so its blank for the next go-round? Or did I miss something?
    I think I'll read your post a few more times... see if I can't follow your thinking better. Thanks.
    Feb 2012
    PERTH AUSTRALIA
    yes that what i am thinking
    sector 0 is erased
    if the bytes to be changed are say bytes 5 - 10 for sector 15, page 1 then you
    write changed data to sector 0/ page 1 / bytes 5-10
    you copy bytes 0-4 of sector 15/page1 to sector 0/page1/ bytes 0-4 - for next loop 1
    you copy bytes 11-255 of sector 15/page1 to sector 0/page1/ bytes 11-255 - for , next loop2
    copy all other pages from sector 15 to sector 0 -
    erase sector 15
    copy sector 0 to 15 ( in
    as you can see the smaller the sector erase the chip supports the better for small changes
    Feb 2012
    PERTH AUSTRALIA
    steve you want to have a go at it ?
    Jun 2009
    Sc*nthorpe, UK
    I could give it a go. How far have you got?
    Feb 2012
    PERTH AUSTRALIA
    Flash_Byte_Modify:
     ' assumes address , length ( upto 256bytes )
     ' assumes sector 0 is not protected
       SDC_sector = 0
       gosub Flash_Sec_Erase  ' erase sector 0
       SDC_address.byte2 = 0  ' use sector 0,instead of given sector , but use given page, byte length
       gosub Flash_write      ' Write the the changed data to sector 0
       if SDC_page > 0  and SDC_page <255 then  ' find the pages to copy
       SDC_address.byte1 = SDC_page
       if  Data_Length < 255 then
         SDC_address.byte0 = SDC_byte +1 -
    well not far , this is the start
    Feb 2012
    PERTH AUSTRALIA
    bit more of an attempt , steve can you check the logic ,cleanup ,
    Flash_Byte_Modify:
     ' assumes selectted sector is not protected
      Flash_Addr_Copy.byte3 =  Data_Length   ' save the selected address & length
      Flash_Addr_Copy.byte2 =  SDC_Sector
      Flash_Addr_Copy.byte1 =  SDC_Page
      Flash_Addr_Copy.byte0 =  SDC_Byte
      SDC_sector = 0
      SDC_sector = 0                            ' use sector 0,instead of given sector , but use given page, byte length
      if Flash_Addr_Copy.byte1 = 0 then         ' find the pages to copy - copy all pages/ bytes  above 0 for given sector
         for SDC_Page = 1 to 255                 ' read all pages above 0  of selected sector
             SDC_Sector  = Flash_Addr_Copy.byte2    ' of read selected sector
             SDC_byte  = 0                          ' bytes 0 - 255
             Data_Length = 255                      ' all bytes
             gosub Flash_Read                       ' read 255 bytes at a time
             SDC_Sector  = 0                        ' use sector 0 aselected sector
             gosub Flash_Write                      ' write
          next SDC_Page
      if Flash_Addr_Copy.byte1 = 255 then       ' find the pages to copy - copy all pages/ bytes  below given page/ byte of sector
         for SDC_Page = 0 to 254                 ' read all pages below 255  of selected sector
          next SDC_Page
      if Flash_Addr_Copy.byte1 >0 and Flash_Addr_Copy.byte1 < 254 then       ' find the pages to copy - copy all pages/ bytes  below given page/ byte of sector
         for SDC_Page = 0 to Flash_Addr_Copy.byte1 - 1   ' read all pages from 0 to selected page -1
          next SDC_Page
        for SDC_Page = Flash_Addr_Copy.byte1 + 1 to 255  ' read all pages from selected page + 1  to 255
          next SDC_Page
     if Flash_Addr_Copy.byte0 + Flash_Addr_Copy.byte3  < 255 then   ' if the start byte + data length of the data changed is < 255 bytes ,
               ' then copy  bytes  below the selected changed data
             SDC_Sector  = Flash_Addr_Copy.byte2         ' read selected sector
             SDC_PAGE   =  Flash_Addr_Copy.byte1         ' of selected page
             SDC_byte = 0                                ' start address bytes 0 to
             Data_Length = Flash_Addr_Copy.byte0 - 1     ' selected byte - 1  ( length)
              ' then copy  bytes above the selected changed data
