HMC5883L Magnetometer chip Possibilities.
Page 1 of 2 12 LastLast
Results 1 to 40 of 58
    May 2012
    Merseyside, UK
    Lightbulb HMC5883L Magnetometer chip Possibilities.
    Hi all
    Am looking at the possibly of using a HMC5883L Magnetometer in a compass application with a PIC.
    Has anybody had any experience in these chips and interfacing to a PIC using PicBasic Pro 2.50 or similar.
    Any advice / help Welcome
    BR
    Andy
    Default Re: HMC5883L Magnetometer chip Possibilities.
    Google is your Friend !!! Link to stamp demo on Parallex site http://www.parallax.com/downloads/co...-2-source-code
    Feb 2012
    PERTH AUSTRALIA
    May 2012
    Merseyside, UK
    Thank you for help both...
    I think will just buy a couple and have a play
    Buying 2.... As first one will go pop
    BR Andy
    Oct 2013
    is any body try the code from parallax site and get good results.I connect HMC5883L module to PIC18f452 and 2x16LCD display and I can read the RAW values.If I turn module RAW values are changing , but the value oh azimuth and degree dont work.
    May 2012
    Merseyside, UK
    Quote Originally Posted by visnja30 View Post
    Any chance of sharing code.... We can see what might be happening ??
    BR
    Andy
    Oct 2013
    here is code with I test the MHC5883L chip.
    I can get some raw readings but I dont now are they correct.Range of readings are from 64000 to 1000.when I turn the module reading are change.
    ' HMC5883L_Demo.bs2 - This is a Demo program for the HMC5883L Compass
    ' Module (PN: 29133). It displays the compass heading north, east, south and west
    ' clockwise from north.
    ' Author.... (C) John A. Williams
    ' {$STAMP BS2p}
    ' {$PBASIC 2.5}
         define OSC 4
    'KONFIGURACIJA LCD DISPLEJA 2X16
            DEFINE  LCD_DREG PORTB
           	DEFINE  LCD_DBIT 0
        	DEFINE  LCD_BITS 4
        	DEFINE  LCD_RSREG PORTB
        	DEFINE  LCD_RSBIT 4
        	DEFINE  LCD_EREG PORTB
        	DEFINE  LCD_EBIT  5
        	DEFINE  LCD_LINES 2
          	DEFINE  LCD_COMMANDUS 2000
        	DEFINE  LCD_DATAUS 40
     'SET UP PORTS
    TRISA = %00111111    'port a je cijeli ulazni
    TRISB = %00000000
    TRISC = %11111111
    TRISD = %00000000
    TRISE = %1111
    ADCON1 = 7	   ' PORTA i PORTE su digitalni  ISKLJUCI KOMPARATORE I ANALOGNE ULAZE
    ' -----[ Pins/Constants/Variables ]-------------------------------------------
    SDA            var      PORTC.4
    SCL            VAR      PORTC.3
    WRITE_DATA     CON     $3C  'Used to perform a Write operation
    READ_DATA      CON     $3D  'Used to perform a Read operation
    MODE           CON     $02  'Read/Write Register, Selects the operating mode. Default = Single measurement
                                 'Send $3C $02 $00 on power up to change to continuous measurement mode.
    X_MSB          CON     $03  'Read Register, Output of X MSB 8-bit value.
    X_LSB          CON     $04  'Read Register, Output of X LSB 8-bit value.
    Z_MSB          CON     $05  'Read Register, Output of Z MSB 8-bit value.
    Z_LSB          CON     $06  'Read Register, Output of Z LSB 8-bit value.
    Y_MSB          CON     $07  'Read Register, Output of Y MSB 8-bit value.
    Y_LSB          CON     $08  'Read Register, Output of Y LSB 8-bit value.
    Cont_Mode      CON     $0
    SCALEFACTOR    CON     4081 'SCALEFACTOR = 65536 * (255/4095) = 4081
    SCALEOFFSET    CON     2048 'The output range of the HMC5883L is -2048 to 2047; therefore to get a 0 (LOWRANGE)to 4095 range
                                'to 4095 (HIGHRANGE) range 2048 must be added to the sensor value.
