Random outcome on multiple devices
Results 1 to 23 of 23
    Jan 2011
    Sydney, Australia
    Default Random outcome on multiple devices
    Hi All,
    I have read most of the forum posts regarding Random Number generation but can't find one that answers my particular question.
    I understand the random number sequence will be highly repeatable and predictable if using the same seed but what is the likelihood of the same random number being generated on two or more stand alone PIC's?
    For example, four PIC12F508's all running the same code and all turn on at the same time - would the outcome of a "RANDOM MyNumber" command likely to be the same for all four PIC's?
    A bit of background - I need to build an array of 32 pairs of LED's and set each pair to toggle at a different frequency. Each pair of LED's will be driven by its own PIC. I was hoping to be able to introduce a degree of randomness to the whole scheme rather than having to program each PIC differently to achieve an overall variation in flash rates between individual pairs.
    Comments and suggestions would be greatly appreciated.
    Cheers
    Barry
    VK2XBP
    Aug 2003
    Default Re: Random outcome on multiple devices
    Hi Barry, Greetings from Australia
    If you run the same program on all four pics the result will be the same.
    There is no math formula to produce a random number
    PicBasic will cycle through a finite set of numbers.
    If you can choose a seed, you could load each pic with a different seed.
    If any action depends on a user pressing a button you can time the button
    push, or count contact bounce, and add that result to a seed for a different seed each launch.
    Without any external input, I think you'd be needing to at least write
    something different to each on-board EEPROM,
    unless you can do something really tricky to detect noise in a power supply or some such thing.
    Cheers, Art.
    Jan 2011
    Sydney, Australia
    Hi Art,
    In what part of the "Land Down-Under" do you reside?
    I am in Sydney's southern suburbs.
    Thanks for the quick reply.
    Noise detection systems are overkill for this project. I was hoping that the power up sequence for individual devices would have provided some degree of variation.
    What if I used a timer based system to generate the seed and then de-tuned the internal oscillator between various devices to get some spread of variation - do you think that would work?
    Alternately, I could cascade a pulse from PIC to PIC and emulate a button push... just thinking out aloud here.
    Cheers
    Barry
    VK2XBP
    Aug 2003
    Close to Brisbane here
    There are always things you can try. Maybe PicBASIC's POT command.
    only instead of using a potentiometer, try a fixed value resistor,
    and maybe a reading with POT will vary enough with temperature
    (if you had to produce multiple units and keep firmware identical).
    Once with the Sony PSP I got random numbers by looking at the audio input
    It all depends on where you want to introduce the variation.... If you by "detune" the oscillator mean to tweak the OSCTUNE register slightly between devices then you might as well program in a different seed from the get-go - there will be a unique program in each device either way.
    Perhaps you can use something like the RCTime command with an external RC (duh...) network to generate the seed and rely on the tolerance of the R and the C to get the needed variance.
    EDIT: Art beat me to it while I was typing and doing some other things.
    Jan 2011
    Sydney, Australia
    Great suggestions guys - thank you.
    I will look at the POT/RCTime commands and choose wide tolerance components or random values to achieve the desired variation.
    Cheers
    Barry
    VK2XBP
    Aug 2003
    I can't help thinking there would be some noise on the power you'd see with ADC.
    Interference between ADC pins has always been a problem...
    Jan 2011
    Sydney, Australia
    I am not sure how I would go about un-tapping the noise to produce a random output.
    Would you care to expand your idea for me?
    Cheers
    Barry
    VK2XBP
    Aug 2003
    If the device is mains powered there's a 50/60Hz clock on the transformer secondary
    the way old LED digital clocks used to keep time from mains signal.
    If you are looking at that with a pic that has an independent clock the results will vary.
    If you can run an ADC from internal RC clock
    DEFINE ADC_CLOCK 3
    and the pic from xtal, and look at any clock or output signal
    generated by the pic program with ADC the results will differ as clocks lose sync.
    I would try the resistor Cap network first (timing cap discharge via resistor).
    (Never done this)
    What about reading a resistor on analog pin? A high value, maybe 100K, would that produce a reasonably wide range of seeds?
    Edit: since no 2 resistors are exactly alike, the voltage should vary.
    Aug 2003
    It sounds like it would work.
    That would be the first thing I'd try now, nice one.
    .. and if not, then tapping the centre of a divider (two resistors from +ve to Gnd).
    Still cheaper than timing a cap discharge.
    I can't say I've tried to make two devices produce a different result,
    just one device from one launch to the next.
    (Never done this)
    Even better, use a LED and 330R resistor. You're bound to get different voltages and it serves as a power indicator.
