Conditional compile
Results 1 to 3 of 3
    Sep 2009
    Default Conditional compile
    I'm trying to create include file. I need way to create conditional compile based on whether variable is defined or not in main file.
    Something like this:
        #IFNDEF TmpB
            TmpB VAR BYTE
        #ENDIF
    If variable is all ready defined, it won't compile just show error:Bad defined value
    If variable isn't defined then I got syntax error.
    #IFDEF Counter2
         Counter2=Counter2+1
    #ENDIF
    For this, if variable isn't define, it's ok, but if is defined then I get Bad defined value.
    Is there way to do that?
    Default Re: Conditional compile
    I might be wrong but I don't think you can do that.
    The #IFNDEF Tmp2 will check if you've previoulsy not done #DEFINE Tmp2, where Tmp2 in this case a compile-time constant Tmp2 (not a PBP constant OR PBP variable).
    So, the only way to do it is to also define "something" in the main file, at the same time as you declare your Tmp2 variable and then check that "something" - not ideal but I think (though I'd like to be wrong) it's the only way.
    Tmp2 VAR BYTE
    #DEFINE VarCreated
    #IFNDEF VarCreated
      Tmp2 VAR BYTE
    #ENDIF
    Again, I hope I'm wrong because I can see what you're trying to do could be useful.
    Sep 2009
    Thanks.
    I know that I could use define for each var, but then I need lot of them and probably it would be messy. Especially if I forget to put one or two define
    That is last option...
    If conditional compile depend on variables, there is almost no way to overlook some of option's.
  1. Conditional compilation
    By ro37bis in forum mel PIC BASIC Pro
    Last Post: - 10th July 2011, 23:02
  2. Conditional default config's
    By cncmachineguy in forum PBP Wish List
    Last Post: - 8th May 2011, 19:47
  3. help with PIC16F628 conditional program
    By joseph in forum mel PIC BASIC Pro
    Last Post: - 5th July 2010, 13:54
  4. Conditional Defines?
    By Kamikaze47 in forum mel PIC BASIC Pro
    Last Post: - 21st June 2010, 22:08
  5. Conditional Compilation
    By milestag in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2006, 20:29
