Hardware PWM (HPWM) Clairification on 18F45K22
Results 1 to 9 of 9
    Jun 2013
    Hong Kong
    Default Hardware PWM (HPWM) Clairification on 18F45K22
    I normally like to code all of my own hardware using the direct access to registers however PBP has included a very nice HPWM Command that makes all of this very simple... However i feel a bit confused as to what is all required in the code to make the HPWM function work correctly in PBP3.
    Does anyone have an simple and or basic code that can be used for my 18F45K22 device?
    The 18F45K22 has select-able ccp channels and it is unclear to me (even after reading the datasheet section) how to align these cpp channels correctly using the registers.
    I am using 4 LED's that i would like to control using HPWM. I am running the cpu from its internal 16Mhz OSC
    LED 1: RC2/CCP1
    LED 2: RC1/CCP2
    LED 3: RE0/CCP3
    LED 4: RD1/CCP4
    I have already set the pins. but I am not sure about the additional registers and defining the timers. Example "define CCP1_REG & define CCP1_BIT" etc...
    TRISC.2 = 0 ' Set Pin to Output
    ANSELC.2 = 0 ' Set Pin to Digital
    Mode_LED_R var PortC.2 ' Digital PWM Output: Mode LED Red Element
    TRISC.1 = 0 ' Set Pin to Output
    ANSELC.1 = 0 ' Set Pin to Digital
    Mode_LED_G var PortC.1 ' Digital PWM Output: Mode LED Green Element
    TRISE.0 = 0 ' Set Pin to Output
    ANSELE.0 = 0 ' Set Pin to Digital
    Mode_LED_B var PortE.0 ' Digital PWM Output: Mode LED Blue Element
    TRISD.1 = 0 ' Set Pin to Output
    ANSELD.1 = 0 ' Set Pin to Digital
    Bluetooth_Link_LED var PortD.1 ' Digital PWM Output: Blue Link Status LED
    define HPWM1_TIMER 1
    define HPWM2_TIMER 2
    define HPWM3_TIMER 3
    define HPWM4_TIMER 4
    CCP1CON = %00001100 ' Turn CCP1 to PWM Mode
    CCP2CON = %00001100 ' Turn CCP2 to PWM Mode
    CCP3CON = %00001100 ' Turn CCP3 to PWM Mode
    CCP4CON = %00001100 ' Turn CCP4 to PWM Mode
    CCP5CON = %00000000 ' Dissable Comparator / PWM Module
    Any help or example code of how to use the HPWM on this chip would be GREATLY Appreciated!!!
    Default Re: Hardware PWM (HPWM) Clairification on 18F45K22
    I haven't used HPWM yet, but DEFINES must be in uppercase.
    Demon,
    The word "define" is a PBP statement, and PBP is not case sensitive. So it doesn't matter what case DeFiNe is.
    What follows "define" is passed on to the assembler, and MPASM IS case sensitive.
    Any defines that PBP is expecting to see, must be UPPERCASE because that's what PBP is looking for.
    Defines used in your own assembly language routines can be any case, as long as your code is looking for the same case.
    neondales's defines have the correct case , even though they are unnecessary and use the wrong timers.
    neondale,
    You don't need any of what you posted, except for the ANSEL's.
    And since you are just fading LED's, the CCP's can all run off of the same Timer, which is TIMER2 by default.
    Here's a program that starts up CCP1-4 at 3Khz - 50% dutycycle.
    Note that the default location for CCP3 is PORTB.5.
    You can move it to PORTE.0 by changing the CCP3MX_ configuration bit.
    If you move it ... change the CCP3 defines to match.
