Adding values one at a time and sending them serially
+ Reply to Thread
Results 1 to 5 of 5
    Nov 2009
    London
    Question Adding values one at a time and sending them serially
    Hi, I have 5 sensors attached to a PIC. I need to get one variable, word size (I suppose) and load the number(s) of the triggered sensor in this variable.
    I have 5 bit size variables which are set when the corresponding numbered sensor gets triggered.
    I want something like this:
    Sens1 Var bit
    Sens2 Var bit
    Sens3 Var bit
    Sens4 Var bit
    Sens5 Var bit
    If lets say sensor 1 and 5 gets activated, Sens1 and Sens5 will be set to 1. So I want to load the value 15 in my variable. Similarly if sensor 2,3,5 gets activated, I want to load 235 in my variable. The max value will be 12345 if all sensors get triggered.
    Default Re: Adding values one at a time and sending them serially
    This is untested but I think it'll do what you want
    Sens VAR BIT[5]                 ' 5bit array for sensor bits
    Sens1 VAR Sens[0]               ' Aliases to the array bits.
    Sens2 VAR Sens[1]
    Sens3 VAR Sens[2]
    Sens4 VAR Sens[3]
    Sens5 VAR Sens[4]
    Multiplicator VAR WORD
    Value VAR WORD
    i VAR BYTE
    CalculateValue:
        Multiplicator = 1
        Value = 0
        For i = 0 to 4      ' Index the 5 sensor bits of the array
            IF Sens[i] THEN
                Value = Value + ((i+1) * Multiplicator)
                Multiplicator = Multiplicator * 10
        NEXT
    Aug 2011
    Guadalajara, México
    Hi Megahertz, the code below is tested for a PIC12F675, it's the Henrik's code but with 3 minor modifications (Sens var type, Aliases index, and inverted counter)
    All the credit is to Mr. Olsson
        __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF & _CPD_OFF
    DEFINE OSCCAL_1K 1              'Internal Clock Auto-cal (for reliable RS232)
    ansel=0                         'Don't use ADC's
    cmcon=7                         'Don't use analog comparators
    DEFINE DEBUG_REG GPIO           'Set Debug pin port
    DEFINE DEBUG_BIT 0              'Set Debug pin bit
    DEFINE DEBUG_BAUD 2400          'Set Debug baud rate
    DEFINE DEBUG_MODE 0             'Set Debug mode: 0 = true, 1 = inverted
    Sens VAR Byte                   ' 5bit array for sensor bits
    Sens1 VAR Sens[1]               ' Aliases to the array bits.
    Sens2 VAR Sens[2]
    Sens3 VAR Sens[3]
    Sens4 VAR Sens[4]
    Sens5 VAR Sens[5]
    Value VAR WORD
    i VAR BYTE
    Begin:
    sens1 = 1                         'Sensor 1 is high
    sens2 = 0                         'Sensor 2 is low
    sens3 = 1                         'Sensor 3 is high
    sens4 = 0                         'Sensor 4 is low
    sens5 = 1                         'Sensor 5 is high
    CalculateValue:
        Multiplicator = 1
        Value = 0
        For i = 5 to 1 step -1      ' Index the 5 sensor bits of the array
            IF Sens[i] THEN
                Value = Value + (i * Multiplicator)
        NEXT
    debug "Sensors : ",#value,13,10
    goto begin
    Ivan.
    My English doesn't sucks, it's just fugly...
    Here's another way to do it. Fully tested.
    Sens1 Var bit
    Sens2 Var bit
    Sens3 Var bit
    Sens4 Var bit
    Sens5 Var bit
    Value VAR WORD
    Idx   VAR BYTE
    Abit  VAR BIT
    Value = 0
    FOR Idx = 1 TO 5
        LOOKUP2 Idx-1,[Sens1,Sens2,Sens3,Sens4,Sens5],Abit
        IF Abit THEN Value = Value * 10 + Idx
    NEXT Idx
    Or, if you change the bits to an array similar to what henrik did, you can do this ...
    Senser VAR BYTE
    Sens1 Var Senser.0
    Sens2 Var Senser.1
    Sens3 Var Senser.2
    Sens4 Var Senser.3
    Sens5 Var Senser.4
    Value VAR WORD
    Idx   VAR BYTE
    Value = 0
    FOR Idx = 1 TO 5
        IF Senser.0(Idx-1) THEN Value = Value * 10 + Idx
    NEXT Idx
    Nov 2009
    London
    Thanks. Another problem resolved
  1. Why does this PBP statement post the wrong time values?
    Last Post: - 22nd November 2011, 03:10
  2. Question about sending data serially
    By FromTheCockpit in forum mel PIC BASIC Pro
    Last Post: - 1st August 2011, 01:21
  3. Replies: 1
    Last Post: - 4th June 2010, 03:34
  4. Replies: 9
    Last Post: - 8th October 2008, 11:15
  5. it's possible to drive four max7221 serially connected?
    By lutherblissett in forum General
    Last Post: - 23rd November 2005, 18:38
