Read SIM 1st message and display it in a 20x4 LCD
Results 1 to 4 of 4
    May 2012
    Cool Read SIM 1st message and display it in a 20x4 LCD
    Hello every one.
    I am trying to read SIM 1st massage and display it in a 20x4 LCD
    I am using PIC18F2550,20x4 LCD and wavecom-gsm-gprs-modem-q2303a.
    When I send this command .The reply is as below…
    AT+CMGR=1
    AT+CMGR=1
    .+CMGR: "REC READ","+8801678715550",,"13/12/05,18:54:31+24"
    .Hello Love Loo.This is a test massage.
    OK
    But when I try to display it in a LCD .It display only….
    +CMGR: “RE
    I want to display the whole massage
    “Hello Love Loo.This is a test massage.”
    Can anyone help me out…
    My Code is....
        __CONFIG    _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
        __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
        __CONFIG    _CONFIG2L, _PWRT_OFF_2L & _BOR_ON_2L & _BORV_3_2L & _VREGEN_ON_2L
        __CONFIG    _CONFIG2H, _WDT_OFF_2H & _WDTPS_512_2H
        __CONFIG    _CONFIG3H, _CCP2MX_ON_3H & _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_ON_3H
        __CONFIG    _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L
    'Define OSC 48           ' Core is running at 48MHz
    '******************** Definitions *******************************
    'DEFINE OSC 4			'for 4 Mhz
    DEFINE OSC 8			'for 8 Mhz
    DEFINE HSER_TXSTA 20h	'I wonder shall I define as DEFINE HSER_TXSTA 24h???
    DEFINE HSER_RCSTA 90h	'same for all
    'DEFINE HSER_BAUD 2400	'for 2400 Baud rate
    'DEFINE HSER_BAUD 4800	'for 4800 Baud rate
    DEFINE HSER_BAUD 9600	'for 9600 Baud rate
    'DEFINE HSER_SPBRG 25		'for 4Mhz/2400 & 8Mhz/4800 with an error %0.16
    DEFINE HSER_SPBRG 12	'for 4Mhz/4800 & 8Mhz/9600 with an error %0.16
    DEFINE HSER_CLROERR 1	'same for all
        DEFINE NO_CLRWDT               '// Saves 17 words code space
    '**************** Allocate variables ***************************
    '****************  define variables  ***************************
        Sedata  var byte[40]
        TELNO   var byte[11]  ' array for phone number
        i       var byte      ' Define loop variable
        Sta     var bit
        Line    var byte    'LCD line address
        K       VAR BYTE    'counter
        KC      VAR BYTE    'counter
    '******************* Initialization ****************************
        TRISA=%00000111    ' Set PORTD to all output
        TRISB=%00000000    ' Set PORTD to all output
        TRISC=%10000001    ' Set PORTD to all output
    '    ansel=%00000011
        CMCON = 7
        PORTB=%00000000
        PORTA=%00000000
        Sta=0
        ADCON1 = 15          ' Set PORTA and PORTE to digital
            Line = $80          'LCD 1st line
            K = 0
            KC = 0
    '----------------- Define LCD pins ------------------------------
        define  LCD_DREG    PORTB           ' LCD Data port
        define  LCD_DBIT    0               ' starting Data bit (0 or 4) if 4-bit bus
        define  LCD_RSREG   PORTB           ' LCD Register Select port
        define  LCD_RSBIT   5               ' LCD Register Select bit
        define  LCD_EREG    PORTB           ' LCD Enable port
        define  LCD_EBIT    4               ' LCD Enable bit
        define  LCD_LINES   4               ' Number of lines on LCD
    '------------------------ End of Declare LCD -----------------------------
        lcdout  $FE,$80,"GSM SMS Center V1.0 "  ' Display Key board V1.0
        Pause   1000                            ' Delay 1 Sec
        lcdout  $fe,$1                          ' Clear Screen
    '--------------------------- mainloop -----------------------------------
    GSM_CHECK:
        HSEROUT ["AT",13]                    'Send AT to modem followed by a CR
        HSERIN 5000, GSM_CHECK, [WAIT("OK")] 'Check OK reply, wait 5sec max.
        lcdout  $FE,$80," Step 1 "  ' Display Key board V1.0
        PAUSE 1000
        HSEROUT ["AT+IPR=9600",13]      'Set transfer speed
        HSERIN 5000, GSM_CHECK, [WAIT("OK")]'Check OK reply, wait 5sec max.
        lcdout  $FE,$80," Step 2 "  ' Display Key board V1.0
        PAUSE 1000
        HSEROUT ["AT+CMGF=1",13]            'send AT to modem followed by a CR and line feed
        lcdout  $FE,$80," Step 3 "  ' Display Key board V1.0
        PAUSE 1000
    BEGIN:
        if PORTC.0 = 0 & Sta=0 then
          goto SEND_SMS
          goto READ_SMS
        PAUSE 1000
        GOTO BEGIN
    READ_SMS:
        HSEROUT ["AT+CMGR=1",13]            'send AT to modem followed by a CR and line feed
        HSERIN 5000,READ_SMS,[WAIT("AT+CMGR=1"),STR Sedata\13]'Check OK reply, wait 5sec max.
    '    Sedata = Sedata << 3
    '   SKIP 10,
    loo:
        lcdout $fe,Line+KC,Sedata[K]
            PAUSE 1000
            K = K+1
            KC = KC+1
            if K < 19 then goto loo
              KC = 0
              Line = $C0
             if K < 39 then goto loo
    Looop:
        PAUSE 1000
            GOTO Looop
    SEND_SMS:
        lcdout  $FE,$80," SMS Send >  > "  ' Display Key board V1.0
        GOTO BEGIN
    ERROR_SMS:
            LCDOut $fe,1,"NO RESPONS!",$fe,$c0,"CHECK SIM/PHONE"
            Pause 3000
            GOTO BEGIN
    Default Re: Read SIM 1st massage and display it in a 20x4 LCD
    Loosha, The lines for the lcd are started form $80 for first line, $C0 for second line, $94 for third line and, $D4 for forth line. I do not see where you are sending any daya to any line other than the first line.
    EN82fn
    May 2012
    Just I think so you don’t see the code carefully.
    In my initialization I do the work.
    Jun 2009
    Sc*nthorpe, UK
    This instruction
    reads in 13 characters
    this is what you should have
    HSERIN 5000,READ_SMS,[WAIT("AT+CMGR=1"),STR Sedata\40\13]'Check OK reply, wait 5sec max.
    Which will read in 40 characters but stop if a ASCII 13 is read.
  1. Virtual 20x4 display in ram on a 12F683
    Last Post: - 6th February 2013, 23:03
  2. Pic18f452 with 20x4 LCD Help
    By djmachine in forum mel PIC BASIC Pro
    Last Post: - 6th November 2008, 22:43
  3. Replies: 6
    Last Post: - 30th June 2008, 16:33
  4. 20x4 LCD and P18F2680
    By microuser in forum mel PIC BASIC Pro
    Last Post: - 9th June 2006, 19:26
  5. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 12:22