    ATNFACTOR      CON     127  'the ATN function input range is -127 TO 127. In order to get the positive scaled range of
                                '0 to 255 into the range of -127 to 127, 127 must be subtracted.
    LOWRANGE       CON     0    'see SCALEOFFSET
    HIGHRANGE      CON     4095 'see SCALEOFFSET
    X              VAR      Word 'x sensor measured value
    Y              VAR      Word 'y sensor measured value
    Z              VAR      Word 'z sensor measured value
    brads          VAR      Word 'angle in brads
    degr           VAR      Word 'angle in degrees
    azimuth        VAR      Word 'value calculated using X ATN -Y
      degr=0
     PAUSE 500
      LCDOUT $FE,$01'clear DISPLAY
      LCDOUT $FE,$01,"test "
      PAUSE 500
    ' -----[ Main Routine ]-------------------------------------------------------
    PAUSE 10
       I2Cwrite SDA,SCL, $3c, $00, [$70]  '(8-average, 15 Hz default, normal measurement)
       I2Cwrite SDA,SCL, $3c, $01, [$A0] ; $00 hoogste gain setting
       I2CWRITE SDA,SCL,WRITE_DATA,MODE, [cont_Mode]  ' Send continuous output command
        LCDOUT $FE,$01'BRISI DISPLAY
       GOSUB GetRawReading                       ' Get RAW Compass reading
      'RAW X,Y,Z data...
      lCDOUT $FE,$80,   "X= " , sdec x
      LCDOUT $FE,$80+8, "Y= ",   sdec y
      LCDOUT $FE,$C0,   "Z= ",  sdec z
      'Calculate Azimuth
      GOSUB GetAzimuth
      brads = azimuth     'get angle
      degr = brads */ 361 'convert to degrees
      LCDOUT $FE,$80,"Degree " , sdec degr
    ' -----[ Subroutines ]--------------------------------------------------------
    GetRawReading:                                 'Compass module subroutine
        PAUSE 400                                  'Wait for new data to become available
        I2CREAD SDA,SCL, READ_DATA, X_MSB, [X.HIGHBYTE]  'Read the data starting at x_msb 3
        I2CREAD  SDA,SCL, READ_DATA ,X_LSB, [X.LOWBYTE]
       I2CREAD  SDA,SCL, READ_DATA, Z_MSB, [Z.HIGHBYTE]
       I2CREAD SDA,SCL, READ_DATA ,Z_LSB, [Z.LOWBYTE]
        I2CREAD SDA,SCL, READ_DATA, Y_MSB, [Y.HIGHBYTE]
        I2CREAD  SDA,SCL, READ_DATA ,Y_LSB, [Y.LOWBYTE]
    GetAzimuth:
    'The output range of the HMC5883L is -2048 to 2047 and the input range of the ATN function
    'is -127 to 127.  I used the method to scale the output to the input discribed in Parallax's Smart
    'Sensors Student Guide v1 starting on page 76.
    'SCALEOFFSET = 2048
    'ATNFACTOR = 127
    'LOWRANGE = 0
    'HIGRANGE = 4095 (2048 + 2047 = 4095)
        x = x + SCALEOFFSET
        x = (x MIN LOWRANGE  MAX HIGHRANGE) ** SCALEFACTOR - ATNFACTOR
        y = y + SCALEOFFSET
        y = (y MIN LOWRANGE MAX HIGHRANGE) ** SCALEFACTOR - ATNFACTOR
        azimuth = x ATN -y
       LCDOUT $FE,$c0,"azimuth " ,  DEC azimuth
    am I wrong or would right shifting the reading 4 give the same answer without all the math
    x var byte
    reading var word
    x= reading>>4
    Shooting from the hip a bit here....
    Since the ATN expects 8bit two's complement values I'm not sure it's going to work when you give it your x and y variables since they are both 16bit variables - even if the values in them are in +/-127 range. Ah, never mind, it probably will since the low byte of the word will look identical anyway....
    Richard,
    You can't simply shift a two's complement number like that, you'll drop the sign.
