+ Reply to Thread
Page 2 of 4 FirstFirst 1234 LastLast
Results 41 to 80 of 125
  1. #41
    Jan 2012
    Grid EN19MV
    Default Re: How do I discern Maidenhead Locator from GPS lat long info.
    I'm trying to recreate it in a spreadsheet to see what values the variables should have at that point.
    But finding time to look at it is difficult right now.
    Don't know if THIS PDF will help - but I was using this in my early attempts to get this figured out. It describes how to discern the 7th and 8th digits
    -Stephen Hawking
  2. #42
    Dec 2011
    IO93ok
    Hi Darrel,
    Many thanks for this.
    I wondered about the variables. I did have a try at following the code through in the hope I could perhaps work it out.
    As a test. I changed the string to 8 characters and tried adding MH(7) ="0" + AINT/10 and MH(8)="0"+ AINT/10 in Lat and Lon routines after MH4 and MH5 as a trial to see what was displayed.
    I think the routine at 8 chrs is referencing the midi digit routine chrs as it displays custom chrs on the LCD in those positions.
    I tried repeating MH4 and 5 but renumbered, so that should give 'IO93okok' as the 7th and 8th position but again it accessed custom chrs. A puzzle for me anyway.
    Rob.
    The moment after you press "Post" is the moment you actually see the typso
  3. #43
    Dec 2011
    IO93ok
    Hi Andy,
    That's the doc I took the info post from
    Regarding working satellites, I downloaded a Maidenhead Locator App for my Android phone. Gives lots of other info too.
    Able to get 10 digit locator from the inbuilt gps on the phone.
    Rob.
  4. #44
    Quote Originally Posted by tasmod View Post
    Not sure if the fifth pair is also a 10x10 subdivision, since the PDF only does 8 characters.
    But continuing the logic to the next pair, I'm getting that your 10 digit locator is ... IO93ok03ed
    Does your Android App give a similar location?
    Nope, it's 24x24.
    And your 10-digit locator is IO93ok03kh.
    This version is quite different from the last one.
    I've tossed out the stuff that came from the pearl script and did it like the PDF mentioned above.
    It has to use the 32-bit floating point routines now. 24-bits just didn't have enough resolution for the sub-squares.
    While this version is more efficient, it's also harder to understand, sorry.
    ; Filename    : Maidenhead_10.pbp
    ; Compiler    : PICBASIC PRO Compiler
    ; Target PIC  : 16F1937, but will work with most any chip
    ; Oscillator  : ANY
    ; Keywords    : Maidenhead, Locator, GPS, Amateure Radio
    ; Description : PICBASIC PRO program to convert between
    ;             : GPS Sexagesimal to Maidenhead coordinate systems
                           ; Must use the 32-bit Floating Point routines
    INCLUDE "FP2032.bas"   ; 32-bit Floating Point for 14-bit cores with RAM at $20
    DEFINE HSER_SPBRG 25  ' 19200 Baud @ 32MHz, 0.16%
    HSEROUT [27,"[2J","Maidenhead Locator",13,10]
    HSEROUT ["16F1937, 32-bit Floating Point",13,10,13,10]
    MH        VAR BYTE[10]
    LonStr    VAR BYTE[12]
    LatStr    VAR BYTE[12]
    LonDeg    VAR BYTE
    LonMin    VAR BYTE
    LonMinDec VAR BYTE
    LonDir    VAR BYTE
    LatDeg    VAR BYTE
    LatMin    VAR BYTE
    LatMinDec VAR BYTE
    LatDir    VAR BYTE
    Idx       VAR BYTE
    AddChar   VAR BYTE
    Divisor   VAR BYTE[4]
    AARG_SAVE VAR BYTE[4]
    MOVE?CF32  macro C, F       ; put a Floating Point Constant in an FP variable
        MOVE?CW  (C & 0xFFFF), F
        MOVE?CW  (C >> 16), F + 2
    MOVE?FF32  macro Fin, Fout  ; Copy an FP var to another FP var
        MOVE?WW  Fin, Fout
        MOVE?WW  Fin + 2, Fout + 2
    ARRAYWRITE LonStr,["00049.77,W",0]  ;  0 47.70'  ;<-- enter GPS location here
    ARRAYWRITE LatStr,["5325.83,N",0]   ; 53 26.20'
    HSEROUT ["LonStr  = ", STR LonStr,13,10]          ; display manual input
    HSEROUT ["LatStr  = ", STR LatStr,13,10]
    ;----[parse strings as if they came from a GPS]---------------------------------
    ARRAYREAD LonStr,[DEC3 LonDeg, DEC2 LonMin, Dec LonMinDec, LonDir]
    ARRAYREAD LatStr,[DEC2 LatDeg, DEC2 LatMin, Dec LatMinDec, LatDir]
    ;----[convert Longitude Sexagesimal to Decimal Degrees]-------------------------
    Aint = LonMinDec : GOSUB ItoFA    ; decimal portion of Minutes
    Bint = 100 : GOSUB ItoFB          ; divided by 100
    GOSUB fpdiv
    Bint = LonMin : GOSUB ItoFB       ; add whole portion of Minutes
    GOSUB fpadd
    Bint = 60 : GOSUB ItoFB           ; divide by 60
    GOSUB fpdiv
    Bint = LonDeg : GOSUB ItoFB       ; add degrees
    GOSUB fpadd
    IF LonDir = "W" THEN              ; if west of Prime Meridian
        @ MOVE?FF32 AARGB2, BARGB2    ; copy Float AARG to BARG
        Aint = 0    : GOSUB ItoFA     ; subtract from 0 to negate
        GOSUB fpsub
    Bint = 180  : GOSUB ItoFB         ; add 180
    GOSUB fpadd
    ;----[Have Longitude in AARG as Float]------------------------------------------
    FOR Idx = 0 TO 8 STEP 2
        SELECT CASE Idx
          CASE 0 : AddChar = "A"
                   @ MOVE?CF32 0x83200000, _Divisor   ; 20
          CASE 2 : AddChar = "0"
                   @ MOVE?CF32 0x80000000, _Divisor   ; 2
          CASE 4 : AddChar = "a"
                   @ MOVE?CF32 0x7B2AAAAB, _Divisor   ; 0.0833333
          CASE 6 : AddChar = "0"
                   @ MOVE?CF32 0x78088889, _Divisor   ; 0.00833333
          CASE 8 : AddChar = "a"
                   @ MOVE?CF32 0x73360B61, _Divisor   ; 0.000347222
        END SELECT
        GOSUB MH_Digit
    NEXT Idx
    ;----[convert Latitude Sexagesimal to Decimal Degrees]--------------------------
    Aint = LatMinDec : GOSUB ItoFA    ; decimal portion of Minutes
    GOSUB fpdiv
    Bint = LatMin : GOSUB ItoFB       ; add whole portion of Minutes
    GOSUB fpadd
    GOSUB fpdiv
    Bint = LatDeg : GOSUB ItoFB       ; add degrees
    GOSUB fpadd
    IF LatDir = "S" THEN              ; if south of equator
        GOSUB fpsub
    Bint = 90  : GOSUB ItoFB          ; add 90
    GOSUB fpadd
    ;----[Have Latitude  in AARG as Float]------------------------------------------
    FOR Idx = 1 TO 9 STEP 2
        SELECT CASE Idx
          CASE 1 : AddChar = "A"
                   @ MOVE?CF32 0x82200000, _Divisor   ; 10
          CASE 3 : AddChar = "0"
                   @ MOVE?CF32 0x7F000000, _Divisor   ; 1
          CASE 5 : AddChar = "a"
                   @ MOVE?CF32 0x7A2AAAAB, _Divisor   ; 0.0416666
          CASE 7 : AddChar = "0"
                   @ MOVE?CF32 0x770882F1, _Divisor   ; 0.00416666
          CASE 9 : AddChar = "a"
                   @ MOVE?CF32 0x723603EC, _Divisor   ; 0.000173583
        END SELECT
        GOSUB MH_Digit
    NEXT Idx
    ;----[Maidenhead conversion complete]-------------------------------------------
    HSEROUT ["LOC ",STR MH\10,13,10,13,10] ; show final result
    Main:                             ; blink an LED when done
        HIGH PORTA.0
        PAUSE 500
        LOW PORTA.0
        PAUSE 500
    GOTO Main
    ;----[Calculate one digit of the Maidenhead Locator]----------------------------
    MH_Digit:
        @ MOVE?FF32 _Divisor, BARGB2      ; put divisor in BARG
        GOSUB fpdiv                       ; do the divide
        @ MOVE?FF32 AARGB2, _AARG_SAVE    ; save AARG for modulus
        GOSUB FtoIA                       ; get integer
        MH(Idx) = Aint + AddChar          ; The Character
        Bint = Aint                       ; copy integer result to BARG
        GOSUB ItoFB                       ; convert it to float
        @ MOVE?FF32 _AARG_SAVE, AARGB2    ; restore previous AARG
        GOSUB fpsub                       ; subtract integer
        @ MOVE?FF32 _Divisor, BARGB2      ; multiply times original divisor
        GOSUB fpmul                       ; AARG now contains the remainder
    The output of the program looks like this ...
