Having trouble using PIC as SPI driver for Hittite PLL
Results 1 to 3 of 3
    Aug 2009
    Default Having trouble using PIC as SPI driver for Hittite PLL
    I'm working on a project where I'm using a PIC18F14K50 to drive a Hittite HMC704LP4E frequency synthesizer via SPI in HMC Mode. I'm trying to make sense of the Hittite documentation. Am I understanding it correctly that I DON'T send whole bytes to the Hittite chip, just strings of bits (in non-multiples of 8)? I don't have an eval board to work with, and I'm just the "code guy." Does anyone else have experience working with these?
    Default Re: Having trouble using PIC as SPI driver for Hittite PLL
    I don't have any experience with these chips but I briefly looked at the datasheet. Indeed, the HMC mode does look "strange".
    If you're using the bitbanged routines, ie SHIFTOUT/SHIFTIN then I don't think there shold be any problems shifting out/in any number of bits. However if you're using the MSSP module then HMC mode doesn't seem to be a good fit.
    Is there a specific reason for selecting HMC mode? It seems easy enough to just select Open mode instead, in which case a transaction is 32 bits (24 + 5 + 3), if I'm reading the datasheet correctly. That mode looks a lot easier "to do" than HMC mode.
    Aug 2009
    Hm... you might be right. I completely over looked that. Let's see if it works!
  1. Need Help on info for spi lcd driver board purchase
    By wdmagic in forum mel PIC BASIC Pro
    Last Post: - 30th April 2013, 16:48
  2. Control a Radio PLL with a PIC
    By RayL113 in forum General
    Last Post: - 14th March 2012, 18:40
  3. Replies: 1
    Last Post: - 12th November 2011, 20:05
  4. SPI on a pic without hardware SPI?
    By modifyit in forum mel PIC BASIC Pro
    Last Post: - 26th April 2006, 14:29
  5. Trouble with PIC 18F2220
    By cpayne in forum mel PIC BASIC Pro
    Last Post: - 19th August 2005, 14:17
