external clock input to RC0/T1CKI on pic18f252 troubles
Results 1 to 4 of 4
    Mar 2014
    Default external clock input to RC0/T1CKI on pic18f252 troubles
    hi all
    been having some ups and down with a frequency counter. i had it working taking an audio signal through a NPN pre-amp and then to a 741 config as a comparator. the op amp was powered by +/-4.5v from a 9v cell tapped with a gnu at the middle. this created a nice square wave output. when connected to the pic my code counted the frequency perfectly, using TMR1 as an asynchronous counter and TMR0 to create a 1 second delay in which i count the number of tmr1 overflows.
    basically, i wanted to make the fixtures a little more permanent and so replaced the 9v cell with a 7660S CPAZ to give my -ve rail and then integrated a dual op amp, config as a 20 gain amp and comparator. result - a nice -5v/+5v swing square wave. however the pic now does not recognise this as an external clock. and i scoped it before when it was connected. i can see a square wave at the RC0/T1CKI pin on the pic, the correct frequency, but it only runs from -0.6v to +4v now. i don't know if this is the problem. is there a certain format the ext clk is required to be for the input? I've even tried a ttl from a function generator but it doesn't like that either.
    i checked code in the xc8 sim and worked every time.
    below is code extract:
    #include <pic18f252.h>
    #include <stdio.h>
    #include <stdlib.h>
    #include <xc.h>
    #include <htc.h>
    #include <delays.h>
    #include <math.h>
    #pragma config WDT = OFF
    unsigned int tmr1_ovflow;
    unsignedint freq;
    /*****************************Timer1 overflow count**********************************/
    void high_ISR (void)
    PIR1bits.TMR1IF = 0; //checks for Timer 1 rollover interrupt flag
    tmr1_ovflow=tmr1_ovflow + 1;
    /*****************************1 Second Delay**********************************/
    void delay (void)
    int i;
    i=0;
    do{
    T0CON = 0x87;
    // configure Timer 0 - select 16-bit mode,
    // internal clock source, enable 1:256 prescaler
    TMR0H = 0xA4;
    // load Timer 0 registers for 1 second delay
    TMR0L = 0x6D;
    INTCONbits.TMR0IF = 0;
    // make sure interrupt flag is reset
    while(!(INTCONbits.TMR0IF)); // wait until TMR0 rolls over
    i=i+1;
    }while(i<1);
    /*****************************Frequency Counter**********************************/
    void freqcount ()
    tmr1_ovflow = 0;
    freq = 0;
    TMR1H =0;// force Timer1 to count from 0
    TMR1L =0;
    PIR1bits.TMR1IF = 0;// clear Timer1 interrupt flag
    RCONbits.IPEN = 1;// enable priority interrupt scheme
    IPR1bits.TMR1IP = 1;// set Timer1 interrupt to high priority
    PIE1bits.TMR1IE = 1;// enable Timer1 roll-over interrupt
    T1CON = 0x87;// enable Timer1 with external clock, prescaler 1
    INTCON = 0xC0;// enable global and peripheral interrupts
    delay ();// start one-second delay and wait for interrupts
    INTCONbits.GIE = 0;// disable global interrupt
    freq = tmr1_ovflow * 65536 + TMR1H * 256 + TMR1L;
    // get the total Timer 1 count, i.e. calculate the frequency
    any ideas? its driving me up the wall haha!
    Default Re: external clock input to RC0/T1CKI on pic18f252 troubles
    This forum isn't really about discussing issues with compilers/languages other than PBP but a quick glance at your code shows
    T0CON = 0x87;
    The value of 0x87 seems to correspond with the comment which probably isn't what you want to do if using an external clock source connected to T0CKI.
    Mar 2014
    oh is it i didn't know the forum wasn't a generic one.
    oh thats fine its timer1 that is configured for ext clk. timer 0 still needs internal to give my 1 second delay. thanks for the reply though!
    Argh, I read the thread title several times and STILL T0CKI.... Must have made a mixup with RC0....
    Sorry about the confusion, good luck!
  1. Shiftin with external Clock howto ?
    By RFsolution in forum mel PIC BASIC Pro
    Last Post: - 21st September 2011, 16:45
  2. Shiftin with external Clock howto ?
    Last Post: - 27th February 2011, 09:40
  3. Data Out From External Clock
    By Quin in forum Serial
    Last Post: - 25th October 2008, 09:11
  4. external clock / internal clock
    By grounded in forum General
    Last Post: - 31st May 2008, 17:44
  5. External clock
    By Firegod in forum mel PIC BASIC Pro
    Last Post: - 17th March 2007, 00:53