    ;----[Device Configuration]--(See manual section 4.9)---------------------------
        __config  _CONFIG1H, _FOSC_INTIO67_1H & _PLLCFG_ON_1H & _PRICLKEN_ON_1H & _FCMEN_ON_1H & _IESO_ON_1H
        __config  _CONFIG2L, _PWRTEN_OFF_2L & _BOREN_SBORDIS_2L & _BORV_190_2L
        __config  _CONFIG2H, _WDTEN_ON_2H & _WDTPS_32768_2H
        __config  _CONFIG3H, _CCP2MX_PORTC1_3H & _PBADEN_OFF_3H & _CCP3MX_PORTB5_3H & _HFOFST_ON_3H & _T3CMX_PORTC0_3H & _P2BMX_PORTD2_3H & _MCLRE_EXTMCLR_3H
        __config  _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L & _DEBUG_OFF_4L
    ;----[DEFINEs]------------------------------------------------------------------
    DEFINE OSC 4               ; Oscillator is 4Mhz
    DEFINE CCP1_REG PORTC      ; Tell PBP which pins the CCP outputs are on
    DEFINE CCP1_BIT 2
    DEFINE CCP2_REG PORTC
    DEFINE CCP2_BIT 1
    DEFINE CCP3_REG PORTB
    DEFINE CCP3_BIT 5
    DEFINE CCP4_REG PORTD
    DEFINE CCP4_BIT 1
    ;----[Aliases]------------------------------------------------------------------
    LED       PIN 0       ; LED on PORTB.0
    ;----[Variables]----------------------------------------------------------------
    Duty      VAR BYTE    ; Duty Cycle
    Chan      VAR BYTE    ; HPWM Channel
    FadeDir   VAR BYTE    ; Fade Direction (1=up, -1=down)
    ;----[Constants]----------------------------------------------------------------
    Freq      CON 3000    ; HPWM Frequency
    MaxBright CON 180     ; Maximum Fade Brightness
    ;----[Initialize]---------------------------------------------------------------
    OSCCON = %01010000    ; 4Mhz Internal OSC
    ANSELA = 0            ; All Digital
    ANSELB = 0
    ANSELC = 0
    ANSELD = 0
    ANSELE = 0
    FadeDir = 1           ; Start fading up
    Duty = 127            ; 50% dutycycle
    ;GOTO Fade1            ; Run Fading Routine
    HPWM 1, Duty, Freq    ; start the Hardware PWM channels
    HPWM 2, Duty, Freq
    HPWM 3, Duty, Freq
    HPWM 4, Duty, Freq
    ;----[Main Program Loop]--------------------------------------------------------
        TOGGLE LED
        PAUSE 500
    GOTO Main
    ;----[Fade all channels up and down]---------------------------------------------
    Fade1:
        FOR Chan = 1 TO 4
            HPWM Chan, Duty, Freq
        NEXT Chan
        IF Duty = MaxBright THEN FadeDir = -1
        IF Duty = 0 THEN FadeDir = 1
        Duty = Duty + FadeDir
        PAUSE 10
    GOTO Fade1
    Uncomment the GOTO Fade1 to run the Fade routine.
    Jun 2013
    Hong Kong
    Thanks for the Help on the Config Bits and Defines!
    I've used it on 628A without any defines, just HPWM command.
    The 16F628A only has one CCP module, and it's output cannot be moved to a different pin.
    The 18F45K22 has 5 CCP modules, and two of them can be moved to different pins.