             SDC_byte    = Flash_Addr_Copy.byte0 + Flash_Addr_Copy.byte3  ' start address bytes above given address and length
             Data_Length = 255 - SDC_byte                                 ' data above changed bytes ( length = 255 bytes  - given addrees + given length )
             gosub Flash_Read                                             ' read the data
             gosub Flash_Write                                            ' write  the data
        ' Sector 0 should now have a complete copy of the data + changed data from the orginal selected sector
          SDC_sector = Flash_Addr_Copy.byte2
          gosub Flash_Sec_Erase              ' erase orginal sector
          for SDC_PAGE = 0 to 255                                          '  copy sector 0 pages to selected sector 0 ( 256bytes at a time)
               SDC_byte    = 0
               Data_Length = 255
               SDC_Sector  = Flash_Addr_Copy.byte2                          ' use selected sector
               SDC_byte    = 0
               Data_Length = 255
          next SDC_PAGE
          SDC_sector = 0                     ' clean up sector 0
    Jun 2009
    Sc*nthorpe, UK
    I will do! Just need a bit of time to absorb the logic.
    Feb 2012
    PERTH AUSTRALIA
    forgot to write the data at the end
               SDC_byte    = 0
               Data_Length = 255
               SDC_byte    = 0
               Data_Length = 255
               gosub Flash_write                                           ' write the data
           next SDC_PAGE
    Feb 2012
    PERTH AUSTRALIA
    well approach seems to work , here is a rundown , the real key is USE A FLASH CHIP THAT SUPPORTS SMALL SECTOR ERASE SIZE AND USE THAT SETTING
    3 new routines - to be added to examples i left
    hope it save others time in the future
    Sheldon
    1. Flash_byte_modfy - use - change 1- 255 bytes of a selected sector/page ,
    uses sector 0 as scratchpad and places changed code to sector 0 ,
    copies all other pages / bytes not changed of the selected sector to sector 0
    then erases the origin sector and copy complete sector 0 to origin
    how to use
    '---------- FLASH_MODIFY_BYTE TEST - example
         Data_Length = 10     ' changed data length
       For SDC_index = 0 to Data_Length
           SDC_buffer[SDC_index] = SDC_index          ' fill the changed data into buffer  with  values
        next SDC_index
        SDC_Sector = 1              ' sector start address for where data is to be placed
        SDC_Page = 3                ' page start address for where data is to be placed
        SDC_Byte = 16               ' byte start addresss for where data is to be placed
        gosub Flash_Byte_Modify
    Flash_Byte_Modify:
     ' asusmes bytes changed are in the same sector and no boundry cross
     ' assumes selected sector is not protected
      SDC_sector = 0
      gosub Flash_write                         ' Write the data  to sector 0
            Flash_Page_Orgin =1                      ' start page of orgin
            Flash_Page_length = 255                  ' how many pages
            Flash_Sec_Orgin =  Flash_Addr_Copy.byte2 ' sector
            Flash_Sec_Dest = 0
            Flash_Page_Dest = 1
            gosub Flash_Page_Copy
            Flash_Page_Orgin =0                      ' start page of orgin
            Flash_Page_length = 254                  ' how many pages
            Flash_Sec_Dest = 0
            Flash_Page_Dest = 0
            Flash_Page_length = Flash_Addr_Copy.byte1 - 1 ' how many pages
            Flash_Sec_Dest = 0                            ' start at same page value as orgin
            Flash_Page_Dest = 0
            Flash_Page_Orgin = Flash_Addr_Copy.byte1 + 1  ' start page of orgin
            Flash_Page_length = 255 - Flash_Page_Orgin    ' panges to copy  = 255 - start address +1
            Flash_Sec_Dest = 0
            Flash_Page_Dest = Flash_Addr_Copy.byte1 + 1
           Flash_Sec_Orgin = 0                     ' copy sector 0