    Jan 2011
    Sydney, Australia
    Hi Guys,
    All great ideas - thank you.
    I have decided to program each PIC separately making subtle differences to LED flash rates and "off-time" periods to give an overall effect of randomness.
    This is a one-off project that I am doing as a labour of love for my company. As such, I just want to get in and get out as quickly as possible
    Cheers
    Barry
    VK2XBP
    One possible issue with using the ADC is that the 12F508 being mentioned in the first post doesn't have one....
    Aug 2003
    Still in general, it sounds like something to try.
    You get 14 bit ADC with pic if I remember,
    should be high enough resolution to vary with resistor tolerance.
    I was keen to see how it panned out without doing it myself
    As long as we stick to 8-bit PICs (which is what PBP supports) there's a quite a selection devices with 12bit ADC and two devices with 16bit ADC (18F8xJ72). All of them are enhanced 16F1xxx or 18F parts though, the smallest I could find thru a quick look is 28pin.
    Jan 2011
    Sydney, Australia
    Hi All,
    So much has happened in the last week or so...
    In typical fashion, the customer (my company on this occasion) has requested "additional functions" to be included which are above and beyond the original scope of work. The degree of modification has required a complete re-design.
    I won't bore you with the trivial details but the system now requires three separate LED flash sequences AND an auto function to scroll through the three stand-alone sequences.
    No - problems, just more time and code...
    I have now moved to a PIC16F1503. I would still like to use some sort of random number generation routine to achieve a random display flash rate between the thirty two individual PIC's without having to separately programming them. I could take the easy way out and do it manually but I like the idea of coming up with something eloquent
    Here is my thought:
    I can use my MeLabs programmer to generate a unique serial number for each PIC that I program. I understand this is a straight forward process. I would like to my program to read this unique serial number and use it as the seed for the random number generation source.
    Here is my question:
    Can is this concept be taken to a reality or am I barking up the wrong tree?
    Comments and suggestions greatly appreciated.
    Cheers
    Barry
    VK2XBP
    Well, the short answer is YES.
    The programmer can auto increment a serial number that gets programmed into Flash Memory.
    That value can be read back with READCODE.
    Quote Originally Posted by Aussie Barry View Post
    Here is my thought:
    I think this would be the same as giving the PIC a fixed seed in the code. You might try a subprogram to save the last number used and then shutting it down. At startup have it read that value from eeprom.
    Quote Originally Posted by Archangel View Post
    Exactly!
    Using the U2's incrementing serial number ... Each PIC has a "Fixed Seed".
    But each of the 32 PICs are guaranteed to have a different seed, therefore a different blink pattern on power-up.
    They are all running the same sequence of 65535 pseudo random numbers, but they all start at a different point in that sequence.
    Jan 2011
    Sydney, Australia
    Thanks for the sanity check guys
    Glad to know I am on the right track.
    I should be able to sort out the serial number start and incremental values but I am curious to know the best place to store the information in flash memory.
    I will be totally honest - I am now working well beyond the limits of my knowledge base. A simple recommendation would be appreciated. A recommendation along with an explanation as to why would superb. I revel in every opportunity to learn something along the way.
    Please note: I have RTFM. Reading is one thing, comprehending is something altogether different.
    Cheers
    Barry
    VK2XBP
    I would suggest putting it at the end of Program Memory.
    The 1503 has 2K words of flash, so two locations starting at 07FEh.
    It will store the lowbyte and highbyte separately.
    Temp   VAR WORD
    Seed   VAR WORD
    READCODE $7FE, Temp
    Seed.LowByte = Temp.LowByte
    READCODE $7FF, Temp
    Seed.HighByte = Temp.LowByte
    I don't have access to a 1503 today, but I think it should work.
    Jan 2011
    Sydney, Australia
    Legendary response Darrel - thank you!
    I will keep you posted with project milestones as they are reached.
    Cheers
    Barry
    VK2XBP
  1. Programming multiple pics with multiple programs
    By Luckyborg in forum mel PIC BASIC Pro
    Last Post: - 3rd April 2013, 17:47
  2. Multiple I2c Devices
    By alphaengr in forum mel PIC BASIC Pro
    Last Post: - 12th January 2012, 04:37
  3. Multiple serial devices to one pic
    By rshaver in forum mel PIC BASIC Pro
    Last Post: - 16th October 2011, 15:34
  4. 12F683 ADcin = binary outcome!
    Last Post: - 5th March 2010, 04:42
  5. Self update of devices
    By Ioannis in forum General
    Last Post: - 24th December 2009, 17:49
