Help With OLED Display / 128X64 SSD1306
Results 1 to 7 of 7
    Default Help With OLED Display / 128X64 SSD1306
    Hello,
    Buy this Oled screen of 0.96 ", but so far it works.
    I work connecting to the I2C Bus, the Micro is a 18F4550 to 20MHz.
    Oled Display Image and Data Sheet: http://www.ebay.co.uk/itm/0-96-128x6...-/130536921656
    Pins Board:
    3V3 D0 (SCLK)
    RS D1 (SDIN)
    CS D2
    WR D3
    RD D4
    RES D5
    VIN D6
    GND D7
    Connection ProtoBoard:
    D1 (SDIN) => B0 (SDA)
    D0 (SCLK) => B1 (SCL)
    3V3 => 3V3 (VCC)
    VIN unknow 3V3 (VCC)
    GND => GND
    VBAT => +
    BS0 => 0
    BS1 => 1
    BS2 => 0
    *The other pins are not connected (RS,CS,WR,RD,RES, D02 to D7).
    I have to connect more things!!, Hope for help me with this project!.
    THX.
    Default Re: Help With OLED Display / 128X64 SSD1306
    At the moment the code doesn´t work. HELP!!
    THX.
    ' CODE
    Device = 18F4550 'Work PIC
    Declare Xtal 20 'Set 20Mhz
    All_Digital true 'Set All Digital Port
    'Pins, I2C BUS ----------------------------------------------
    Declare I2C_Slow_Bus On 'SLow el bus I2C
    Declare SDA_Pin PORTB.0 'I2C (SDA)
    Declare SCL_Pin PORTB.1 'I2C (SCL)
    Declare Hbus_Bitrate 100 'I2C Bitrate 100Hz
    ' Program
    DelayMS 200 ' Wait for the PIC® micro to stabilise
    'Initialitation of display Commands (data Sheet)
    HBStart 'Send a Start condition to the I2C bus
    HBusOut 0x3C 'Control, (Slave address)
    HBusOut 0 'LowByte R/W#=0
    HBusOut 0xAE 'Display off
    HBusOut 0xD5 'Set Osc Frequency
    HBusOut 0x80
    HBusOut 0xA8 'Set Mux Ratio
    HBusOut 0x3F
    HBusOut 0xD3 'Set Display Offset
    HBusOut 0x00
    HBusOut 0x8D 'Set charge Pump regulator
    HBusOut 0x14 'Or 0x10
    HBusOut 0xA1 'Set Segment re-map or 0xA0
    HBusOut 0xC8 'Set COM Output Scan Direction or 0xC0
    HBusOut 0xDA 'Set COM pins Hardware Configuration
    HBusOut 0x12 'or 0x02
    HBusOut 0x81 'Set Contrast Control
    HBusOut 0x81 'or 0x22, 0xCF
    HBusOut 0xD9 'Set Pre-Charge Period
    HBusOut 0xF1 'or 0xF22
    HBusOut 0xDB 'Set VCOMH Deselect Level (Display Start Line)
    HBusOut 0x40 'Display Start At 0
    HBusOut 0xA5 'Set Disable Entire Display On or 0xA4h
    HBusOut 0xA6 'Set Normal/ A7h Inverse Display
    HBusOut 0xAF 'Set Display ON
    HBStop 'Send a Stop condition to the I2C bus
    Ini:
    DelayMS 1000
    'HBusOut 0x3C 'Control, (Slave address)
    'HBusOut 0 'LowByte R/W#=0
    HBReStart 'Send a Restart condition
    HBusOut $A7 'All Pixels ON
    DelayMS 1000
    HBusOut $A6 'All Pixels OFF
    DelayMS 1000
    HBusOut 0xAE 'Display OFF
    HBStop
    GoTo Ini
    Edit Post
    Reply
    + Reply to Thread
    « Previous Thread | Next Thread »
    Thread Information
    AS far as I can see, This isn't PICBASIC code.
    EN82fn
    Whatever you are doing, I hope you didn't include the forum commands at the bottom of your code.
    Hey Dave,
    Yes, I'm Sorry is Proton Compiler. But seem more or less.
    Hello Demon,
    Could you be more explicit, I would appreciate.
    Can you tell me missing or there are extra code, which I do wrong.
    Thx.
    Quote Originally Posted by Denner View Post
    Hello Demon,
    Thx.
    I was talking about this stuff:
    Edit Post
    Reply
    + Reply to Thread
    Thread Information
  1. Winstar OLED Display Problem with lcdout comands
    By bubbleless in forum mel PIC BASIC Pro
    Last Post: - 31st December 2019, 05:53
  2. A Serial GLCD 128x64 Simple Project
    By Oldspring in forum Off Topic
    Last Post: - 8th March 2010, 20:58
  3. Ks0108 128x64 Glcd
    By HenrikOlsson in forum General
    Last Post: - 9th June 2008, 21:58
  4. OLED 128x128 color display
    By Ron Marcus in forum mel PIC BASIC Pro
    Last Post: - 21st May 2007, 01:45
  5. GLCD 128x64 with KS0108 controller
    By Darklakebridge7 in forum mel PIC BASIC Pro
    Last Post: - 5th December 2005, 21:06