    Maidenhead Locator
    LonStr  = 00049.77,W
    LatStr  = 5325.83,N
    LOC IO93ok03kh
    BTW: Those are really small squares (in red).
    Dec 2011
    IO93ok
    Wow, wow and WOW. What can I say? That is your usual brilliant stuff.
    I use DT_Ints, Big Digits, ADC Average and now your Locator code.
    Many many thanks. I tried but just can't follow it through as you expected
    I never realised just how small the final location square was. That's half my plot. Reason is, the gps antenna is on the window ledge on a back room!
    If I move to front room it would change !! Stunning.
    Now I need to re-organise the screen layout. I didn't think I would run out of room on a 20x4 display.
    I will post a picture of the completed item, it's boxed but not quite complete.
    Once again, many thanks.
    Rob.
  7. #47
    Dec 2011
    IO93ok
    Hmmm, I've transferred the code over into my program but I must have done something wrong as the locator is incorrect.
    I'm getting 10 and kd instead of 03 and kh which is correct at back of house. kg at front of house
    I will check it over again.
    Here's a screenshot of the Android app.
    Rob.
  8. #48
    These are some of the results I get ...
        LAT           LON       Maidenhead
    Deg Min.Min   Deg Min.Min   1234567890
     53 25.83'    -0 49.77'   IO93ok03kh  Back Yard
     53 25.82'    -0 49.77'   IO93ok03kg  Front Yard
     53 25.04'    -0 49.29'   IO93ok10kd  Wrong Place
    Since the main difference is the decimal portion of the Minutes, you might want to look at the values in the LonMinDec and LatMinDec variables.
    They should come from the latsecs and lonsecs variables you parsed from the GPS.
    Although, it's not seconds ... it's the decimal portion of the Minutes.
    Dec 2011
    IO93ok
    That was it Darrel. I had aliased the wrong variables to save renaming.
    Gives correct code at 'back yard' 90% of time. Why 90% ? Well, it faces North and the number of satellites it will lock to for a precise fix varies quite a lot. This is due to antenna position and satellite positions. If I lift antenna slightly, it will improve.
    The gps gives a slightly changing fix as it recalculates. According to manual it outputs a 'Fix' in sentence when it has aquired 4 satellites
    At the South facing 'front yard' it is 100%, as it will fix 12 satellites, the limit of this gps module.
    I'm going to try inputting an initialisation string at start up. This will turn off all sentences except the RMC sentence. This should stop the occasional random catchup 'seconds' jump as another sentence is output. There are four other defaults, GGA , GSV , GSA and ZCH. The latter is the unit channel status.
    It appears that they are output randomly according to PC gps serial monitoring program, whilst RMC is per second.
    Rob.
  10. #50
    Does your GPS module put out more decimal places in the LAT/LON fields?
    Since the edge of the square runs through the middle of the house, whether you're at the front window or rear window inside, you're always near the edge.
    I imagine that if you were standing in the middle of your back yard, the reading would be more consistent.
    One or two more decimals may improve the resolution considerably.
    With only two decimals, a difference of .01 is a whole square.
        LAT           LON       Maidenhead
    It depends on whether your GPS gives enough data or not.
    When recording NMEA sentences from my Android, it gives 6 decimals.
    Dec 2011
    IO93ok
    Again you come to my aid Darrel.
    I had limited the output by declaring the lat/lon secs as byte. Changed them to word and it becomes much more stable now. Datasheet says the decimal part is of variable length not fixed, so word should cover it.
    I have also improved the start time to fix by finally fitting the Supercap to the gps module, something I should have done a while ago. This gives 48hr backup.
    Don't groan but I now have another problem I'm going to look at. The time is now 2 seconds slow. Probably all the code plus the NMEA being slow too.
    I'm looking at adding 2 secs then trigger display using DT_Ints on the next PPS pulse rise time. Feasible ??
    Rob.
  12. #52
    Dec 2011
    IO93ok
    Hmmm no. I screwed that up somehow.
    I realised it was saving DEC2 in the gps string so it would not be any different, so I changed it to DEC4 for now.
    I changed the DEC2 in display line to DEC4 and I was getting 4 decimal places on Latitude displayed but Long went to all 0's. So locator was IO84 something.
    Will spend some time on it.
    Rob.
  13. #53
    Dec 2011
    IO93ok
    Now this is interesting.
    If I mess with the size of any 'secs' variables it screws everything up. I can get Lat to 4 decimal places but not Long, it still goes to zero.
    Right now I put the code back to original and got IO93ok03kg as the locator. I'm going to reduce this to the 4 pair for display just now, only to get more on screen.
    I put my phone with the app running next to the gps antenna.
    The phone was showing a fix to 16 sats and gave IO93ok03lh with 53 25.8266 and 0 49.7704 as the co-ordinates.
    For mine. When I had the 4 decimal places shown on the display it showed 25.8246
    Rob.
  14. #54
    Dec 2011
    IO93ok
    It's between DEC4 in gps string and Aint in locator code.
    I can get the display right but not the locator using DEC4 in the gps string and DIGs in the display LCDOUT.
    I can get the locator right but not the position display if I just use latsecs as the variable in the gps input string.
    Not knowing how Aint works I'm stumped now.
    EDIT:
    Just walked the property with the phone. Wow, those squares are small. I get LG, LH, KG, KH and guess where the crossover is, yes, right around the room where the unit is. I think I'll stick to DEC2 for now
    Rob.
  15. #55
    With DEC4 change it to this for the Longitude ...
    Bint = 10000 : GOSUB ItoFB        ; divided by 10000
    GOSUB fpdiv
    GOSUB fpadd
    GOSUB fpdiv
    GOSUB fpadd
        GOSUB fpsub
    GOSUB fpadd
    And do the same thing with the Latitude.
    Dec 2011
    IO93ok
    That was it.
    Using "DEC4 latsecs/lonsecs" in the gps string and changing to Word size variables uses the 4 decimal places.
    Interestingly using battery power for the unit, I got exactly the same reading as the phone app moving the unit around.
    Thanks Darrel.
    I'm now looking at making the time display more accurate to the second epoch using DT_Ints
    Rob.
  17. #57
    Yahooo!
    If you are going to add interrupts, you'll need to make some changes.
    SERIN2's baudrate is software timed, and it doesn't like being interrupted.
    You'll have to move the serial lines over to RC6 and RC7 (the USART pins).
    Then use HSERIN instead of SERIN2.
    HSERIN is not affected by the interrupts.
    Dec 2011
    IO93ok
    Hmm, guess which pins are not catered for on pcb ?
    Redesign methinks.
    Rob.
  19. #59
    Dec 2011
    IO93ok
    Redesign completed. New board made where all pins are accessible and pads for option of pullups/down resistors.
    I have altered the software to use HSERIN and HSEROUT and all is well at the moment. It is working just fine.
    Using the code in previous post:
    My aim was to display the clock triggered by the gps pps signal. I tried DT_Ints and added the @ INT_RETURN where the original Clock sub had RETURN. This caused the display to only update the very first square with random characters per second with PPS signal.
    This is the setup naming Clock. I wasn't sure where to put the INT_Enable . I tried just after this ASM and at beginning of Clock routine with same result.
            INT_Handler    INT_INT,        _Clock,      PBP,  yes
    @   INT_ENABLE   INT_INT     ; enable external (INT) interrupts
    Rob.
  20. #60
    Dec 2011
    IO93ok
    This is the full code with the Ints active but it's just updating first character.
