'[HD44780] Controller received data whist busy' error while simulating
Results 1 to 3 of 3
    Default '[HD44780] Controller received data whist busy' error while simulating
    I am getting '[HD44780] Controller received data whist busy' error while simulating in proteus. Is there any delay I should consider, if then when and how much? Thanks
    code:
    Gosub clear lcd
    ' other calculations
    LCDOUT $FE,$80,"P>",DEC P1,".",DEC P2,DEC P3,"  ","CURRENT"
    LCDOUT $FE,$C0,"I>",DEC I1,".",DEC I2,DEC I3,"  ","TEM>",DEC S1,DEC S2,".",DEC S3
    LCDOUT $FE,$90,"D>",DEC D1,".",DEC D2,DEC D3 ;," ", DEC DEL
    LCDOUT $FE,$D0,"SET TEMP>",DEC T1,DEC T2,".",DEC T3
    clear_lcd:
    LCDOUT $FE,$01,$02
    ___________________
    WHY things get boring when they work just fine?
    Sep 2010
    Las Vegas, NV
    Default Re: '[HD44780] Controller received data whist busy' error while simulating
    Well the most obvious thing is your calling a sub that doesn't exist.
    Second would be better if you showed all your code as it's not obvious where the snippet shown fits.
    Just sayin'.
    According to the data sheet most instructions take 3 cycles except "Clear display" which takes 165. Suggest you explicitly declare the defines related to LCD operation and specifically LCD_COMMANDUS and LCD_DATAUS. Play with these values till Proteus is happy or turn off the warning if it works in your real world config.
    George
  1. Replies: 2
    Last Post: - 15th December 2012, 02:19
  2. display received data
    By NURULHAIZA in forum mel PIC BASIC Pro
    Last Post: - 12th May 2010, 07:03
  3. 4 or 8 bit LCD data bus (HD44780)
    By sumkrnboy in forum General
    Last Post: - 10th May 2008, 22:05
  4. DS18B20 Busy Flag
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 6th November 2006, 14:21
