Assigning a string variable to another string variable
+ Reply to Thread
Results 1 to 3 of 3
    New Jersey
    Default Assigning a string variable to another string variable
    I'm so close I can smell it.
    I'm using this to get my data:
    DAT VAR byte[255]
    UNIT1 VAR byte[255]
    UNIT2 VAR byte[255]
    UNIT3 VAR byte[255]
    CMD VAR BYTE
    HSERIN 1, COMPLETE_RX_TRANSFER,[wait ("&"),dec2 CMD, STR DAT\255\"#"]
    This works well. The problem is, I want to filter the DAT data and then assign different string variables for the DAT. It looks like this:
    SELECT CASE CMD
        CASE 80
            UNIT1=DAT
        CASE 81
            UNIT2=DAT
        CASE 83
            UNIT3=DAT
    END SELECT
    The problem is that when I go to display the newly assigned variables I only get the first character. I've tried UNIT1=DAT\255 and that returns an error. What am I missing? I know I can just filter it with HSERIN but I thought it would make the program quicker if I used one HSERIN statement and then used select case to sort the data.
    Default Re: Assigning a string variable to another string variable
    I don't quite understand why you need to do what you're trying to do, it seems like a waste of RAM to have multiple copies of the same data instead of just acting on the data stored in the DAT array. But anyway, one way would be like
    i VAR BYTE
    For i = 0 to 254
       UNIT1[i] = DAT[i]
    NEXT
    New Jersey
    I'm not quite sure what I'm doing but your technique worked well.
    Thanks.
  1. Transform String Variable
    By Magoga in forum mel PIC BASIC
    Last Post: - 3rd January 2013, 02:25
  2. Multi-digit word variable to string
    By Amoque in forum mel PIC BASIC Pro
    Last Post: - 25th March 2012, 20:06
  3. Assigning particular value to a variable
    Last Post: - 31st July 2011, 00:22
  4. HSERIN for variable length string
    Last Post: - 19th February 2010, 06:58
  5. Assigning a variable to only a few pins?
    By Dayaks in forum mel PIC BASIC Pro
    Last Post: - 28th August 2006, 00:21
