10F222 wake/sleep
Results 1 to 4 of 4
    Sep 2010
    Las Vegas, NV
    Default 10F222 wake/sleep
    Ladies and Gents,
    I've been playing around with the 10F222 and its sleep/wake on pin change. Not trying to show my ineptness here but what do they mean by reading the input pins? This code works:
    CLEAR
    adcon0 = 0         ' Turn off ADC
    option_reg = %00001000       ' enable wake on pin, weak pull ups, prescaler to wdt
    osccal = %00000000            ' oscillator calibration
    trisio = %1101      ' GP1 only is output
    gpio = 0 ' turn everything off
    LED VAR gpio.1
    i VAR BYTE
    start_here:
    IF gpio.0 = 0 THEN GOSUB Light_LED
    IF gpio.3 = 0 THEN GOSUB Light_LED
    SLEEP 5
    GOTO start_here
    Light_LED:
    i = 0
        FOR i = 0 TO 3
        TOGGLE LED
        PAUSE 8000
        NEXT i
    I'd like to know if I did it right or is there something more subtle, or bodacious, I should be doing.
    I've, I think, attached the page and my code. Constructive help greatly appreciated.
    Aug 2008
    Portugal
    Default Re: 10F222 wake/sleep
    Hi AvionicsMaster
    Here is a code using IOC and Sleep.
    '*  Name    : Temporizador 3m p/ Lavar Dentes.BAS               *
    '*  Author  : Hugo Oliveira                                     *
    '*  Notice  : Copyright (c) 2012 ProSystems                     *
    '*  Date    : 01-03-2012                                        *
    '*  Notes   : Proteus + Circuito com SOT-23 e CR2032            *
    '*          : 10F222 - Wake from sleep através de IOC no GP3    *
    @ __config _IOFSCS_4MHZ & _WDT_OFF & _MCLRE_OFF & _CP_OFF & _MCPU_ON
     '===================SRF AND PINOUT CONFIGURATION - 1-In / 0-Out=================
                  '76543210
         TRISIO = %00001000
           GPIO = %00000000
     OPTION_REG = %00000000 'OPTION_REG.7 - Wake on change bit 0=Enable
         ADCON0 = %00000000 'Analog pins disable
    '==================================ALIAS========================================
     VAZIO1 VAR GPIO.0
     VAZIO2 VAR GPIO.1
     LED    VAR GPIO.2
     MCLR   vAR GPIO.3
    '=================================VARIABLES=====================================
     I VAR BYTE
    '================================MAIN LOOP======================================
    @ movlw 0x01A  ;OSCCAL Value
    @ movwf OSCCAL
     WHILE MCLR = 0
     WEND
     FOR I = 0 TO 119 '~120 Segundos a Piscar de 1 em 1 Segundo
        HIGH LED
        PAUSE 500
        LOW LED
        PAUSE 500
     NEXT
     FOR I = 0 TO 59  '~30 Segundos a Piscar de 0,5 em 0,5 Segundo
        HIGH LED
        PAUSE 250
        LOW LED
        PAUSE 250
     NEXT
     HIGH LED
     PAUSE 30000     '~30 Segundos sempre ligado
     LOW LED
     'Sequencia de finalização
     HIGH LED: PAUSE 100: LOW LED: PAUSE 100
     I = GPIO     'Must read GPIO before entering sleep. Read the Datasheet
    @ SLEEP
    @ NOP
    GOTO Main
    Thanks and Regards;
    Gadelhas
    There's a slight difference between the PBP command SLEEP and the ASM instruction SLEEP.
    The PBP command uses the ASM instruction sleep but relies on the watchdog timer to periodically wake the PIC up in order to keep track of time. If you don't want the PIC to periodcally wake up you need to disable the watchdog and use the ASM instruction SLEEP directly.
    What they mean by "reading the pins" is that before entering sleep mode you should make a "dummy read" of the pins in order to clear any mismatch which might otherwise cause the PIC to wake right back up.
    On some PIC chips there is an option in Config Word that allows the WDT to be enabled when PIC is running and automatically disabled when it enteres SLEEP (in ASM command, not PBP sleep).
    For example 16F1826/27. See page 44 of the datasheet at http://ww1.microchip.com/downloads/e...Doc/41391D.pdf
  1. Cannot wake from SLEEP
    By BrianT in forum mel PIC BASIC Pro
    Last Post: - 21st May 2013, 07:47
  2. Replies: 1
    Last Post: - 11th November 2011, 07:01
  3. 16F690... How to wake from sleep?
    By Heckler in forum mel PIC BASIC Pro
    Last Post: - 5th July 2011, 22:07
  4. 16F181: can't wake up from sleep
    By Navaidstech in forum mel PIC BASIC Pro
    Last Post: - 9th January 2010, 04:33
  5. wake up from sleep
    Last Post: - 31st August 2007, 17:09