    ;        GPS NMEA Display code with GPSDO monitoring
    ; 			         PIC16F876A
    ;                                   __________
    ;                          !MCLR |1        28| RB7------D7
    ;     PLL Volt--AN0---RA0 |2        27| RB6------D6
    ;    adc spare--AN1---RA1 |3        26| RB5------D5
    ;    adc spare--AN2---RA2 |4        25| RB4------D4
    ;    adc spare--AN3---RA3 |5        24| RB3------LCD E
    ;                  spare---RA4 |6        23| RB2------LCD RS
    ;    adc spare--AN4---RA5 |7        22| RB1------spare
    ;                Ground---Vss |8        21| RB0------PPS In
    ;                OSC1---XTAL |9        20| VDD------ +5 V
    ;                OSC2---XTAL |10       19| Vss------Ground
    ;                  spare---RC0 |11       18| RC7------H-RX -- GPS NMEA In
    ;                  spare---RC1 |12       17| RC6------H-TX -- GPS Command Out
    ;                  spare---RC2 |13       16| RC5------spare
    ;               Pbutton---RC3 |14       15| RC4------spare
    ' Program to display returned value of a GPS NMEA string on RA4
    ' LCD in 4-BIT mode PIC16F876a controller 4Mhz clock Fuse PWRT BODEN
    'Typical GPS sentence string: $GPRMC,192144.62,A,5041.6058,N,00412.6124,E,0.45,3 57.74,081205,,*0B
    'The default sentences are continuously output.
    'Now suppose I want to read only one particular sentence I need to program the GPS to do that.
    'The input message  ILOG controls which sentences are logged.
    '$PRWIILOG,???,V,,,\r,\n
    'Inputting this sentence, disables all the sentences.
    'Now suppose we want only RMC sentence then input the following sentence serially to gps
    '$PRWIILOG,RMC,A,,,,\r\n
    'The \r() and \n () are sentence terminator in NMEA
    'V disables that particular sentence while A enables that sentence.
    @  __config  _HS_OSC & _WDT_ON & _PWRTE_ON & _BODEN_OFF & _LVP_OFF & _CPD_OFF & _WRT_OFF & _DEBUG_OFF & _CP_OFF
    ; Place a copy of these variables in your Main program for digit characters--
    ;--   The compiler will tell you which lines to un-comment                --
    ;--   Do Not un-comment these lines                                       --
    ;wsave   VAR BYTE    $20     SYSTEM      ' location for W if in bank0
    wsave   VAR BYTE    $70     SYSTEM       ' alternate save location for W
    'wsave1  VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    'wsave2  VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    ;wsave3  VAR BYTE    $1A0    SYSTEM      ' location for W if in bank3
    INCLUDE "Average.bas"     ; DT's 16-bit Analog Module averaging values
    INCLUDE "DT_INTS-14.bas"  ; Base Interrupt System
    INCLUDE "ReEnterPBP.bas"
    Define LCD_DREG PORTB     ' Port for LCD Data
    Define LCD_DBIT 4         ' Set LCD starting data bit
    Define LCD_RSREG PORTB    ' Port for RegisterSelect (RS) bit
    Define LCD_RSBIT 2        ' Port Pin for RS bit  (pin9)
    Define LCD_EREG PORTB     ' Port for Enable (E) bit
    Define LCD_EBIT 3         ' Port Pin for E bit    (pin7)
    Define LCB_BITS 4         ' Using 4-bit bus
    Define LCD_COMMANDUS 1500 ' Command Delay (uS)
    define LCD_DATAUS 50      ' Data Delay (uS)
    DEFINE ADC_BITS 10        ' Setup ADC
    DEFINE ADC_SAMPLEUS 5
    DEFINE ADC_CLOCK 1
    DEFINE HSER_BAUD 4800
    OPTION_REG.6 = 1            ' Interrupt rising edge
    OPTION_REG.7 = 0            ' Enable Pull-Up's
    PPS VAR PORTB.0
    Pbutton VAR PORTC.3
    ' Initialise ADC
    ADCON1 = %10000100 ' Set PORTA analog and RIGHT justify result
    ADCON0 = %01000001 ' Configure and turn on A/D Module channel 0 Fosc 8
    'Declare variables
    volt VAR WORD     ' scaled value real part
    voltd1 VAR WORD   ' scaled value first decimal place
    voltd2 VAR WORD   ' scaled value second decimal place
    'Allocate Variables for GPS: ####################
    TimeOut CON 2000
    hh VAR BYTE             'hours
    mm VAR BYTE             'minutes
    ss VAR BYTE             'seconds
    knots VAR WORD          'speed in knots (units)
    knotsten VAR BYTE       'speed in knots (tens)
    course VAR WORD         'heading
    latdeg VAR BYTE         'degrees latitude
    latmin VAR BYTE         'minutes latitude
    latsecs VAR WORD        'seconds latitude
    NS VAR BYTE             'north or south
    londeg VAR BYTE         'degrees longitude
    lonmin VAR BYTE         'minutes longitude
    lonsecs VAR WORD        'seconds longtitude
    EW VAR BYTE             'east or west
    d VAR BYTE              'day
    m VAR BYTE              'month
    y VAR BYTE              'year
    butt VAR BYTE           'pushbutton variable
    marker VAR BYTE         'toggle marker
    marker2 VAR BYTE        'UTC or BST
    MH     VAR BYTE[10]     'locator variables##########
    Idx       VAR BYTE                                 ;
    AddChar   VAR BYTE                                 ;
    Divisor   VAR BYTE[4]                              ;
    AARG_SAVE VAR BYTE[4]   '----------------###########
    nPos  var byte          ' digit variables
    nDig  var byte          '--------------------
    Idx2 VAR BYTE           ' Month variables
    X VAR BYTE                                  ;
    Char VAR WORD           '--------------------
    scroll VAR BYTE
    fix VAR BYTE            'GPS fix - Yes="A"  No="V"
    butt = 0                ;clear button variable
    marker = 0              ;set marker to zero for full info display at start
    marker2 = 0             ;set UTC
    PAUSE 50
    LCDOut $fe,$80,"    GPS Decoder     "   ; scrolling opening display
    LCDOut $FE,$c0," G8VLQ  March 2014  "
    Pause 2000
       for scroll = 1 to 20                 ' FOR..NEXT loop so message scrolls off the LCD to the left
                lcdout $fe,24               ' Scrolls display one position to the left
                pause 100                   ' Pause 150 ms
       next scroll                          ' do loop again till max count
                pause 1500                   ' Pause 1000ms
                lcdout $fe,1                ' Clears LCD
    Initialisation:    ;Leaving GPRMC as only sentence output
    HSEROUT ["$PRWIILOG,GGA,V,,,",13,10]
    PAUSE 100
    HSEROUT ["$PRWIILOG,GSA,V,,,",13,10]
    PAUSE 100
    HSEROUT ["$PRWIILOG,GSV,V,,,",13,10]
    PAUSE 100
    HSEROUT ["$PRWIILOG,ZCH,V,,,",13,10]
    PAUSE 100
    GPS: 'read GPS  #############################################################################################
    HSerIn Timeout,Clock,[wait("$GPRMC"),wait(","),DEC2 hh,DEC2 mm,DEC2 ss,wait(","),fix,wait(","),DEC2 _
    latdeg,DEC2 latmin,wait("."),DEC4 latsecs,wait(","),NS,wait(","),DEC3 londeg,DEC2 lonmin,wait("."),DEC4 lonsecs,_
    wait(","),EW,wait(","),knots,wait("."),DEC2 knotsten,wait(","),DEC3 course,wait(","),DEC2 d,DEC2 m,DEC2 y]
    IF marker = 1 THEN BigClock     ; keeps big clock running if value is 1
    IF marker2 = 1 THEN Plusone
    BUTTON Pbutton,0,100,0,butt,1,BigClockClear      ;button press to jump to fullscreen big clock
    GOSUB PLL         ;get the A/D value of pll control voltage
    GOSUB ShowMonth   ;show month as letters
    GOSUB Locator     ;maidenhead locator
    ;GOSUB BST
    GOSUB Clock       ;medium digit clock
    goto GPS          ; ##########################################################################################