    You need to remember the sign, shift the abs value and restore the sign
    Sign VAR BIT
    Reading VAR WORD
    x VAR BYTE
    Sign = Reading.15
    x = ABS(Reading) >> 4
    If Sign THEN x = -x
    it works on paper , i'm curious to compile it and see what happens , i'm feeling a cast from word to byte and only a 4 bit r-shift might allow the loss of the sign bit to be ignorable . if it works it saves a lot of steps
    I would christen it as quick and dirty code
    You're quite right Richard!
    It works provided that x in this case IS declared as a byte (which it was in your code of course)
    x = Reading >> 4
    HSEROUT["Reading: ", SDEC Reading, "   X: ", SDEC x,10,13]
    Reading: -2048   X: -128
    Reading: 2047   X: 127
    Reading: -100   X: -7
    Reading: 100   X: 6
    If x is declared as a WORD then it fails:
    Reading: -2048   X: 3968
    Reading: -100   X: 4089
    Reading: 100   X: 6
    thanks for confirming that henrik ,saves me the trouble .
    I worked that out with the windows7 calculator (in programmer mode) it makes it easy to visualise some solutions , another feature sadly lacking in windoze 8.1
    correction
    not lacking in wdoze8 just hard to find like most of anything that's useful
    May 2012
    Merseyside, UK
    Hi
    I am experriment with this code... more or less same setup as Visnga30 difference being I am using a 16F818..
    I can understand the raw numbers OK X.Y and Z... But I feel something is wrong in the Azimuth Calcs... All I am seeing in debug is 160 for Azimuth and 255 for degr...
    Ultimatly I need it to show Degrees of compass (0 to 360) this would be degr ?
    Help appreciated .
    Andy
    Just noticed thats what OP was saying!
    Last edited by andybarrett1; - 30th December 2014 at 14:37. Reason: Latter addition !
    Oct 2013
    Dear andybarrett1 do you managed to solve the problems with code? Do you managed to show the correct angle and degrees.
    Are you willing to share your code with us?
    May 2012
    Merseyside, UK
    Hi
    I wish I had got it working.... I am working on what the others posted. But at the moment not working.
    It is certainly to do with the ATN function.
    BR
    Andy
    May 2012
    Merseyside, UK
    Hi Richard
    In short am I right in thinking if I declare :-
    x var byte
    readingx var word
    Then Substitute :-
    x = x + SCALEOFFSET
    With :-
    x = readingx >> 4
    The ATN Calculation might work ??
    I am away from my desk at moment but have been struggling with this for a whilst..... :-(
    BR
    Andy
    you can do a similar thing with y axis too ,
    my routine will give the same result as the scale offset method its just much quicker and simpler.
    don't forget the ATN result is in radians so deg = atnresult*360/256
    I suspect that without using floats all round for these calcs the resulting resolution may be a little disappointing , but its worth a look
    May 2012
    Merseyside, UK
    Thank you for reading
    Hi Have tried suggestions...
    But now the I2CRead command is failing on on the HIGHBYE and LOWBYTE locations, I think it due to the X declare beng a Byte now not a Word.
    My solution was to just use the MSB part and comment out the LSB putting the result into X.
    This compiled OK but raw numbers refuse to move.... \i guess it needs the whole word.
    HELP !!
    BR
    Andy
    the i2c read uses the word var readingx the byte var x is the "scaled" result from that reading
    if you can't work that out post your code so we can see what your doing {in code tags }
    May 2012
    Merseyside, UK
    Hi Richard
    Thank you for reply... Here is code to date.... With most recent error.
    '*  Name    : COMPASS_818.BAS                                      *
    '*  Notice  : Copyright (c) 2014 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 24/08/2014                                        *
    ' LCD should be connected as follows:
    '       LCD     PIC
    '       DB4     PortA.0
    '       DB5     PortA.1
    '       DB6     PortA.2
    '       DB7     PortA.3
    '       RS      PortA.4 (add 4.7K (10k)pullup resistor to 5 volts)
    '       E       PortB.3
    '       RW      Ground
    '       Vdd     5 volts
    '       Vss     Ground
    '       Vo      5K potentiometer (or ground)
    '       DB0-3   No connect
        adcon1 = 7     ' Turns Analogs off
        DEFINE OSC 12	'Set oscillator in MHz
        'OSCCON = $70
        DEFINE LCD_EBIT 6
        DEFINE LCD_RSBIT 7
    SDA            var      portb.1                  'transceives to/from SDA
    SCL            var      portb.4                  'sends clock pulses
    Cont_Mode      CON     $0
    X              VAR      byte 'x sensor measured value
    Y              VAR      byte 'y sensor measured value
    Z              VAR      byte 'z sensor measured value
    READX         VAR      WORD
    READY         VAR      WORD
    READZ         VAR      WORD
    PAUSE 500                                     ' Give sensor needed power up time
      I2CWRITE SDA,SCL,WRITE_DATA,MODE,[Cont_Mode]  ' Send continuous output command
    DO
      'RAW X,Y,Z data...
