Current Measuring
Results 1 to 6 of 6
    Dec 2012
    Türkiye
    Default Current Measuring
    Hello everyone ;
    I need a simple solution to measure the current of a DC motor of which current changes between 0A - 1A ... Can you suggest me such solutions ? DC motor works with 12V and its RPM is controlled through PWM ...
    OK
    Default Re: Current Measuring
    The ACS715 measures up to 20 amps of current and converts it into a 0-5 volt signal, 185 mV per amp. It can be buffered with a capacitor to smooth out the a/c element. It is only available as a surface mount SOIC, though:
    http://www.digikey.com/product-detai...1-1-ND/1955903
    I use them for one of my gizmos.
    Mike
    From another forum:
    Microchip has several application guides on their website regarding using the ADC; you should read them.
    Have a look at AN513 and ADN007 for some ideas.
    I remember seeing a design that changed current to voltage using discrete parts, then read that using a PIC.
    Can't remember where I saw that.
    Edit: http://www.electronics-lab.com/proje...008/index.html
    0-33V, 0-3A.
    Dec 2010
    It's called a resistor, Robert Teasing aside, you simply choose a value such that there is a volt drop you can measure across the shunt resistor that is still small enough to not impact your circuit when the maximum current is flowing.
    Unfortunately with a PWM it's more complicated to figure out what that voltage equivalence really is - first because it's AC, but worse it is a square wave and might be changing a bit fast for the PIC ADC can follow. I'd think along the lines of a shunt resistor with a differential amplifier (op-amp) sensing across it, that charges or discharges a capacitor through a resistor, which is then measured with the ADC. Choose values based on response time needed; fast enough to limit the time the answer is wrong, but slow enough the PIC can follow it. The voltage will be directly proportional to the average current after about 5 time constants.
    Feb 2011
    Many HBridge drivers have motor current sensing (0-5 V) pin outputs --
    ' Dual VNH5019 Motor Driver HBridge http://www.pololu.com/docs/0J49/all
    ' Dual MC33926 Motor Driver HBridge http://www.pololu.com/catalog/product/1213
    Dec 2012
    Türkiye
    Thanks guys .. I've taken care of the problem with ACS715- 05 ... It's got an output of 185 mV/A ... It took care of the problem with a tough kind of ADC reading technique ... Like 500 times of ADC readings for one cycle ... Because it is bloody sensitive ...
    Regards ..
  1. Measuring DC current
    By mitchf14 in forum mel PIC BASIC Pro
    Last Post: - 17th January 2009, 18:49
  2. Measuring Resistance
    By jhorsburgh in forum General
    Last Post: - 24th September 2008, 09:29
  3. Measuring voltage from a current transformer
    Last Post: - 5th May 2008, 21:19
  4. Measuring time
    By AugustoPedrone in forum mel PIC BASIC Pro
    Last Post: - 30th July 2007, 23:46
  5. measuring current from a photo diode
    By mischl in forum mel PIC BASIC Pro
    Last Post: - 13th November 2005, 14:42
