+ Reply to Thread
Results 1 to 17 of 17
    Default How to setup pbp3 with MPLABX?
    Could someone please point me in the right direction to some ACCURATE instructions on how to get the PBP3 compiler to be seen in MPLABX? I have googled for hours, and everything I find is 8.x, and none of it seems to remotely apply to X....
    Default Re: How to setup pbp3 with MPLABX?
    Dec 2014
    Good luck getting any sort of help. MElabs and Mecanique seem to be too busy with other projects to support their legacy products. I recently purchased PBP Pro 3.0 and MCSP full version and am disappointed to find that MCSP particularly provides ZERO support.
    Northeast
    Cyberdove, what are you doing to request assistance? I usually get prompt replies from emails, and Charles (at ME Labs) has shown generosity with his time on the phone. I have never attempted to utilize tech support from MCSP.
    Quote Originally Posted by Cyberdove View Post
    the question could be ...
    What's your problem ? Both are quite straightforward.
    moreover MCPSX gives you a straight link to the Melabs Forum ( Where Charles Leo himself can help you ... ) ... so you just have to hit your HELP tab !!!
    Northeast
    I'm getting hung up:
    "3) Mark PBP Tool Chain and PicBasic Language Syntax"
    PicBasic Language Syntax is not showing up as one of the options. Did find the PBP Tool Chain option.
    Those instructions are from a much older version of MPLABX. The Language Syntax plugin is no longer available.
    A number of features no longer work the same way (if they work at all). Last time I tried it source level debugging was just about useless.
    I agree , i'm heading back to mikro C for new projects . their latest update enables source level debugging for some of the newer chips ,finally!
    This is more entertaining than Free to Air TV
    Northeast
    So if I understand correctly, there is absolutely no advantage (debugging) to going through a massive ordeal to attempt to get PBP3 to work in the new MPLABX over the MicroStudio?!?
    Hmm, source level debugging seems a distant dream for PBP.
    But to be fair, the language syntax of PBP is much more straight forward than C so it is easier to debug and correct errors.
    Still, debugging is on top of my wish list.
    not if you include usercommands and asm code blocks .
    and that's the only thing that keeps pbp3 viable for me
    Dec 2014
    I used MCSP years ago and got prompt support directly from them. Now - nothing.
    wrong [again] its almost if nobody wants anyone to be able to use 8 bit pic chips any longer .
    the chips can be now compiled for and programmed but that's it , no icd support.
    pic16f1619 is a no go for icd
    It's not entirely clear, but you might need the AC244066 Emulation Extension Pak to debug the 16F1619.
    Only if you got MPLAB REAL ICE...
    Looking at it again I think you're right. I was looking in the datasheet and didn't see anything about debug support.
    According to mplabx 4 the 16F1619 should be supported by PK3 and ICD3.
    Which MPLABX in turn does not support PBP3...
    Back to square 1.
  1. Integrate PBP3 in MPLABX.
    By Ziko87 in forum PBP3
    Last Post: - 21st May 2013, 13:41
  2. PBP3 Long setup
    By iphillipsca in forum mel PIC BASIC Pro
    Last Post: - 30th October 2012, 20:03
  3. Can't get ISIS/Proteus VSM to work with PBP3 and MPLABX
    By chicowoodhill in forum mel PIC BASIC Pro
    Last Post: - 28th July 2012, 20:45
  4. PIC16F777 - setup
    By orjon1 in forum mel PIC BASIC Pro
    Last Post: - 2nd June 2011, 20:17
  5. ADCIN setup help need
    By dangill in forum mel PIC BASIC Pro
    Last Post: - 26th February 2008, 15:22
Members who have read this thread : 27