    ;         MAIDENHEAD CONVERSION   --  Darrel Taylor
    Locator:
        MOVE?WW  Fin, Fout
    Aint = lonsecs : GOSUB ItoFA    ; decimal portion of Minutes
    GOSUB fpdiv
    GOSUB fpadd
    GOSUB fpdiv
    GOSUB fpadd
    IF EW = "W" THEN              ; if west of Prime Meridian
        GOSUB fpsub
    GOSUB fpadd
        SELECT CASE Idx
        END SELECT
        GOSUB MH_Digit
    NEXT Idx
    Aint = latsecs : GOSUB ItoFA    ; decimal portion of Minutes
    GOSUB fpdiv
    GOSUB fpadd
    GOSUB fpdiv
    GOSUB fpadd
    IF NS = "S" THEN              ; if south of equator
        GOSUB fpsub
    GOSUB fpadd
        SELECT CASE Idx
        END SELECT
        GOSUB MH_Digit
    NEXT Idx
    MH_Digit:
    ;         Month routine
    ShowMonth:
        LCDOut $fe,$80+9,DEC2 d," "
        GOSUB Month
        LCDOut " ","20",DEC2 y
    Month:
        Idx2 = (m - 1) * 3
        FOR X = Idx2 TO Idx2 + 2
            LOOKUP X,["JanFebMarAprMayJunJulAugSepOctNovDec"],Char
            LCDOUT Char
        NEXT X
    ;                British Summer Time
    BST:
     IF m = 3 AND d = 30 THEN Plusone
     IF m >= 03 and m <= 10 THEN Plusone
    Plusone:
      IF m = 10 and d = 26 then UTC
      IF m >=10 and m <3 then UTC
      hh = hh + 1
      IF hh = 25 THEN hh = 0
      marker2 = 1
    UTC:
      marker2 = 0
    ;                PLL control voltage read result via Average routine
    PLL:             ' Measure GPSDO PLL control voltage for TCXO  - Approx 1.65v for lock
    ADCON0.2 = 1     ' Start conversion
    NotDone:
    pause 1
    IF ADCON0.2 = 1 Then NotDone
    value =((ADRESH * 256)+(ADRESL))
    gosub Average
    ' Calculate Voltage to 2 decimal places
    volt = value * 5/1024
    voltd1 = ( value * 5//1024) * 10/1024
    voltd2 = ((value *5 //1024) * 10//1024) * 10/1024
    lock:
    IF (volt=1) AND (voltd1 =6) AND (voltd2 =<9) THEN
    LCDOUT $FE,$C0+9,"Lock  "
    ClockClear:             ;Returning from Big Digit Clock, need to clear screen
    LCDOut $FE, 1           ;Clear Screen
    marker = 0              ;set marker to full info display
    GOTO GPS
    Clock:                   ;Display medium character time clock
    'Set up the digits (http://www.darreltaylor.com/files/CustChar.htm)
    LCDOUT  $FE,$40,$03,$03,$03,$03,$03,$03,$03,$03  ' Cust Char #0
    LCDOUT  $FE,$48,$0E,$1F,$1B,$1B,$1B,$1B,$1B,$1B  ' Cust Char #1
    LCDOUT  $FE,$50,$1F,$1F,$18,$18,$18,$18,$1F,$1F  ' Cust Char #2
    LCDOUT  $FE,$58,$03,$03,$03,$03,$03,$03,$1F,$1F  ' Cust Char #3
    LCDOUT  $FE,$60,$0E,$1F,$1B,$1B,$1B,$1B,$1F,$0E  ' Cust Char #4
    LCDOUT  $FE,$68,$1B,$1B,$1B,$1B,$1B,$1B,$1F,$0E  ' Cust Char #5
    LCDOUT  $FE,$70,$1F,$1F,$03,$03,$03,$03,$1F,$1F  ' Cust Char #6
    LCDOUT  $FE,$78,$1E,$1F,$03,$03,$03,$03,$03,$03  ' Cust Char #7
        nDig=ss dig 0 : nPos=7 : gosub displaydigit
        nDig=ss dig 1 : nPos=6 : gosub displaydigit
          npos=5 : gosub colon
        ndig=mm dig 0 : npos=4 : gosub displaydigit
        ndig=mm dig 1 : npos=3 : gosub displaydigit
          npos=2 : gosub colon
        ndig=hh dig 0 : npos=1 : gosub displaydigit
        ndig=hh dig 1 : npos=0 : gosub displaydigit
    LCDOUT $FE,$C0+9,"False Data "            ;displays
    IF fix = "A" THEN
    LCDOUT $FE,$C0+9,"Fix  ",#volt, ".", # voltd1,# voltd2,"v"            ;overwrites No Data
    GOSUB lock                                ;checks for pll lock if Fix valid
    LCDOUT $fe,$94," G8VLQ  ",STR MH\10," " ;STR is 10 digit Maidenhead Locator
    LCDOut $fe,$d4,DEC2 latdeg,$DF,DEC2 latmin,"'",DEC latsecs DIG 3,DEC latsecs DIG 2,_
    NS,"  ",DEC2 londeg,$DF,DEC2 lonmin,"'",DEC lonsecs DIG 3,DEC lonsecs DIG 2,EW
    ;$DF is degree symbol, some LCD displays have it in different location
    @ INT_RETURN
    ;RETURN
    displaydigit:
    if ndig=0 then gosub zero
    if ndig=1 then gosub one
    if ndig=2 then gosub two
    if ndig=3 then gosub three
    if ndig=4 then gosub four
    if ndig=5 then gosub five
    if ndig=6 then gosub six
    if ndig=7 then gosub seven
    if ndig=8 then gosub eight
    if ndig=9 then gosub nine
    Zero:
    	LCDOUT $FE,$80+nPos,1
    	LCDOUT $FE,$C0+nPos,5
    One:
    	LCDOUT $FE,$80+nPos,0
    	LCDOUT $FE,$C0+nPos,0
    Two:
    	LCDOUT $FE,$80+nPos,7
    	LCDOUT $FE,$C0+nPos,2
    Three:
    	LCDOUT $FE,$80+nPos,6
    	LCDOUT $FE,$C0+nPos,3
    Four:
    	LCDOUT $FE,$80+nPos,5
    Five:
    	LCDOUT $FE,$80+nPos,2
    Six:
    Seven:
    Eight:
    	LCDOUT $FE,$80+nPos,4
    Nine:
    colon:
          lcdout $fe,$80+nPos,$A5
          lcdout $FE,$C0+nPos,$A5
    BigClockClear:
    LCDOut $FE, 1           ;Clear original full data screen
    marker = 1              ;set marker for fullscreen clock loop
    'THICK DIGITS
    LCDOUT  $FE,$40,$07,$07,$07,$07,$07,$07,$07,$07  ' Cust Char #0
    LCDOUT  $FE,$48,$1C,$1C,$1C,$1C,$1C,$1C,$1C,$1C  ' Cust Char #1
    LCDOUT  $FE,$50,$0F,$1F,$1F,$1E,$1C,$1C,$1C,$1C  ' Cust Char #2
    LCDOUT  $FE,$58,$1E,$1F,$1F,$0F,$07,$07,$07,$07  ' Cust Char #3
    LCDOUT  $FE,$60,$1C,$1C,$1C,$1C,$1E,$1F,$1F,$0F  ' Cust Char #4
    LCDOUT  $FE,$68,$07,$07,$07,$07,$0F,$1F,$1F,$1E  ' Cust Char #5
    LCDOUT  $FE,$70,$1F,$1F,$1F,$00,$00,$00,$00,$00  ' Cust Char #6
    LCDOUT  $FE,$78,$00,$00,$00,$00,$00,$1F,$1F,$1F  ' Cust Char #7
    GPS2:
    HSerIn Timeout,Clock,[wait("$GPRMC"),wait(","),DEC2 hh,DEC2 mm,DEC2 ss]
    BUTTON Pbutton,0,100,0,butt,1,ClockClear     ;button press to change back to full info display
    BigClock:               ;Display Big Digit fullscreen clock
        nDig=ss dig 0 : nPos=17 : gosub displaydigit1
        nDig=ss dig 1 : nPos=14 : gosub displaydigit1
                        npos=13 : gosub colon
        ndig=mm dig 0 : npos=10 : gosub displaydigit1
        ndig=mm dig 1 : npos=7 : gosub displaydigit1
                        npos=6 : gosub colon1
        ndig=hh dig 0 : npos=3 : gosub displaydigit1
        ndig=hh dig 1 : npos=0 : gosub displaydigit1
    GOTO GPS2
    displaydigit1:
    if ndig=0 then gosub Zero1
    if ndig=1 then gosub One1
    if ndig=2 then gosub Two1
    if ndig=3 then gosub Three1
    if ndig=4 then gosub Four1
    if ndig=5 then gosub Five1
    if ndig=6 then gosub Six1
    if ndig=7 then gosub Seven1
    if ndig=8 then gosub Eight1
    if ndig=9 then gosub Nine1
    Zero1:
        LCDOUT $FE,$81+nPos,3     ;note added 1 to position for right side of character
        LCDOUT $FE,$C0+nPos,1
        LCDOUT $FE,$C1+nPos,0     ;note added 1
        LCDOUT $FE,$94+nPos,1
        LCDOUT $FE,$95+nPos,0     ;note added 1
        LCDOUT $FE,$D4+nPos,4
        LCDOUT $FE,$D5+nPos,5	;note added 1
    One1:
          LCDOUT $FE,$80+nPos," "
    	LCDOUT $FE,$81+nPos,0
    	LCDOUT $FE,$C0+nPos," "
    	LCDOUT $FE,$94+nPos," "
    	LCDOUT $FE,$D4+nPos," "
    	LCDOUT $FE,$D5+nPos,0
    Two1:
    	LCDOUT $FE,$C0+nPos,7
    	LCDOUT $FE,$C1+nPos,5
    	LCDOUT $FE,$95+nPos," "
    	LCDOUT $FE,$D5+nPos,7
    Three1:
    	LCDOUT $FE,$95+nPos,3
    	LCDOUT $FE,$D4+nPos,7
    Four1:
    	LCDOUT $FE,$81+nPos," "
    	LCDOUT $FE,$C0+nPos,4
    	LCDOUT $FE,$C1+nPos,7
    	LCDOUT $FE,$95+nPos,1
    	LCDOUT $FE,$D5+nPos,1
    Five1:
    	LCDOUT $FE,$81+nPos,6
    	LCDOUT $FE,$C1+nPos," "
    	LCDOUT $FE,$94+nPos,6
    Six1:
    	LCDOUT $FE,$94+nPos,2
    Seven1:
    Eight1:
    Nine1:
    colon1:
          lcdout $fe,$C0+nPos,$A5
          lcdout $FE,$94+nPos,$A5
    Rob.
