Downward compatibility PBP versions.
Results 1 to 5 of 5
    Feb 2011
    Default Downward compatibility PBP versions.
    I have posted solar tracking code as open source to be compiled with PBP version 2.60A.
    My question (from others), Are the latest versions of PBP 100% downward compatible with version 2.60A?
    http://www.harbornet.com/sunflower/sunrun.pbp
    Default Re: Downward compatibility PBP versions.
    I'm still at 2.60c, but the subject of new CONFIG directive in 3.0 comes up often.
    Miami, Florida USA
    Me too. I am still at 2.60c. New features in 3.0 would make it impossible for downward compatibility.
    Anonymous
    Feb 2011
    OK. That makes sense. So, excepting new features, both will produce the same hex file from the same source code?
    Miami, Florida USA
    Quote Originally Posted by SUNFLOWER View Post
    Hmm, I am not sure about that. They always make improvements with every new version. For example, they may try to make a certain command run faster (with less instructions) than with a previous version. I don't know what changes they made with the new version 3.0, but that can be found in the Melabs webpage.
    Anonymous
  1. PBP v3.0 vs previous versions
    By MikeBZH in forum mel PIC BASIC Pro
    Last Post: - 4th October 2011, 21:30
  2. No choice but to use PBP on 64 bit versions of Windows :(
    By TerdRatchett in forum mel PIC BASIC Pro
    Last Post: - 28th July 2011, 13:20
  3. Two Versions of MPASM in the Same Computer???
    By rsocor01 in forum mel PIC BASIC Pro
    Last Post: - 11th July 2011, 20:24
  4. MikroElectronika releases PIC32 compiler beta versions
    By ScaleRobotics in forum Off Topic
    Last Post: - 17th February 2011, 16:41
  5. Intelmac compatibility?
    By edopaulus in forum mel PIC BASIC Pro
    Last Post: - 18th July 2009, 14:28