           Flash_Sec_dest = Flash_Addr_Copy.byte2  ' erase destination  and copy data from flash orgin
           Flash_clear = 1                          ' set flag erase orgin sector 0 after copy
           gosub Flash_Sec_Copy                     ' copy the sector
    2. Sector copy routine - - this routine copy the data from the origin sector to destination sector
    - will erase destination sector prior to copy
    - option flag " Flash_clear " when set will Erase orgin sector after copy
    - assumes no copy protect on destination or origin
    how to use
           Flash_Sec_Orgin = 0                     ' sector origin  - sector to copy
           Flash_Sec_dest = 1                     ' sector destination  - will be erased then copy data from sector origin
           Flash_clear = 1                            ' option flag to erase origin sector after copy
     Flash_Sec_Copy:
      ' copys data from 1 sector to another
      ' erases destination sector - optional clean of orginal sector
      ' assumes Flash_Sect_Orgin,Flash_Sect_Dest Flash_clear
      ' Erases wont work on sectors that are write protected
      ' sector erase take 600ms per instruction
          SDC_Sector  = Flash_Sec_Dest          ' clear destination sector
          gosub Flash_Sec_Erase              ' use SDC_sector info to erase destination sector
               SDC_Sector  = Flash_Sec_Orgin     ' sector to copy
               SDC_byte    = 0
               Data_Length = 255
               gosub Flash_Read              ' read the data to buffer
               SDC_Sector  = Flash_Sec_Dest      ' sector to copy to
               SDC_byte    = 0               ' use sector details for destination
               Data_Length = 255
           next SDC_PAGE
         if Flash_clear = 1 then
            SDC_sector = Flash_Sec_Orgin         ' clean up orgin sector
    3. Page copy routine - this routine will copy pages 0-255 of origin to destination
    - no sector boundry cross supported
    - assumes destination is all "1" - no erase is required
    - sector is not protected
    how to use
    ' example copy sector 0/ page 0 50 pages to sector 0 , start page 125     (  page size number of  bytes depends on chip)
          Flash_Page_Orgin = 0            ' start address page of origin
            Flash_Page_length = 50      ' number of pages to copy
            Flash_Sec_Orgin = 0            ' sector origin address
            Flash_Sec_Dest = 0            ' Sector destination
            Flash_Page_Dest = 125         ' Page destination
    Flash_Page_Copy:
      ' copys data from pages 0 -255 from orgin or destination sector
      ' assumes destination sector pages are Erased
      ' assumes pages orgin and pages destination do not cross sector boundrys
      ' assumes Flash_Page_Orgin,Flash_Page_dest ,Flash_Page_length, Flash_Sec_orgin ,Flash_Sec_dest
      ' writes wont work on sectors that are write protected
         for  Flash_tmp2 =  Flash_Page_Orgin to Flash_Page_length    '  copy sector 0 pages to selected sector 0 ( 256bytes at a time)
               SDC_PAGE =  Flash_tmp2
               SDC_byte    = 0
               Data_Length = 255
               SDC_PAGE = Flash_Page_Dest                        ' page to copy to
               SDC_byte    = 0
               Data_Length = 255
               Flash_Page_Dest = Flash_Page_Dest + 1              ' increment destination page
         next Flash_tmp2
  1. Erase error
    By waynepauly in forum mel PIC BASIC Pro
    Last Post: - 29th June 2012, 02:23
  2. Internal eeprom - erase block
    Last Post: - 13th February 2008, 11:11
  3. 18F2431 won't program or erase.
    By HenrikOlsson in forum mel PIC BASIC Pro
    Last Post: - 28th September 2006, 07:55
  4. 12F675 won't reprogram or erase
    By modifyit in forum mel PIC BASIC Pro
    Last Post: - 19th May 2006, 05:07
  5. 12F629 won't erase and bandgap save?
    By Keith55555 in forum mel PIC BASIC Pro
    Last Post: - 6th April 2004, 01:28
