Convert 3-byte hex to dec to display on LCD
Results 1 to 5 of 5
    lab310's Avatar
    lab310 Guest
    Default Convert 3-byte hex to dec to display on LCD
    I'm doing some fp calculus and result is stored in 3 byte's. How to display this value on LCD in decimal presentation?
    For example, a1= 3f, a2=12, a3= 34
    h 3f1234 = 4133428, and this is a value to display on LCD (or serial port).
    Jun 2005
    Wisconsin
    My suggestion would be to mathematically combine the digits into a single value then:
    LCDout $FE,$C0,[dec calculatedvalue]
    lab310's Avatar
    lab310 Guest
    Can't do that since PBP doesn't handle >16bit variables, and I have 24bit.
    Jun 2005
    Wisconsin
    How about:
    LCDout $FE,$C0,[dec a1,dec a2,dec a3]
    Italy
    Hi!
    Just do an addition like you would do on paper without a calculator.
    The multipliers used below are the single HEX digits.
    (Multipliers for your example: 3=3, F=15, 1=1, 2=2, 3=3, 4=4).
    See also the PicBasic "DIG" instruction.
    HEX
    3F1234
    DEC
    1048576
    1048576
    1048576
      65536
      65536
      65536
      65536
      65536
      65536
      65536
      65536
      65536
      65536
      65536
      65536
      65536
      65536
      65536
       4096
        256
        256
         16
         16
         16
          1
          1
          1
          1
    4133428
    (3*6)+(15*6)+(1*6)+(2*6)+(3*6)+(4*1)= 148 (write 8)
    14+(3*7)+(15*3)+(1*9)+(2*5)+(3*1)= 102 (write 2)
    10+(3*5)+(15*5)+(1*0)+(2*2)= 104 (write 4)
    10+(3*8)+(15*5)+(1*4)= 113 (write 3)
    11+(3*4)+(15*6)= 113 (write 3)
    11+(3*0)= 11 (write 1)
    1+(3*1)= 4 (write 4)
    Have fun!
    Luciano
  1. LCD freeze
    By harryweb in forum mel PIC BASIC Pro
    Last Post: - 5th October 2009, 09:01
  2. Migrating from PIC16F690 to PIC18F4525 and having LCD issues
    By jblackann in forum mel PIC BASIC Pro
    Last Post: - 6th June 2008, 21:05
  3. Microcontroller with 2 way paging application problem
    Last Post: - 20th April 2007, 18:27
  4. 3 HPWM channels
    By docwisdom in forum mel PIC BASIC Pro
    Last Post: - 4th April 2006, 03:43
  5. 16F877 RAM Question
    By Art in forum mel PIC BASIC Pro
    Last Post: - 6th August 2005, 12:47
