IOC on a ACD pin ?
Results 1 to 6 of 6
    Feb 2012
    PERTH AUSTRALIA
    Default IOC on a ACD pin ?
    is it possible to trigger a IOC on a acd pin ?
    cheers
    Sheldon
    Bombay, India
    Default Re: IOC on a ACD pin ?
    My hunch is that it should be possible. You may need to configure the pin for digital input to capture the IO Change and then switch the pin to analog to get the analog value.
    Feb 2012
    PERTH AUSTRALIA
    but would that not work if i was looking for a analog change not a logic change ?
    Bombay, India
    Obviously not. You cannot have an interrupt on analog change.
    Hello,
    You did not mention which pic you are using? Many pics have comparator modules connected to the analog pins. These can generate interrupts on change by setting the reference voltage to your desired trigger level.
    Just an idea, depending on your specific pic and available pins.
    Feb 2012
    PERTH AUSTRALIA
    thats a good thought . the pic i am using is 16F1947 ,
    I IOC pins cannot be an analog pin on this chip.
    reason is i am using a 4 analog pins connected to a touch panel , so would be good to use a interrupt to serve the routine
  1. Unorthodox use of IOC Port.B
    By mtripoli in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2013, 22:06
  2. pulsin problem using IOC with DT_int14.bas
    By longpole001 in forum mel PIC BASIC Pro
    Last Post: - 5th December 2012, 10:00
  3. Replies: 1
    Last Post: - 12th May 2012, 13:37
  4. A Simple IOC Routine (Interrupt On Change)
    By lugo.p in forum mel PIC BASIC Pro
    Last Post: - 8th March 2010, 20:53
  5. IOC question
    By Adrian in forum mel PIC BASIC Pro
    Last Post: - 1st April 2008, 20:21
