water quantity measuring
Results 1 to 4 of 4
    Mar 2014
    Default water quantity measuring
    Dear all
    Can any one show me how to measure water automatically in a bottle
    I want to fill 500 ml in a bottle automatically only 1 press
    Thank in advancei
    Default Re: water quantity measuring
    RathaMsc
    Medical products engineering makes use of dispensing precision volumes.
    Try Goggle.
    Norm
    Bombay, India
    If you know the rate of flow (known pressure into a tube with known orifice size), it is easy to fill exactly 500ml by just timing how long the water should flow through such a tube. A simple solenoid should be sufficient to do that.
    May 2008
    Italy
    ... Or you can use a load cell and measure the weight via ADC.
    A home made dynamometer can be easily built with a spring and a switch.
    Cheers
    Al.
  1. Help with water speed please
    By Ramius in forum mel PIC BASIC Pro
    Last Post: - 28th December 2013, 03:07
  2. Water sealed LEDs
    By NickMu in forum Off Topic
    Last Post: - 25th January 2013, 17:55
  3. water flow meter..
    By ecca in forum mel PIC BASIC Pro
    Last Post: - 27th May 2010, 11:11
  4. Electric water valve
    By Christopher4187 in forum Off Topic
    Last Post: - 6th April 2008, 22:41
  5. Replies: 1
    Last Post: - 20th October 2007, 08:55