  21. #61
    Dec 2011
    IO93ok
    Hi Darrel,
    Hmmm, looking at the various timings I don't see how this can be done.
    The NMEA string is output at the same point, the epoch of the PPS pulse, so the code is executing the string read when it also needs to start to display the 'advanced' time.
    As I see it at the moment, the code reads the gps string, then parses it, saving each piece to the assigned variable and runs the subroutines before initiating the display.
    As a test, I added two seconds to the seconds variable. Then comparing against a radio time signal it was almost the same. I say almost as it is not quite two seconds out in code execution.
    I suppose I could add a suitable pause value and bring it inline but I would have to test the offset, if any, over a period of operation. This assumes code execution always takes the same time to execute.
    Any ideas would be welcome.
    Rob.
  22. #62
    Hi Rob,
    I haven't been following this thread in detail so I apolgize if I'm suggesting something that's already been covered or isn't doable for whatever reason.
    Looking at the code you posted, and as you mentioned, you spend quite a bit of time in the ISR. I have two questions/suggestions.
    A) Why do you need to reload the custom characters each time? Wouldn't it be better to load them once at startup?
    B) Can't you simply set a flag in the ISR (ie UpdateDisplay = 1) which you then poll in the main loop? If the flag is set you update the display and reset the flag.
    Obviously there must be enough clock cycles between interrupts to do whatever needs to be done - no matter "where" it's being done (inside or out of the ISR).
    Doing (B) above you basically can't have the HSERIN statement within the main loop as it will "block" the processor for up to TimeOut ms (2000 in the code as posted). What you'd need to do is either introduce UART interrupt or simply poll the UART RX interrupt flag within the mainloop (provided the mainloop is "tight" enough to not overflow the UART receive buffer (2 bytes).
    Yes and no. It doesn't read, then parses it. HSERIN is parsing the string as the bytes comes in, one by one. If it didn't do that you'd have to have a recieve buffer as big as the complete NMEA string. But again, the code in your ISR takes considerable amount of time and it's quite possible that if an interrupt occurs in the middle of the HSERIN statment (quite possible) the ISR is stealing too much time so the the receive buffer (2 bytes) overruns and HSERIN "gets lost".
    At 4800 baud each byte is a about 2ms long so if your ISR takes more than 4ms to execute it will most definitely cause issues for the HSERIN. Seeing all those LCDOUT statements within the ISR and the subroutines it calls makes me think your ISR runs way up into the tens of ms.
  23. #63
    Dec 2011
    IO93ok
    Hi Henrik,
    Quite a bit to digest there. Good food for thought. Thanks.
    I missed the fact that the custom characters for the medium digits was constantly loading in the loop. I've moved that to the beginning now out of the loop, it is loaded at start up.
    The BigDigit clock did only load it's characters once then entered it's own loop, so that's taken care of.
    The main problem as I see it is that the gps string start occurs at the same time as the 'seconds' rise point. In the gps module the start of the rise of the PPS also triggers the NMEA string output. In other words the seconds epoch occurs for both. I don't know if it's possible to receive the string and trigger the display code at the same time. I was just trying to get to a more accurate time.
    The time is very close now anyway allowing for code run timing. I could add a small pause to bring it closer I suppose.
    Rob.
  24. #64
    Hi Rob,
    More thoughts.....
    Since, if I'm not mistaken, the time is parsed from the NMEA string using the PPS signal to initiate a display update will update the display with the time information from the last received string which is basically one second "old". I think that the best you can do really is to simply grab and parse the string and then update the display.
    If you're receiving the full 82byte NMEA string that will take ~170ms, add the actual display update code to that - you'll be a couple of hundred ms off.
    Dec 2011
    IO93ok
    Hi Henrik,
    I've been doing some more reading regarding the NMEA string from the Rockwell datasheets. (19 pages in one 142 in other !)
    I've discovered two choice bits.
    (1.) The string is always after the event, so is 1 second late as you said.
    (2.) Standard laid down for time this way is up to +/- .9 seconds regardless of (1.) above.
    Rockwell do a binary protocol at 9600 baud which is 'message' driven. So you can actually poll for time separately with far more accuracy but it would require a complete code rewrite.
    I'm trying to keep code tight in the BigClock sub which only reads the h, m, s, part of string. This is at beginning of the string anyway. I update in reverse to display, s m h.
    At the moment I've added 2 seconds before display and with the other code changes, it's as near as I can see visually using the PPS LED. It is almost on the PPS event. That is near enough for me. Checking against MSF radio time signal using Spectrum Lab software, it's very close.
    Visually humans can discern a 250ms difference, so as I can hardly see any difference, it should be closer than 250ms diff.
    I could load the output into SpecLab to compare both signals I suppose. I may eventually do that anyway as I'm curious to what the code timing is.
    I have the frequency lock part spot on, so it would be nice to get the time part as well, but I don't think its possible.
    For my sins, in my other life I am an official timekeeper, timing to hundredths of a second. I can see '100ths differences there ok
    Amazing really how many times a day I see exactly the same time to the hundreth of a second, two competitors achieve.
    Another idea, but I suspect will gain nothing is :-
    Read string full time once at start up.
    Display
    loop:
    Then read only seconds.
    Increment software clock s m h
    update display
    loop
    String read would be very quick. Approx 20ms.
    EDIT:
    Just realised that at 20ms I would have read h m s anyway, so pseudo code above is pointless.
    Rob.
  26. #66
    Dear all,
    first of all i would like to congrats the work have been done in this post.
    I would also like to inform you once again that im not a programmer. So my knowledge at programming is really low.
    I try to setup as a hobby a gps and project the info to ulcd that i have many years at my small lab.