            Lcdout $fe, 1 ' Clear LCD screen
            Lcdout "X=",SDEC X  ,"   Y=",SDEC Y
            Lcdout $fe, $C0, "Z=",SDEC Z
      'DEBUG HOME, "RAW X,Y,Z", CR
      'DEBUG       "X = ",11, SDEC x, CR
      'DEBUG       "Y = ",11, SDEC y, CR
      'DEBUG       "Z = ",11, SDEC z, CR         ' Print angle
      'DEBUG CR
      'Calculate Azimuth
      GOSUB GetAzimuth
      'Calculated Heading in Degrees
      'DEBUG CR
      'DEBUG "Heading in NORTH, EAST, SOUTH, and WEST clockwise from NORTH:", CLREOL, CR, CR
      'DEBUG "Degree " ,11, SDEC degr, CR 'display degrees
      GOSUB GetHeading
    LOOP
        I2CREAD SDA,SCL,READ_DATA, X_MSB,[X.HIGHBYTE]  'Read the data starting at x_msb 3
        I2CREAD SDA,SCL,READ_DATA ,X_LSB,[X.lowBYTE]
    'Do the same for Z and Y:
        I2CREAD SDA,SCL,READ_DATA, Z_MSB,[Z.HIGHBYTE]
        I2CREAD SDA,SCL,READ_DATA ,Z_LSB,[Z.lowBYTE]
        I2CREAD SDA,SCL,READ_DATA, Y_MSB,[Y.HIGHBYTE]
        I2CREAD SDA,SCL,READ_DATA ,Y_LSB,[Y.lowBYTE]
    GetAzimuth:
    'SCALEOFFSET = 2048
    'ATNFACTOR = 127
    'LOWRANGE = 0
        'x = x + SCALEOFFSET
        'x = (x MIN LOWRANGE MAX HIGHRANGE) ** SCALEFACTOR - ATNFACTOR
        'y = y + SCALEOFFSET
        'y = (y MIN LOWRANGE MAX HIGHRANGE) ** SCALEFACTOR - ATNFACTOR
    x = readx >>4
    Y = readY >>4
    'Z = readZ >>4
      'DEBUG       "SCALED X,Y", CR
        azimuth = x ATN -y
      'DEBUG "Azimuth ",11, SDEC azimuth, CR ' display scaled azimuth
      'DEBUG "COS Azimuth ",11, SDEC COS azimuth, CR ' display scaled cos azimuth
    GetHeading:
    'Gives a heading in North, South, East and West.
        IF degr = 90 THEN
            'DEBUG "NORTH"
            'DEBUG CLREOL
        IF degr = 0 THEN
             'DEBUG "EAST"
             'DEBUG CLREOL
        IF degr = 270 THEN
             'DEBUG "SOUTH"
             'DEBUG CLREOL
        IF degr = 180 THEN
             'DEBUG "WEST"
             'DEBUG CLREOL
    Excuse my issues I am still learning....
