Using PBP3 Gold on Low Pin Count USB Dev Kit (PIC18F14k50). I'm using the vanilla HID code with minor changes to PID/MFR/Device Name.
I followed the code from here: http://msdn.microsoft.com/en-us/libr...=vs.85%29.aspx
My PBP main code looks like this: (Nothing exciting, you've all seen this.)
' * Auto generated EasyHID file. PBP 2.60 and above          *
include "ConfigBits.inc"
' include the HID descriptor
include	"DESCUSBProject.bas"
DEFINE OSC 48
DEFINE LOADER_USED 1
USBBufferSizeMax   con 32  ' maximum buffer size
USBBufferSizeTX    con 32  ' input
USBBufferSizeRX    con 32  ' output
' the USB buffer...
USBBuffer        Var Byte[USBBufferSizeMax]
USBBufferCount   Var Byte
' * main program loop - remember, you must keep the USB      *
' * connection alive with a call to USBService every couple  *
' * of milliseconds or so...                                 *
usbinit ' initialise USB...
ProgramStart:
   gosub DoUSBIn
   gosub DoUSBOut
   goto ProgramStart
' * receive data from the USB bus                            *
DoUSBIn:
   USBBufferCount = USBBufferSizeRX              ' RX buffer size
   USBService                                    ' keep connection alive
   USBIn 1, USBBuffer, USBBufferCount, DoUSBIn   ' read data, if available
' * wait for USB interface to attach                         *
DoUSBOut:
   USBBufferCount = USBBufferSizeTX              ' TX buffer size
   USBOut 1, USBBuffer, USBBufferCount, DoUSBOut ' if bus available, transmit data
My WinUSB code looks like this:
#include "pch.h"
#include "USBUtils.h"
LONG __cdecl
_tmain(
	LONG     Argc,
	LPTSTR * Argv
Routine description:
	Sample program that communicates with a USB device using WinUSB
	DEVICE_DATA           deviceData;
	HRESULT               hr;
	USB_DEVICE_DESCRIPTOR deviceDesc;
	BOOL                  bResult;
	BOOL                  noDevice;
	ULONG                 lengthReceived;
	UNREFERENCED_PARAMETER(Argc);
	UNREFERENCED_PARAMETER(Argv);
	//Press any key to continue to allow debugger attaching
	system("pause");
	// Find a device connected to the system that has WinUSB installed using our
	// INF
	hr = OpenDevice(&deviceData, &noDevice);
	if (FAILED(hr)) {
		if (noDevice) {
			printf(_T("Device not connected or driver not installed\n"));
		} else {
			printf(_T("Failed looking for device, HRESULT 0x%x\n"), hr);
		return 0;
	// Get device descriptor
	bResult = WinUsb_GetDescriptor(deviceData.WinusbHandle,
								   USB_DEVICE_DESCRIPTOR_TYPE,
								   0,
								   0,
								   (PBYTE) &deviceDesc,
								   sizeof(deviceDesc),
								   &lengthReceived);
	if (FALSE == bResult || lengthReceived != sizeof(deviceDesc)) {
		printf(_T("Error among LastError %d or lengthReceived %d\n"),
			   FALSE == bResult ? GetLastError() : 0,
			   lengthReceived);
		CloseDevice(&deviceData);
		return 0;
	// Print a few parts of the device descriptor
	printf(_T("Device found: VID_%04X&PID_%04X; bcdUsb %04X\n"),
		   deviceDesc.idVendor,
		   deviceDesc.idProduct,
		   deviceDesc.bcdUSB);
	//Insert Actual code here.
	UCHAR DeviceSpeed;
	bResult = GetUSBDeviceSpeed(deviceData.WinusbHandle, &DeviceSpeed);
	if (bResult == FALSE){
		printf("Something broke in GetUSBDeviceSpeed.\n");
		return(EXIT_FAILURE);
	PIPE_ID pipeUSB;
	bResult = QueryDeviceEndpoints(deviceData.WinusbHandle, &pipeUSB);
		printf("Something broke in QueryDeviceEndpoints.\n");
	ULONG cbSize;
	UCHAR szBuffer[] = "Hello World";
	cbSize = (ULONG)strlen((char*)szBuffer);
	ULONG cbSent;
	printf("Writing to Bulk Endpoint.\n");
	bResult = WinUsb_WritePipe(deviceData.WinusbHandle, pipeUSB.PipeOutId, szBuffer, cbSize, &cbSent, 0);
	//bResult = WriteToBulkEndpoint(deviceData.WinusbHandle, &pipeUSB.PipeOutId, &cbSize);
		printf("Something broke in WriteToBulkEndpoint.\n");
		printf(_T("Error among LastError %d\n"),GetLastError());
	else{
		printf("Wrote %d bytes to device.\n", cbSent);
	printf("Reading from Bulk Endpoint.\n");
	bResult = ReadFromBulkEndpoint(deviceData.WinusbHandle, &pipeUSB.PipeInId, cbSize);
		printf("Something broke in ReadFromBulkEndpoint.\n");
		printf(_T("Error among LastError %d\n"), GetLastError());
	cbSize = 256;
	system("pause");
	//End actual code
	return EXIT_SUCCESS;
My output looks like this:
Device found: VID_1781&PID_07BD; bcdUsb 0110
Device speed: 1 (Low speed).
Endpoint index: 0 Pipe type: Interrupt Pipe ID: 3.
Endpoint index: 1 Pipe type: Interrupt Pipe ID: 3.
Error among LastError 87
Now, obviously, I'm not writing to a bulk endpoint, I'm writing to an interrupt endpoint. I just not sure how to finagle that.
So how do I fix this?
