Problem with Newhaven LCD on 18LF66K80
+ Reply to Thread
Results 1 to 8 of 8
    May 2014
    Stone, Staffordshire, UK
    Default Problem with Newhaven LCD on 18LF66K80
    Hello,
    I am having great difficulty getting a newhaven 20x4 LCD working on my 18LF66K80 in 4 bit mode. When using PORTA.0-3, once one bit of data is set, it gets unset before the next is set. I have temporary solved that by embedding assembler which achieves the same thing, however I am getting a persistent problem where the display just shows 2 rows of vertical lines.
    I also get similar results from using LCDOUT, where basically when I set all the bits suitably it "just doesn't work" with similar effects to above.
    I am confident with the wiring as we have another PIC with the same code written in C (albeit 8bit) working perfectly.
    D4-7 are on RA0-3 respectively
    RW is on RF3
    RS is on RF2
    E0 is on RA5
    The following are the defines I tried for LCDOUT.
    DEFINE LCD_DREG PORTADEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTF
    DEFINE LCD_RSBIT 2
    DEFINE LCD_REREG PORTF
    DEFINE LCD_RWBIT 3
    DEFINE LCD_EREG PORTA
    DEFINE LCD_EBIT 5
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2100
    DEFINE LCD_DATAUS 500
    An example of the code I am using to display some text is below:
        LCDOut $fe,1:FLAGS=0:Pause 250
        LCDOUT "Hello World"
        pause 2000
    goto Main
    Any help getting to the bottom of this would be hugely appreciated!
    Default Re: Problem with Newhaven LCD on 18LF66K80
    Kris, I would move the commands "FLAGS=0" and "PAUSE 250" to just above the MAIN loop. There is no reason to be resetting the display every loop. Also I would set the cursor command to be part of the LCDOUT statement as such: LCDOUT $fe.1,"Hello World". And 2100 us. seems a bit long for the command. I have never used anything more than 250 us. in the past and I have used all different kinds of lcd displays from different mfr's.
    EN82fn
    May 2014
    Hello,
    Thanks for your reply, though we have messed with the command delays a lot just to see if we could get it working, I'll adjust it and try again now. When I connect it to the oscilloscope it seems that the enable line isn't going high for long enough when using LCDOUT which was interesting.
    I will try now and post the results.
    Kris Douglas
    One last thought Kris, I would like to see the direction registers for your ports as well as the the ANCON register values for the portA port F.
    EN82fn
    May 2014
    Hello, my code for the LCD is as follows:
    ' MiniCon Motherboard LCD Test
    ' Kris Douglas 23/05/14
    ' We will run at 64MHz once the PLL is started up
    Define OSC 64
    'LCD Definitions
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSBIT 2
    DEFINE LCD_RWBIT 3
    DEFINE LCD_EBIT 5
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    ' PIC18LF66K80 Configuration Bit Settings
    ' Basic source line config statements
        CONFIG RETEN = OFF
        CONFIG INTOSCSEL = HIGH
        CONFIG SOSCSEL = DIG
        CONFIG XINST = OFF
        CONFIG FOSC = INTIO2
        CONFIG PLLCFG = ON
        CONFIG FCMEN = OFF
        CONFIG IESO = OFF
        CONFIG PWRTEN = ON
        CONFIG BOREN = SBORDIS
        CONFIG BORV = 1
        CONFIG BORPWR = ZPBORMV
        CONFIG WDTEN = ON
        CONFIG WDTPS = 1048576
        CONFIG CANMX = PORTB
        CONFIG T0CKMX = PORTB
        CONFIG T3CKMX = PORTG
        CONFIG MSSPMSK = MSK7
        CONFIG MCLRE = ON
        CONFIG STVREN = ON
        CONFIG BBSIZ = BB2K
        CONFIG CP0 = OFF
        CONFIG CP1 = OFF
        CONFIG CP2 = OFF
        CONFIG CP3 = OFF
        CONFIG CPB = OFF
        CONFIG CPD = OFF
        CONFIG WRT0 = OFF
        CONFIG WRT1 = OFF
        CONFIG WRT2 = OFF
        CONFIG WRT3 = OFF
        CONFIG WRTC = OFF
        CONFIG WRTB = OFF
        CONFIG WRTD = OFF
        CONFIG EBTR0 = OFF
        CONFIG EBTR1 = OFF
        CONFIG EBTR2 = OFF
        CONFIG EBTR3 = OFF
        CONFIG EBTRB = OFF
    ' Alias definitions
        'Alias the LED on the board
        localLed var PORTA.7
        'Alias the LCD control pins
        LCD_Backlight var PORTB.5
        LCD_E2 var PORTF.1
        'Alias the buzzer on the board
        buzzer var PORTC.1
        'Alias the watchdog
        mbWatchDog var PORTF.7
    ' Variables
        'LCD Variables
        lcdData var byte
        bla var byte
    ' Set Phase-Locked Loop to Enabled
        'OSCCON = OSCCON | %01110000
        'OSCTUNE = OSCTUNE | %01000000
    ' Port configuration
        'Port D needs setting to digital
        ADCON1 = %01101111
    ' Program code to flash LED and display text on LCD
        LCDOUT $fe,1, "Hello World"
    goto Main
    Kris Douglas
    Apr 2011
    Welches, Oregon
    I am NOT familiar with the chip you are using, but just yesterday I was near to pulling out my few remaining hairs before realizing that I had not set my TRIS registers to output. Is this necessary on the 18LF66K80?
    Try adding this:
    http://www.picbasic.co.uk/forum/showthread.php?t=18529
    Then check the warnings during compile. It will tell you how to make all pins digital.
    You set port D to digital but I see nothing for port A.
    Feb 2012
    PERTH AUSTRALIA
    i agree with robert , check port A config as a start point , as port a 0-5 are analog optional , also when connecting port at 64mhz i had some very bad results when not using the "LATA.x" commands for outputs , here Port A for the 18F67K22 , should be much the same
    ' -------   Setup port A Variables  & directions  ----------
        ANCON0.0 = 1               ' Set PortA:0 Analog / Digital allocation - 0 = digital ,1 analog - ANSEL0
        ANCON0.1 = 1               ' Set PortA:1 Analog / Digital allocation - 0 = digital ,1 analog - ANSEL1
        ANCON0.2 = 1               ' Set PortA:2 Analog / Digital allocation - 0 = digital ,1 analog - ANSEL2
        ANCON0.3 = 1               ' Set PortA:3 Analog / Digital allocation - 0 = digital ,1 analog - ANSEL3
        ANCON0.4 = 1               ' Set PortA:5 Analog / Digital allocation - 0 = digital ,1 analog - ANSEL4 Set RA5 (AN4/ ANSEL4) to be analog input for V-Mon
        TRISA =  %00101111         ' setup Port A input=1,output=0 for I/O pins , set input for RA0-RA3, RA5
        PORTA  = %00101111         ' Clear Outputs
  1. Problem with GOSUB/GOTO and Newhaven OLED question
    By Christopher4187 in forum mel PIC BASIC Pro
    Last Post: - 12th April 2013, 10:24
  2. Newhaven Serial COG 2X16 LCD
    By Neosec in forum mel PIC BASIC Pro
    Last Post: - 20th March 2013, 06:09
  3. Newhaven 4x40 LCD, issues!
    By MOUNTAIN747 in forum mel PIC BASIC Pro
    Last Post: - 18th October 2012, 22:23
  4. Replies: 36
    Last Post: - 14th March 2011, 18:38
  5. LCD Problem!
    By uaf5000 in forum mel PIC BASIC Pro
    Last Post: - 19th May 2010, 23:06
