Record, storage and compare analog signals
Results 1 to 17 of 17
    Apr 2008
    Default Record, storage and compare analog signals
    Hi, all, please I need help
    I need record analog signal (10Bit) to PIC with length 60us, storage as reference (red line) and compare with next one incoming (blue line). My question is, how to sampling and storage reference signal and compare those signals? I want to use PIC18F2455.
    Look Fig1Name:  fig1.jpg
    Thanks Kuba
    Default Re: Record, storage and compare analog signals
    Looking at the Data sheet of the chip 18F2455 and especially in the A/D Acquisition Requirements, it seems that you need a 2.45usec for every sample. Of course you need also a little time to transfer the AD value to an array and start AD again. Say for the sake of the discussion the the total time is 3usec.
    This leaves you with only 20 samples in the 60usec period.
    Is that OK with you?
    Apr 2008
    I think, 20 samples is enough.
    How can I obtain this 20 samples and storage as numbers for calculation?
    Thanks Kuba
    The assumption of 2.45us was based on the fact that Vdd is 5Volts and the source impedance less than 2.5Kohm.
    What will be the clock of the your controller?
    Apr 2008
    I will use osc. 20MHz
    Kuba
    Lets then suppose you have the analog input at AN0.
    ADCON0=%00000001    ' Channel 0, ADC on
    ADCON1=%00001110    ' AN0 as analog,rest as digital
    ADCON2=%10010101    ' Right justify result and Fosc/16
    analog_res_array    VAR WORD[40]
    counter             VAR BYTE
    start_array         VAR BYTE     ' first element of the array to store samples
    stop_array          VAR BYTE     ' last element of the array to store samples
    start_array=0:stop_array=19      ' first group of 20 samples
    gosub adc_routine
    start_array=20:stop_array=39     ' second group of 20 samples
    gosub adc_routine
    adc_routine:
        for counter=start_array to stop_array
            high adcon0.1
            while adcon0.1:wend
            analog_res_array[counter]=adresh*256+adresl
        next counter
    Now in the array you have 40 samples (two groups of 20) and you can compare them.
    Note that code is untested, but you get the idea.
    Apr 2008
    Thanks for your help.
    Kuba
    Apr 2008
    I have code for 10 Bit AD converter with array storage four samples.
    If I send results from array separately, I see all numbers of array results on LCD, (Example 1.)
    But If I send all results from array together, LCD show number 0. (Example 2.)
    My question is, what is wrong, how correct this code, how can I send all results from array to LCD?
    Kuba
    Example 1.
    Lcdout DEC array[0]," ", Dec array[1]," ", Dec array[2]," ", Dec array[3]
    Example 2.
    Lcdout DEC array[counter]
    This is my code:
    Define LCD_DREG PORTB
    Define LCD_DBIT 4
    Define LCD_RSREG PORTC
    Define LCD_RSBIT 4
    Define LCD_EREG PORTC
    Define LCD_EBIT 5
    ' Define ADCIN parameters
    Define ADC_SAMPLEUS 3 ' Set sampling time in uS
    TRISB = %00000000 ' Set PORTB to all output
    TRISC = %00000000 ' Set PORTC to all output
    ADCON1 = %10000010 ' Set PORTA analog and right justify result
    Pause 500 ' Wait .5 second
    array Var Word [4]
    counter VAR Byte
    Start_array VAR Byte
    Stop_array VAR Byte
    Start_array =0 : Stop_array = 3
    adc_runtime:
    for counter = Start_array to Stop_array
    ADCIN 0, array[counter] ' Read channel 0 to array[counter]
    next counter
    Pause 100 ' Wait .1 second
    Lcdout $fe, 1 ' Clear LCD
    Goto adc_runtime ' Do it forever
    Jun 2009
    Sc*nthorpe, UK
    Use example 1 as example 2 will only display array[4] or you could do something like this
    adc_runtime:
    Lcdout DEC array[counter]," "
    next counter
    Try it a see what happens
    You try to display only one array element and especially the array[4] element that does not exist. You have defined from 0 to 3 (4 elements) and the variable counter after the end of the For-Next loop ends up with the value of 4.
    So you try to display an non-existence variable, that could have a random value.
    Steve has given you an example to display the variable within the loop and should work as you expect.
    Apr 2008
    Working, great
    Thanks EarlyBird2
    Kuba
    Apr 2008
    Hi loannis,
    I tried your metod, it does not work.
    Method of EarlyBird2 really works, Im surprise.
    Kuba
    Jun 2009
    Sc*nthorpe, UK
    Kuba,
    You are welcome.
    What method? I explained what Steve has given you as an example.
    Apr 2008
    Hi loannis,
    now I understand you explanation.
    Exist other method, how to send all array elements to LCD, after the completion loop, except my 1. Example?
    Kuba
    Sorry for my english
    With arrays the STR modifier is used to send without FOR-NEXT loop.
    But in your case you need a second modifier and up to this moment this is not supported.
    This does work: STR my_array\16 ' sends the first 16 bytes of the array my_array
    This does not work: STR DEC my_array\16
    But I wish sometime in the next update/upgrade it will be supported!
    Apr 2008
    Thanks loannis for your answer
    Kuba
  1. how to record sound into eeprom
    By Mus.me in forum mel PIC BASIC Pro
    Last Post: - 20th November 2009, 22:16
  2. How to read analog signals?
    By thm ov3rkill in forum mel PIC BASIC Pro
    Last Post: - 8th March 2009, 06:00
  3. Using a PIC to record voice
    By weirdjim in forum mel PIC BASIC Pro
    Last Post: - 24th December 2007, 21:21
  4. Replies: 6
    Last Post: - 20th August 2006, 23:00
  5. The best way to record non-volatile data
    By johnson in forum General
    Last Post: - 19th July 2004, 10:03