    BR
    Andy
    this should fix the i2c errors
    '       LCD     PIC
    '       DB4     PortA.0
    '       DB5     PortA.1
    '       DB6     PortA.2
    '       DB7     PortA.3
    '       E       PortB.3
    '       RW      Ground
    '       Vdd     5 volts
    '       Vss     Ground
    '       DB0-3   No connect
        'OSCCON = $70
        DEFINE LCD_EBIT 6
        DEFINE LCD_RSBIT 7
    Cont_Mode      CON     $0
    'SCALEFACTOR    CON     4081 'SCALEFACTOR = 65536 * (255/4095) = 4081
    'SCALEOFFSET    CON     2048 'The output range of the HMC5883L is -2048 to 2047; therefore to get a 0 (LOWRANGE)to 4095 range
    'ATNFACTOR      CON     127  'the ATN function input range is -127 TO 127. In order to get the positive scaled range of
    'LOWRANGE       CON     0    'see SCALEOFFSET
    'HIGHRANGE      CON     4095 'see SCALEOFFSET
    READX         VAR      WORD
    READY         VAR      WORD
    READZ         VAR      WORD
    DO
      'RAW X,Y,Z data...
      'DEBUG HOME, "RAW READX,READY,READZ", CR
      'DEBUG CR
      'Calculate Azimuth
      GOSUB GetAzimuth
      'DEBUG CR
      GOSUB GetHeading
    LOOP
        I2CREAD SDA,SCL,READ_DATA, X_MSB,[READX.HIGHBYTE]  'Read the data starting at x_msb 3
        I2CREAD SDA,SCL,READ_DATA ,X_LSB,[READX.lowBYTE]
        I2CREAD SDA,SCL,READ_DATA, Z_MSB,[READZ.HIGHBYTE]
        I2CREAD SDA,SCL,READ_DATA ,Z_LSB,[READZ.lowBYTE]
        I2CREAD SDA,SCL,READ_DATA, Y_MSB,[READY.HIGHBYTE]
        I2CREAD SDA,SCL,READ_DATA ,Y_LSB,[READY.lowBYTE]
    GetAzimuth:
    'SCALEOFFSET = 2048
    'ATNFACTOR = 127
    'LOWRANGE = 0
    x = readx >>4
    Y = readY >>4
    'Z = readZ >>4
        azimuth = x ATN -y
    GetHeading:
        IF degr = 90 THEN
            'DEBUG "NORTH"
            'DEBUG CLREOL
        IF degr = 0 THEN
             'DEBUG "EAST"
             'DEBUG CLREOL
        IF degr = 270 THEN
             'DEBUG "SOUTH"
             'DEBUG CLREOL
        IF degr = 180 THEN
             'DEBUG "WEST"
             'DEBUG CLREOL
    to get the azimuth result in degrees
    azimuth = ( x ATN -y) */ 360
    Not important at this point but you have East and North reversed.
    I'm try to do the same thing with HMC5983, I can read data which seems reasonable ie very different and repeatable for the four directions, but I can't seem to produce a heading less than about 180.
    Typical raw numbers
    x y
    N 215 -176
    E -76 7
    S -265 -287
    W -12 -474
    Seems like an awful lot of negative numbers? I wonder if I've killed it?
    George
    May 2012
    Merseyside, UK
    Thank You....
    Will try ASAP...
    Have a great New Year.... Or .... Has it happened already !
    BR
    Andy
    May 2012
    Merseyside, UK
    Hi..
    Some success.... with code as below:-
    Am I correct in assuming the compass is in the X-Y Axis ..., Z is purely for Azimuth?
    I think something is wrong with Azimuth and Degree calcs as Degree is only moving between 0-256...
    The good news is both of them are moving now :-)
    I really am wishing I paid more attention to maths now at school... Being a hardware engineer I can blag my way though it... Dabbling with S/W it not so easy...
    Any pointers welcome.... Happy New year to All
    BR
    Andy
    '       LCD     PIC
    '       DB4     PortA.0
    '       DB5     PortA.1
    '       DB6     PortA.2
    '       DB7     PortA.3
    '       E       PortB.3
    '       RW      Ground
    '       Vdd     5 volts
    '       Vss     Ground
    '       DB0-3   No connect
        'OSCCON = $70
        DEFINE LCD_EBIT 6
        DEFINE LCD_RSBIT 7
    Cont_Mode      CON     $0
    READX         VAR      WORD
    READY         VAR      WORD
    READZ         VAR      WORD
    DO
      'RAW X,Y,Z data...