    Here is the code up to now:
    @ ERRORLEVEL -306 ; this command prevents the compiler to give you a notice of
                      ; crossing page boundary - make sure bits are set
    PORTB = 0
    input portb.0
    ; -----[ Variables ]-------
    PWRLED      var     PORTb.1   ; this shows that the initialization is finished
    LCD         var     PORTb.2   ; to LCD operation
    GPS_TX      var     PORTb.0   ; info from GPS
    GPS_RX      var     PORTb.4   ; COMMANDS TO GPS, this feature is not
    Testled     var     PORTb.5   ;ill try to use this when GPS module find signal
    pause 2000
    ' -----[ Variables ]-------------------------------------------------------
    '   $GPRMC,090045.000,A,3823.6645,N,02353.3600,E,0.02,195.80,170518,,,A*62
    '   $GNGGA,140405.000,3823.6010,N,02353.3054,E,1,9,0.88,0.8,M,35.9,M,,*40
    hh          var     byte    'hours
    mm          var     byte    'minutes
    ss          var     byte    'seconds
    sss         var     word    'milisecs
    degrees	    VAR     BYTE    'latitude/longitude degrees
    minutes	    VAR     BYTE    'latitude/Longitude minutes
    minutesD    VAR	    word    'latitude/LONGITUDE DECIMAL MINUTES
    dir         VAR     BYTE    ' direction (latitude: 0 = N, 1 = S / longitude: 0 = E, 1 = W)
    degrees2    VAR     BYTE    'latitude/longitude degrees
    minutes2    VAR	    BYTE    'latitude/Longitude minutes
    minutesD2   VAR	    word    'latitude/LONGITUDE DECIMAL MINUTES
    dir2        var     byte    ;direction (latitude: 0 = N, 1 = S / longitude: 0 = E, 1 = W)
    SatNo       VAR	    BYTE    'number of satellites connected
    knots       var     word    'speed over ground
    knots2      var     byte    'speed over ground
    course      var     word    'course
    course2     var     byte    'course
    day         var     byte    'day
    month       var     byte    'month
    year        var     byte    'year
    i           var     word
    GNRMC       var     word
    GNGGA       var     WORD
    FIX         var     word
    Modefix     var     byte
    horizon     var     byte
    precision   var     byte
    meter       var     byte
    METERS      var     byte
    Meters2     var     byte
    ' -----------------  [ Initialization ]----------------------
    serout2 LCD,32,[$55]      ' uOLED Initialize
    pause 2000
    serout2 lcd,32,[$56,$01]
    serout2 lcd,32,[$45]
    serout2 lcd,32,[$55]
    serout2 lcd,32,[$73,$00,$03,$11,$ff,$ff," Leonardo Bilalis",$00]
    pause 200
    serout2 lcd,32,[$73,$02,$06,$10,$ff,"     Copyright 2018",$00]
    pause 3000
    serout2 lcd,32,[$73,$02,$06,$10,$ff,$ff,"      GPS.........",$00]
    pause 200
    HIGH pwrled
    '--------------------   [MAIN] ------------------------------
    ;$GPRMC,090045.000,A,3823.6645,N,02353.3600,E,0.02,195.80,170518,,,A*62
    serin2 gps_tx,84,[wait("$GNRMC"),_                              ;we wait for $GNRMC
    wait(","),dec2 hh,dec2 mm,dec2 ss,wait("."),dec3 sss,_          ;we wait for 090045.000
    wait(","),fix,_                                                 ;we wait for A
    wait(","),dec2 degrees,dec2 minutes,wait("."),dec4 minutesd,_   ;we wait for 3823.6645
    wait(","),dir,_                                                 ;we wait for N
    wait(","),dec3 degrees2,dec2 minutes2,wait("."),dec4 minutesd2,_;we wait for 02353.3600
    wait(","),dir2,_                                                ;we wait for E
    wait(","),dec knots,wait("."),dec2 knots2,_                     ;we wait for 0.02
    wait(","),dec3 course,wait("."),_                               ;we wait for 195.80
    wait(","),dec2 day,dec2 month,dec2 year]                        ;we wait for 170518
    ;$GNGGA,140405.000,3823.6010,N,02353.3054,E,1,9,0.88,0.8,M,35.9,M,,*40
    serin2 gps_tx,84,[wait("$GNGGA"),_
    wait(","),dir,_
    wait(","),dir2,_
    wait(","),modefix,_
    wait(","),dec2 satno,_
    wait(","),dec3 horizon,dec precision,_
    wait(","),meter,dec2 METERS,dec Meters2]
    serout2 lcd,32,[$73,$03,$00,$00,$ff,$ff,"Protocol:",dec5 GNRMC,$00] ; THIS IS NOT WORKING
    pause 200
    serout2 lcd,32,[$73,$00,$02,$00,$ff,$ff,"Date:",dec2 day,dec2 month,dec2 year,$00] ; THIS IS NOT WORKING
    pause 200
    serout2 lcd,32,[$73,$00,$04,$00,$ff,$ff,"TIME: ",dec2 hh+3," :",dec2 mm," :",dec2 ss,$00]
    pause 200
    serout2 lcd,32,[$73,$00,$06,$00,$ff,$ff,"Satellites:",dec2 satno," ","Fixed:",fix,$00]
    pause 200
    serout2 lcd,32,[$73,$00,$08,$00,$ff,$ff,"Lat : ",dec2 degrees,dec2 minutes,".",dec4 minutesd," ",dir,$00]
    pause 200
    serout2 lcd,32,[$73,$00,$0A,$00,$ff,$ff,"Lon : ",dec3 degrees2,dec2 minutes2,".",dec4 minutesd2," ",dir2,$00]
    pause 200
    serout2 lcd,32,[$73,$00,$0C,$00,$ff,$ff,"GND SPEED : ",dec knots*1852/1000,".",dec2 knots2,$00]
    pause 200
    serout2 lcd,32,[$73,$00,$0E,$00,$ff,$ff,"Meters : ",dec2 METERS,dec Meters2,$00] ; THIS IS NOT WORKING
    pause 5000
    if fix = "V" then notfix
    notfix:
    serout2 lcd,32,[$73,$00,$03,$11,$ff,$ff,"   Waiting for GPS",$00]
    pause 200
    '-------------------- [ CLEAR ] -----------------------------
    Clearlcd:
    What i would like to do is to display:
    Protocol : GNRMC
    DATE :
    TIME :
    Satellites:
    LAT :
    LON :
    GND SPEED:
    METERS:
    I have the following problem.
    1. Cannot display the DATE. Something is wrong at my code and there is not proper display of the date.
    2. I have put a loop for display all the factors, because i need to clear the LCD every time something is change. So please could you help me understand how could i manage to display the factors and only change on the fly the ones really going like Time, LAT, LON, GND SPEED, SATs etc.
    3. The Protocol command is not working
    4. The speed is not working properly, i think i need to do better the conversion
    5. The meters are not displaying, there is a wrong value in there.
    6. I need to convert the measurements from the NMEA message LAT and LON to google numbers.
    Please check what i have done till now in order for me to understand what it is needed.
  27. #67
    I have updated a little bit the code so when there is a no data at portb.0 to have a notice.
    but still i need to fix the following. Is there any advise?
    '*  Author  : LEONARDO BILALIS                                  *
    '*  Notice  : Copyright (c) 2018 [LEONARDOS BILALIS]            *
    '*  Date    : 12/5/2018                                         *
    '*  Notes   : This is an GPS                with ulcd           *
    ;& __config _HS_OSC & _WDT_ON & _LVP_OFF & _CP_OFF
    Include "MODEDEFS.BAS"
    DEFINE OSC 8
    OSCCON=%01111000     '8 Mhz
    CMCON = 7            'turn comparators off
    ANSEL = 0            'All digital
    PORTB = 0            'make low all ports at B range
    input portb.0        'make input portb.0
    '                              [ PIC Variables ]                            /
    Testled     var     PORTb.5
    dots        var     byte
    dots=8
    countremain var     byte      ; we use a countremain to check the incoming from portb.0
    ' --------------------[ GPS Variables for NMEA sentenses ]---------------------/
    '   $GPRMC,090045.000,A,3823.6645,N,02353.3600,E,0.02,195.80,170518,,,A*62   /
    '   $GNGGA,140405.000,3823.6010,N,02353.3054,E,1,9,0.88,0.8,M,35.9,M,,*40   /
    hh          var     byte    'hours
    day         var     byte    'day
    year        var     byte    'year
    i           var     word
    GNRMC       var     word    'protocol
    GNGGA       var     WORD    'protocol
    FIX         var     word    'fix sat V/A
    Modefix     var     byte    'mode fix 1 or 2 or 3 depens
    horizon     var     byte
    precision   var     byte
    meter       var     byte
    METERS      var     byte
    Meters2     var     byte
    '                          [ LCD Initialization ]                         /
    pause 2000
    serout2 lcd,32,[$45]      ' clear the lcd
    serout2 lcd,32,[$45]      ' clesr the lcd
    pause 200
    pause 3000
    pause 200
    '     [ After the lcd initialization we power the Led at PIC ]        /
    HIGH pwrled
    '                         [MAIN Program]                           /
    ;gosub clearlcd
    serin2 gps_tx,84,[countremain]      ; we check what is coming from the port
    if countremain = 0 then lostcable   ; if nothing is coming the we check the cable
    ;gosub clearlcd
    '                    [ Example NMEA Sentense of GNRMC ]                       /
    ' [$GNRMC,090045.000,A,3823.6645,N,02353.3600,E,0.02,195.80,170518,,,A*62]   /
    '                     [ Example NMEA Sentense of GNGGA ]                     /
    ' [$GNGGA,140405.000,3823.6010,N,02353.3054,E,1,9,0.88,0.8,M,35.9,M,,*40    /
    wait(","),dir,_
    wait(","),dir2,_
    wait(","),modefix,_
    ' Here if the GPS module havent been fixed to any satellite will jump to notfix  /
    '                           [ Return from notfix ]                           /
    '                   [ We clear any character on the display ]               /
    gosub clearlcd
    ;serout2 lcd,32,[$45]
    ;pause 500
    ' here is where the code dispays the stored info from the NMEA sentenses  /
    ;serout2 lcd,32,[$73,$00,$0C,$00,$ff,$ff,"GND SPEED : ",(dec knots,".",dec2 knots2)*/1.852,$00]
    ;pause 200
    pause 3000
    serout2 lcd,32,[$45]  ' clears the LCD
    '                              [ SUB ROUTINES ]                              /
    notfix:     ' Still looking for fixed signal
    serout2 lcd,32,[$73,$03,$06,$10,$ff," Time:",dec2 hh+3," :",dec2 mm," :",dec2 ss,$00]
    serout2 lcd,32,[$73,$03,$08,$10,$ff,rep "."\dots,$00]
    pause 200
    goto main       'returns to main
    lostcable:
    serout2 lcd,32,[$73,$00,$03,$11,$ff,$ff,"   Connection lost",$00]
    serout2 lcd,32,[$73,$01,$06,$10,$ff,"   Please check cable",$00]
    pause 2000
    '                              [ CLEAR LCD ]                               /
    Clearlcd:
  28. #68
    first off , what has your post got to do with maidenhead ? why not start a new relevant post instead of confusing this one
    secondly posting figures as pictures makes life difficult for anyone inclined to assist
    in you google numbers query (which is really deg ,min, sec conversion to decimal degrees )
    how did you get 38 + 2/60 + 3.49/3600 = 38.034297
    my calculator says 38.0343027 ps (in 32 bit float result is 38.0343018, with 64 bit float 38.0343028)done on pic24f using xc16
    you will have fun trying to get math accurate to 10 significant digits on that chip [even 32 bit floats struggle]
    your best bet is nbit math
    the decimal portion can be :-
    mins *1000000/6 + sec *1000/36
    parsing the nmea sentences is well covered but you may be interested in this
    http://support.melabs.com/forum/picb...strtok-usercmd
    a strtok function for pbp
    parsing strings with spaghetti code will always by a shortcut to madness
  29. #69
    Hi richard,
    1) i did post in here because i was planning to do that conversion as well on next step. But i cant simply display the date, so my knowledge wont be able to do any further
    2) pictures i believe always help.
