Sideline Markers to "pair" the IF and ENDIF commands
Results 1 to 5 of 5
    Nov 2007
    Lightbulb Sideline Markers to "pair" the IF and ENDIF commands
    I intend to use quite some If-Then and If Then Endif commands.
    But sometimes it is hard to keep a right view on things when you don't see which IF commands stands alone and which IF commands are closed with an Endif, and if so, Which Endif in that manner.
    Would it be an idea to mark an IF command (when clicking on the specific line) along with its closing Endif command?
    It would make things so much more clear. :-)
    Default Re: Sideline Markers to "pair" the IF and ENDIF commands
    Good idea, but that is out of PBP's hands. It's something that could be handled by whatever IDE you use: Microcode Studio, Fineline, etc.
    FineLine IDE already does exactly that and I'm 99.9% sure MPLABX does too.
    "Bracketing" (ie matching IF/ENDIF, FOR/NEXT, WHILE/WEND etc), code folding and source level debugging is what's missing in MicroCode Studio IMHO.
    Sep 2009
    I'm using MPLABX, code folding, TODO markers, etc still doesn't work for PBP3...
    Or am I missing something
    No, since you're using it and I'm not it's most likely ME who's missing something.
    That makes source level debugging pretty much the only reason for using it (MPLABX) with PBP then.
  1. Replies: 0
    Last Post: - 14th November 2013, 03:32
  2. Replies: 3
    Last Post: - 15th October 2012, 08:06
  3. Replies: 8
    Last Post: - 3rd March 2011, 22:20
  4. Sending printer "Esc/Pos" commands
    By Kman in forum mel PIC BASIC Pro
    Last Post: - 25th June 2007, 20:17
  5. Replies: 1
    Last Post: - 16th February 2005, 20:05