            'Lcdout $fe, 1 ' Clear LCD screen
            'Lcdout "X=",SDEC READX  ,"   Y=",SDEC READY
            'Lcdout $fe, $C0, "Z=",SDEC READZ
      'DEBUG CR
      'Calculate Azimuth
      GOSUB GetAzimuth
      'degr = brads */ 361 'convert to degrees
       degr = brads*360/256
       Lcdout $fe, $C0, "Degrees =",SDEC degr
      'DEBUG CR
      GOSUB GetHeading
    LOOP
    GetAzimuth:
    'SCALEOFFSET = 2048
    'ATNFACTOR = 127
    'LOWRANGE = 0
    x = readx >>4
    Y = readY >>4
    Z = readZ >>4
       'azimuth = x ATN -y
          Lcdout "Azimuth=",SDEC azimuth
    GetHeading:
        IF degr = 90 THEN
          'Lcdout "North"
            'DEBUG "NORTH"
            'DEBUG CLREOL
        IF degr = 0 THEN
          'Lcdout "East"
             'DEBUG "EAST"
             'DEBUG CLREOL
        IF degr = 270 THEN
          'Lcdout "South"
             'DEBUG "SOUTH"
             'DEBUG CLREOL
        IF degr = 180 THEN
          'Lcdout "West"
             'DEBUG "WEST"
             'DEBUG CLREOL
    your degree calc is incorrect
    this will overflow a word var causing errors
    degr = brads */ 360
    is the better way
    May 2012
    Merseyside, UK
    Hi Richard.
    Still reading between 100 to 900 on degrees.
    Close to the River Mersey in Liverpool here fireworks are all ready noisy
    Thank you for help ....
    looks like you are converting azimuth to degrees twice
    once here
     'Calculate Azimuth
      GOSUB GetAzimuth
       degr = brads*360/256      and this is still wrong needs to be  degr = brads */ 360
    and once here
    x = readx >>4
    Y = readY >>4
    Z = readZ >>4
       'azimuth = x ATN -y
    surly once is enough
    azimuth = x ATN -y
    May 2012
    Merseyside, UK
    I am now more confused than I was before....
    Aximuth is the angle between ground and the Z-Plane
    Degree is the heading (ie Compass Bearing)
    I am most interested in getting the display to show degrees on North, East, West .... Whatever...
    Confused...
    Andy
    your prg as provided does nothing with the "Z" reading
    the term you have designated as azimuth is derived from azimuth = x ATN -y ie an " x " and a " y " reading , these readings are a vector (rectangular co-ordinates) the ATAN function gives you the (polar ) direction of the vector in radians where 0-255 corresponds to 0-360 degrees , so to get a degree reading the
    degr = brads */ 360 scales the atn result to degrees
    z is right out and your variable names aren't strictly meaningful
    Last edited by richard; - 31st December 2014 at 23:10. Reason: typo its not vectors its a vector and removed the dual degree conversion again
    May 2012
    Merseyside, UK
    Hi
    Z just got commented out by accident... My Bad.. It back now and was anyway !
    Sorry again my misunderstanding if the ATN result is radians 0 to 255 the equation as I remember is:-
    Degree = radians x 180 over PI
    You see my confusion ?
    from the pbp manual
    ATN returns the 8-bit arctangent of 2 two's-complement 8-bit values. If a byte is
    greater than 127 (high bit set), it is treated as a negative value. The arctangent
    returned is in binary radians, 0 to 255, representing a range of 0 to 359 degrees.
    May 2012
    Merseyside, UK
    Hi Richard...
    Will tidy code and play more later ...today !!
    Thanks for help
    I non too good with S/W
    May 2012
    Merseyside, UK
    Hi
    Have tided code.... And it does seem to work better now. But Degrees are reversed (360 to 0) Clockwise. Or am I reading the sensor upside down?
    Azimuth is renamed Radians... the resulting calculation now used to give degrees.
    Z... is not used at all... Maybe I can add or subtract the locale degree error (Unknown at time of writing) into code once degrees working the right way round.
    Latest code show below.... Bear in mind I am not a software guy so any suggestions of further advice welcome.