    3) you are right on the calculation 38.0343027. I did something wrong in there.
    4) if Parsing NMEA is ok then why Date is not displaying right? I will check once again what i have done on the code.
    5) i will check the link and the strtok. But i find easier the way i did it because i understand it.
    as i said im not a programmer. This code might be simple for you, but is too much for me. I try to do things stwp by step on this code. There are lots of bugs and mistakes which at the moment cant solve.
    i found a small mistake on the first parsing code. i have forgot a sentence which may cause the problem displaying date.
    Will keep you update.
  30. #70
    i though i found the mistake on the first code for parsing
    i did complete the sentense
    wait(","),dec3 course,wait("."),dec2 course2,_                  ;we wait for 195.80
    but still next line which is the date is not dispayed right.
  31. #71
    ok the date is displayed. But sometimes it looks like that missing the date code and displays 00/here a 2 digit number/00, then it comes back to the right date.
  32. #72
    this is how I would go about parsing nmea, for what you are doing there is little point in storing all the data just to display it
    only store what is needed for calculations or enhanced display.
    I would also read in the entire nmea sentence using $ ast the start marker and * as the end marker.
    when you have a complete sentence send it off for parsing if its the correct sentence type
    '*  Name    : NOKIA_DEMO.PBP                                     *
    '*  Author  : richard                                            *
    '*  Notice  :                                                    *
    '*  Date    : 16/5/2018                                          *
    '*  Version :  mssp1 version  with bigtxt                        *
    '*  Notes   :                                                    *
    '*          :FOR pic 16F1847@32MHZ           NOKIA               *
    #CONFIG ; 16FF1847.
            __config _CONFIG1, _FOSC_INTOSC & _WDTE_ON & _PWRTE_ON & _MCLRE_ON & _CP_OFF & _BOREN_OFF
            __config _CONFIG2, _PLLEN_OFF & _LVP_OFF
    define      OSC         32
    ; --- *** Oscillator  *** ---------------------------------------------------
    OSCCON = %11110000           ;32 MHz,
    ANSELb = 0
    ANSELA = 0
    TRISA=%10010000
    TRISB=%11101011
    ch var byte
    BUFF VAR BYTE [16]
     ;DEFINES FOR DISPLAY   use   font7x5_16.bas   or  font7x5_18.bas     for pic18
     #DEFINE PIC16 1
     #define use_mssp 1
     lcdheight con 5      ;  6 PAGES
     lcdwidth  con 83     ; 84 PIXELS WIDE
    ' LCD_CLK     var     LATB.4       ' SCK1     pin needs to be set as dig o/p
    ' LCD_DIN     var     LATB.2       ' SDO1     pin needs to be set as dig o/p
     LCD_RST     var     LATA.4
     LCD_DC      var     LATA.3
     LCD_CE      var     LATA.6
     LCD_LIGHT   var     LATA.0
    nmea var byte[80]
    h var byte
    m var byte
    s var byte
    Include "nokia_ds.INC"  ' bring it in
    include "font7x5_16.bas"
    @ #DEFINE   TOKEN_DESTROY 1
    include "strtok.pbpmod"
    '==========================    MAIN  Routine    ==============================
        gosub lcd_init
        LCDCLR
        ARRAYWRITE BUFF,["READY",0]
        LCDSTR  5,0,BUFF
        PAUSE 1000
        LCDCLR
    looper:
    'start=$ end=*
    arraywrite nmea,["GNRMC,090045.000,A,3823.6645,N,02353.3600,E,0.02,195.80,170518,,,A",0]
    ;STRLEN nmea
    strtok nmea,0,","
    LCDSTR  0,0,nmea    ;sentence type
    strtok nmea
    ARRAYREAD  nmea ,[SKIP (STRTOK_INX-STRTOK_LEN),dec2 h,dec2 m,dec2 s]
    arraywrite buff,[dec2 h,":",dec2 m,":",dec2 s,0]
    LCDSTR  36,0,BUFF
    strtok nmea ;fix
    strtok nmea ;fix
    arraywrite buff,["lon",0]
    LCDSTR  0,1,BUFF
    ARRAYREAD  nmea ,[SKIP (STRTOK_INX-STRTOK_LEN),str buff\16]
    LCDSTR 20,1,buff
    strtok nmea
    LCDSTR 77,1,buff
    strtok nmea
    arraywrite buff,["lt",0]
    LCDSTR  0,2,BUFF
    LCDSTR 13,2,buff
    strtok nmea
    LCDSTR 77,2,buff
    strtok nmea
    arraywrite buff,["speed",0]
    LCDSTR  0,3,BUFF
    LCDSTR 36,3,buff
    strtok nmea
    arraywrite buff,["hdg",0]
    LCDSTR  0,4,BUFF
    LCDSTR 36,4,buff
    strtok nmea
    arraywrite buff,[dec2 h,"/",dec2 m,"/",dec2 s,0]
    LCDSTR  36,5,BUFF
  33. #73
    and to emphasize the advantage of an algorithmic approach over spaghetti code
    '*  Notice  :                                                    *
    '*  Notes   :                                                    *
    #CONFIG ; 16FF1847.
    define      OSC         32
    ANSELb = 0
    ANSELA = 0
    TRISA=%10010000
    TRISB=%11101011
    ch var byte
    BUFF VAR BYTE [16]
     #DEFINE PIC16 1
     #define use_mssp 1
     LCD_RST     var     LATA.4
     LCD_DC      var     LATA.3
     LCD_CE      var     LATA.6
    nmea var byte[80]
    h var byte
    m var byte
    s var byte
        gosub lcd_init
        LCDCLR
        LCDSTR  5,0,BUFF
        PAUSE 1000
        LCDCLR
    looper:
        'start=$ end=*
        strtok nmea,0,","
        ARRAYREAD nmea, 5, GNGGA,[wait("GNRMC")]
        GOSUB SH_MSG
        GOSUB SH_TIME
        strtok nmea ;fix
        GOSUB SH_LON
        GOSUB SH_LAT
        LCDSTR  0,3,BUFF
        LCDSTR 36,3,buff
        strtok nmea
        LCDSTR  0,4,BUFF
        LCDSTR 36,4,buff
        strtok nmea
        LCDSTR  36,5,BUFF
        PAUSE 1000
    GNGGA:
        arraywrite nmea,["GNGGA,140405.000,3823.6010,N,02353.3054,E,1,9,0.88,0.8,M,35.9,M,,",0]
        strtok nmea,0,","
        ARRAYREAD nmea, 5, XXX,[wait("GNGGA")]
        GOSUB SH_MSG
        GOSUB SH_TIME
        GOSUB SH_LON
        GOSUB SH_LAT
        strtok nmea
        strtok nmea
        strtok nmea
        strtok nmea
        strtok nmea
        arraywrite buff,["M",0]
        LCDSTR  28,5,BUFF
        LCDSTR 0,5,buff
        PAUSE 1000
    GOTO LOOPER
    XXX:
        LCDCLR
        arraywrite buff,["Oops",0]
        LCDSTR  0,1,BUFF
    SH_MSG:
        strtok nmea
    SH_TIME:
        LCDSTR  36,0,BUFF
        strtok nmea
    SH_LON:
        LCDSTR  0,1,BUFF
        LCDSTR 20,1,buff
        strtok nmea
        LCDSTR 77,1,buff
        strtok nmea
    SH_LAT:
        LCDSTR  0,2,BUFF
        LCDSTR 13,2,buff
        strtok nmea
        LCDSTR 77,2,buff
        strtok nmea
  34. #74
    Hi richard,
    really appreciate your help. I will print out your post and code, because i need to understand it first.