    Jun 2013
    Hong Kong
    The part that was most helpful is the fact that PBP3 now defines all of its config bits in a very organized fashion for the new devices:
    #IF __PROCESSOR__ = "18F45K22"
    #MSG "** STARTING FIRMWARE COMPILATION **"
    #MSG "COMPILING FIRMWARE (" + __FILE__ + ")"
    #msg "FOR MICROCHIP PIC PROCESSOR (" + __PROCESSOR__ + ")"
    #IF __LONG__ = 1
    #MSG "PICBASIC COMPILER IS USING LONG VARIABLES (PBPL)"
    #ELSE
    #MSG "PICBASIC COMPILER IS USING WORD VARIALBLES (PBPW)"
    #ENDIF
    CONFIG FOSC = INTIO67 ; Internal oscillator block
    CONFIG PLLCFG = OFF ; Oscillator used directly
    CONFIG PRICLKEN = OFF ; Primary clock can be disabled by software
    CONFIG FCMEN = OFF ; Fail-Safe Clock Monitor disabled
    CONFIG IESO = OFF ; Oscillator Switchover mode disabled
    CONFIG PWRTEN = ON ; Power up timer Enabled
    CONFIG BOREN = SBORDIS ; Brown-out Reset enabled in hardware only (SBOREN is disabled)
    CONFIG BORV = 190 ; VBOR set to 1.90 V nominal
    CONFIG WDTEN = ON ; WDT is always enabled. SWDTEN bit has no effect
    CONFIG WDTPS = 32768 ; 1:32768
    CONFIG CCP2MX = PORTC1 ; CCP2 input/output is multiplexed with RC1
    CONFIG PBADEN = OFF ; PORTB<5:0> pins are configured as digital I/O on Reset
    CONFIG CCP3MX = PORTE0 ; P3A/CCP3 input/output is mulitplexed with RE0
    CONFIG HFOFST = ON ; HFINTOSC output and ready status are not delayed by the oscillator stable status
    CONFIG T3CMX = PORTC0 ; T3CKI is on RC0
    CONFIG P2BMX = PORTD2 ; P2B is on RD2
    CONFIG MCLRE = EXTMCLR ; MCLR pin enabled, RE3 input pin disabled
    CONFIG STVREN = ON ; Stack full/underflow will cause Reset
    CONFIG LVP = OFF ; Single-Supply ICSP disabled
    CONFIG XINST = OFF ; Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
    CONFIG DEBUG = OFF ; Disabled
    CONFIG CP0 = OFF ; Block 0 (000800-001FFFh) not code-protected
    CONFIG CP1 = OFF ; Block 1 (002000-003FFFh) not code-protected
    CONFIG CPB = OFF ; Boot block (000000-0007FFh) not code-protected
    CONFIG CPD = OFF ; Data EEPROM not code-protected
    CONFIG WRT0 = OFF ; Block 0 (000800-001FFFh) not write-protected
    CONFIG WRT1 = OFF ; Block 1 (002000-003FFFh) not write-protected
    CONFIG WRTC = OFF ; Configuration registers (300000-3000FFh) not write-protected
    CONFIG WRTB = OFF ; Boot Block (000000-0007FFh) not write-protected
    CONFIG WRTD = OFF ; Data EEPROM not write-protected
    CONFIG EBTR0 = OFF ; Block 0 (000800-001FFFh) not protected from table reads executed in other blocks
    CONFIG EBTR1 = OFF ; Block 1 (002000-003FFFh) not protected from table reads executed in other blocks
    CONFIG EBTRB = OFF ; Boot Block (000000-0007FFh) not protected from table reads executed in other blocks
    #ELSE
    #ERROR "FIRMWARE NOT SUPPORTED FOR " + __PROCESSOR__
    #ERROR "FIRMWARE REQUIRES AN 18F45K22 PIC PROCESSOR"
    #ERROR "!!! FIRMWARE COMPILATION ABORTED !!! "
    #ENDIF
    This is the config coding i am using in my pic processor now. to set up all of the config bits and change the Mux'ing of the CCP Modules. The Code is also ver helpful because i program a lot of different devices and if i have the wrong device set when i go to compile it... The Editor will "remind" me to change the output device type to the correct PIC. Melabs has done a great job and creating more functionality in the newest versions of the compilers.
    Thanks Melabs for Being Awesome!!!
    Jun 2013
    Hong Kong
    How do you insert a "code" Block into a post so that the code doesn't loose all of its formatting?
    Use GO ADVANCED option below reply box. The CODE tags are with square brackets (icon is # sign).
  1. manual hardware PWM setup on 16F1824
    By comwarrior in forum mel PIC BASIC Pro
    Last Post: - 31st January 2011, 18:34
  2. Hardware PWM Question?
    By jhorsburgh in forum General
    Last Post: - 18th August 2008, 03:07
  3. Inverting the o/p of hardware PWM
    By AndrewC in forum mel PIC BASIC Pro
    Last Post: - 7th August 2008, 19:36
  4. 3 Hardware PWM.
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 30th January 2008, 12:21
  5. pics with 3 hardware PWM ports
    By CBUK in forum mel PIC BASIC Pro
    Last Post: - 5th August 2004, 00:14