    '       LCD     PIC
    '       DB4     PortA.0
    '       DB5     PortA.1
    '       DB6     PortA.2
    '       DB7     PortA.3
    '       E       PortB.3
    '       RW      Ground
    '       Vdd     5 volts
    '       Vss     Ground
    '       DB0-3   No connect
        'DEFINE OSC 12	'Set oscillator in MHz
        OSCCON = $70
        DEFINE LCD_EBIT 6
        DEFINE LCD_RSBIT 7
    Cont_Mode      CON     $0
    READX         VAR      WORD
    READY         VAR      WORD
    READZ         VAR      WORD
    Radians        VAR      Word 'value calculated using X ATN -Y
    DO
    'RAW READX,READY,READZ data...
    'Calculate Azimuth
      GOSUB GetRadians
      brads = Radians     'get angle
      degr = brads */360 'convert to degrees
    GOSUB GetHeading
    LOOP
    GetRadians:
    'is -127 to 127.
    x = readx >>4
    Y = readY >>4
    Z = readZ >>4
       'Lcdout "X=",SDEC X  ,"   Y=",SDEC Y
       'Lcdout $fe, $C0, "Z=",SDEC Z
    Radians = x ATN -y
    Lcdout "Radians =",SDEC Radians
    GetHeading:
        IF degr = 90 THEN
        'Lcdout "North"
        IF degr = 0 THEN
        'Lcdout "East"
        IF degr = 270 THEN
        'Lcdout "South"
        IF degr = 180 THEN
        'Lcdout "West"
    Andy, you still have North and East reversed and South and West reversed as well, North is 0, East is 90, South is 180 and West is 270.
    http://commons.wikimedia.org/wiki/File:Compass_Card.png Although I guess you'd be better off saying greater than 315 or less than 45 it's North.
    George
    BTW I'm trying and failing to get a 5983 (supposedly updated version) working with little or no success, I think I killed it!
    May 2012
    Merseyside, UK
    Hi George
    I think the reversal on the last bit of the code is to do with headings and angles etc.. So not all that worried.
    Is the 5983 the same layout as mine... If so will the code not crow bar into it ?
    Am also not to sure about gain settings etc.... Have left mine at default.
    BR
    Andy
    My understanding (perhaps wrong) is that 5983 is an improved version of 5883. It is temperature compensated and will output at a greater rate appearently. I'm working on the assumption that it is software compatible - but you know what they say about assume.
    George
    I can't edit my last post and I wanted to add
    My understanding is that you want the gain as high as possible without saturating. X,Y and Z values are in the range -2048 to 2047 so I guess you're looking for something like -1500 to 1500.
    I see you don't allow for declination, the difference between magnetic and true north. You can get your local declination from http://www.magnetic-declination.com/
    I'm assuming the the X coordinate points North, although now I think of it I can't see why. the only reference I can find is "Arrow indicates direction of magnetic field that generates a positive output reading in Normal Measurement configuration" take from that what you will.
    George
    May 2012
    Merseyside, UK
    Hi George
    I agree with gain... Reading the datasheet seems to be way to go ... If it over saturates you get the -4096 figure.
    I also am assuming that X is north... Certainly shows like that at in most of places I have looked.
    Y seems to be either West (left) or East (right).... depending on what you look at... I did find a useful Honeywell document yesterday, will post a little later on.
    There is certainly a shortage of info around as to how to use these devices with PicBasic
    BR
    Andy
    Are you using one of the break-out boards, GY0281 or GY282? Could you post a circuit diagram? The two break-out boards above both have 3.3v regulators on them, I'm curious as to what Vcc you run the PIC at and if you use level changers. If X is North Y must be West. George
  1. 3 axis digital compass sensor HMC5883L
    By ScaleRobotics in forum General
    Last Post: - 8th June 2014, 22:19
  2. How to use this IO chip?
    By wdmagic in forum mel PIC BASIC Pro
    Last Post: - 30th April 2013, 19:06
  3. compass chip
    By Macgman2000 in forum mel PIC BASIC Pro
    Last Post: - 27th October 2009, 01:42
  4. Do you use ICD possibilities of MicroCode Studio
    By octal in forum mel PIC BASIC Pro
    Last Post: - 14th December 2007, 17:22
  5. Which chip do i use?
    Last Post: - 2nd December 2007, 22:28