    Im a person that i understand something when i make notes and then i test my notes to see if i got it. Maybe this seems a bit stupid to others, but for me at the end works.
    Thanks a lot once again.
    Yesterday night i figured out that i need to correct TIME 24 hour, as im located on South of Europe --> Greece and we are +3 from UTC. So if it is 22:00 at UTC the time on display is +3....and shows 25.
    Then i need to say also that as we are +3 from UTC, when the time at UTC is 21:00 here will be 00:00, so the code must also change the date. (at them moment DATE follows the UTC time)
    Up to now i know what i have done with the code, even if it is wrong and even if there are lots of bugs. I'm happy at least i understand what i have done.
    Hopefully the following days i will have good news.
  35. #75
    this is what i get up to now on the display. But is not stable.
    Date is loosing data sometimes and presents zeros.
    My code refresh the display in order to get newer update on time, Sats, coordinates. Because i havent found the way to have always on the data and just refresh the digits need, for example the seconds.
    i keep working on it.
  36. #76
    i'm not surprised , given that :-
    not all nmea fields are filled in for every message
    not all nmea fields are fixed length
    I can't think of a more difficult way to approach this task than what you are trying to do.
    I can't think of a more difficult to debug approach for this task than what you are trying to do
    here is a snap of mine hooked to actual data, it has no trouble keeping up with the 4 or 5 messages
    per second that the gps spits out
    managed to snap the pic as the message type was updated so it a bit vague as to what its type is/was
    and the lat/lon are bogus who would trust the internet these days
    Last edited by richard; - 23rd May 2018 at 08:38. Reason: ps the solder on pin8 looks a bit dodgy
  37. #77
    Im from mobile so i will Post a line of the code for the following question when i will be on computer.
    I read the Data from the GPS, especially for the time and date.....
    Serin2.....
    Then i display the needed info......
    Serout2......
    What is the command to use inside the Serout2 in order to jump to a LABEL and Correct the UTC?
    It will be useful if i understand the command inside the Serout2 that give me the access to jump to a LABEL.
    One more question. I see most of You are using the HSERIN2, HSEROUT2,
    And You Richard on your code are using the arrayread arraywrite.
    I need to check the manual and see what is the difference between those.
  38. #78
    ok i'm stack.
    i place my code up to now. I dont want anyone to write a code for me, i just want from you to give me direction to solve my following problem.
    I know i have many mistakes and maybe i aproach the code in a wrong way, in a difficult direction.
    So one of my problems i would like to solve, is to give the right time, in 24H.
    I have in mind that i need to use interrupts.
    Is there any solution at the moment to use the SEROUT2 command
    serout2  lcd,32,[$73,$00,$04,$00,$FF,$E0,"  TIME: ",dec2 hh+3," :",dec2 mm," :",dec2 ss,$00]
    and jump at a label ???
    Plusthree:
      hh = hh + 3
    I would like first to solve time issue, even if i have to refresh/clear the display.....then my next problem to solve is to keep the data on the screen and replace only the numbers or characters needed to be change.
    Following is the code up to now.
    '*  Notice  : Copyright (c) 2017 [LEONARDOS BILALIS]            *
    '*  Date    : 24/5/2018                                         *
    '*  Notes   : This is a GPS                          *
    @ __config _CONFIG1, _HS_OSC & _WDT_OFF & _LVP_OFF & _CP_OFF
    DEFINE OSC 8
    '                           [ ULCD 1'44 4D System ]                          /
    ' "o" degree character is manual created for degree value
    Testled     var     PORTb.5
    dots        var     byte
    dots = 22
    Timeout     con     2000
    hh          var     byte    'hours
    day         var     byte    'day
    year        var     byte    'year
    i           var     word
    horizon     var     byte
    precision   var     byte
    meter       var     byte
    METERS      var     byte
    Meters2     var     byte
    marker2     var     byte    'UTC OR GRT (GREEK TIME)
    pause 2000
    pause 200
    pause 3000
    pause 200
    HIGH pwrled
    '----------------------sent a centence to gps------------------------
    ;serout gps_rx,84,[$PMTK_103*30]
    '                         [MAIN Program]                           /
    ;gosub clearlcd
    ;gosub clearlcd
    wait(","),dec2 hh,dec2 mm,dec2 ss,wait("."),dec3 sss,_          ;we wait for 090045.000 which is the time when we got the info
    wait(","),dec1 knots,wait("."),dec2 knots2,_                    ;we wait for 0.02
    serin2 gps_tx,84,[wait("$GNGGA"),_                              ;we wait for GNGGA
    wait(","),dec2 hh,dec2 mm,dec2 ss,wait("."),dec3 sss,_          ;we wait for 140405.000 which is the time when we got info
    wait(","),dec2 degrees,dec2 minutes,wait("."),dec4 minutesd,_   ;we wait for 3823.6010 longitude
    wait(","),dir,_                                                 ;we wait for the N/S
    wait(","),dec3 degrees2,dec2 minutes2,wait("."),dec4 minutesd2,_;we wait for 02353.3054 latitude
    wait(","),dir2,_                                                ;we wait for E/W
    wait(","),modefix,_                                             ;we wait for modefix 1,2 or 3 check gps manual for NMEA
    wait(","),dec2 satno,_                                          ;we wait for the number of fixed satellites, this is impoetant info
    wait(","),dec3 horizon,dec precision,_                          ;we wait for horizon
    wait(","),meter,dec2 METERS,dec Meters2]                        ;we wait for the meters
    gosub clearlcd
    ;pause 500
    serout2 lcd,32,[$73,$03,$00,$00,$FF,$FF,"Protocol:","NMEA",$00]
    serout2 lcd,32,[$73,$01,$02,$01,$07,$E0,"Date:",dec2 day,"/",dec2 month,"/",dec2 year,$00]
    serout2 lcd,32,[$73,$00,$07,$00,$FF,$FF," Satellites",$00]
    serout2 lcd,32,[$73,$03,$09,$11,$07,$FF,dec2 satno,$00]
    serout2 lcd,32,[$73,$00,$07,$00,$FF,$FF,"               Fixed",$00]
    serout2 lcd,32,[$73,$0D,$09,$11,$07,$FF,fix,$00]
    serout2 lcd,32,[$73,$00,$0B,$00,$ff,$ff,"Lat : ",dec2 degrees,"*",dec2 minutes,"'",dec4 minutesd," ",dir,$00]
    serout2 lcd,32,[$73,$00,$0D,$00,$ff,$ff,"Lon : ",dec3 degrees2,"*",dec2 minutes2,"'",dec4 minutesd2," ",dir2,$00]
    ;pause 200
    ;serout2 lcd,32,[$73,$00,$0E,$00,$ff,$ff,"Meters : ",dec2 METERS,dec Meters2,$00]
    pause 5000
    serout2 lcd,32,[$73,$00,$08,$10,$ff,rep "." \22,$00]
    pause 200
    lostcable:
    pause 2000
    '                      GREEK TIME and Correcrion                         /
    ' at the moment this is not connected to any part of the code
    Plusthree:
      hh = hh + 3
    '                              [ CLEAR LCD ]                               /
    Clearlcd:
  39. #79
    I have found that inline math for lcdout cmd on a pic16 turns to crap, serout2 may have the same issues
    you probably need to do the math first then print result
    i would do it this way
    hh=hh+3 ;utc+3
    hh=hh//24 ;REALLY SHOULD ADD A DAY TO DATE TOO IF day changes
    serout2 lcd,32,[$73,$00,$04,$00,$FF,$E0," TIME: ",dec2 hh," :",dec2 mm," :",dec2 ss,$00]
  40. #80
    Hi Richard,
    Thanks for the reply. I will try that.
  1. LAT replaces PORT command?
    By markscotford in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2011, 16:37
  2. Need Info for PBP?
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 30th January 2009, 07:44
  3. Replies: 1
    Last Post: - 27th July 2008, 06:14
  4. dmx info.
    By oscar in forum mel PIC BASIC Pro
    Last Post: - 8th May 2005, 11:54
Members who have read this thread : 18
