Cannot wake from SLEEP
Results 1 to 6 of 6
    Default Cannot wake from SLEEP
    I cannot get my PIC18F4620 to wake from sleep. The code and the configuration settings are below. It is such a simple program but obviously I am missing some necessary register setting.
    All suggestions gratefully received.
    BrianT
    </code>
    '* Name : SleepLED.pbp *
    '* Author : Brian Taylor *
    '* Notice : Copyright (c) 2013 Brian Taylor *
    '* : All Rights Reserved *
    '* Date : 20/05/2013 *
    '* Version : 1.0 *
    '* Notes : *
    '*** PIC18F4620 Config Register setup for MeLabs U2 USB programmer ******
    ' OSC = INTIO2, Set to 4 MHz via OSCCON, FSCM = Dis, IESO = Dis, PwrupTmr = Dis
    ' BrownOut = Dis, BOR Volts = 2, WDT = Dis, WDTPS = 1:512, CCP2 mux = RC1,
    ' PortB reset = Digital, LPT1Osc = Low Pwr, MCLR = Reset, Stack overflow = Ena
    ' LVP = Dis, Enhanced CPU = Dis, All memory = Not Protected
    LED var PORTC.6 ' LED activity indicator
    A var byte
    OSCCON = %01101111 ' 4 MHz
    Test:
    debug "FlashTest", 13, 10
    for a = 0 to 7 : high led : pause 50 : low led : pause 150 : next a
    debug "LED sleep test", 13, 10
    SleepTest:
    high led
    sleep 10
    low led
    pause 10
    goto test
    </endcode>
    Default Re: Cannot wake from SLEEP
    sleep requires you enable WDT
    Something else is needed though. The next code snip hangs at the SLEEP line. WDTCON = 1 turns the SoftWDT on but that does not stop the hang..
    read 47, snooze.byte0
    read 48, snooze.byte1
    gosub lowestpower
    WDTCON = %00000001
    sleep snooze ' SLEEP for SNOOZE time
    WDTCON = %00000001
    gosub runstate
    goto CheckLaunchHour
    endif 'RunFlag = 0 case
    </endcode>
    This next code block works provided there is a WDTCON in the code.
    '* Version : 1.0 *
    '* Notes : *
    DEFINE OSC 4 'Define crystal frequency. Needs setting via OSCCON
    DEFINE DEBUG_REG PORTB 'Debug output pin port
    DEFINE DEBUG_BIT 6 'Debug output pin bit
    DEFINE DEBUG_BAUD 19200 'Debug baud rate
    DEFINE DEBUG_MODE 0 'Debug mode: 0 = True, 1 = Inverted
    A var byte
    WDTCON = %00000001 ' enables SWDT - needs WDT OFF in config
    Test:
    high portb.6 : pause 1 'make the TxD pin an output
    sleep 5
    low led
    goto test
    Dec 2007
    Finland
    How about WDT_ON_2H in CONFIG?
    PICs CONFIGS
    I am using PBP3.0.1.4 with MCSPX 5.0.0.5
    I set the config state through the drop down [C] button that pops up whenever I do a 'compile/program'. There is no choice to set WDT_ON_2H.
    Is WDT_ON_2H a valid directive for a PIC18F4620?
    Dec 2007
    Finland
    Yes it is. Below is part of PIC18F4620.PBPINC from device -folder.
    ;  The #CONFIG block is passed directly to the asm file, but PBP will replace it
    ;  automagically with the contents of a user-defined #CONFIG block if one is
    ;  found in the PBP source program.  There is no need to edit or comment this
    ;  block in this file.  Simply copy it to your source program and edit it there.
            __CONFIG    _CONFIG1H, _OSC_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
            __CONFIG    _CONFIG3H, _CCP2MX_PORTC_3H & _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_ON_3H
            __CONFIG    _CONFIG4L,  _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L
    This is example that I have used with PIC18F4520 and it might be just fine for you too. If not, then change according to your needs.
    At least sleep & nap are working OK, also with interrupt. Check right parameters for CONFIGS from link that I sent earlier (credits to Demon).
        __CONFIG    _CONFIG1H, _OSC_INTIO67_1H
        __CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOREN_OFF_2L
        __CONFIG    _CONFIG3H, _PBADEN_OFF_3H
        __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
  1. Wake from sleep with USB Interrupt
    By kduck63 in forum mel PIC BASIC Pro
    Last Post: - 13th January 2013, 00:59
  2. 16F690... How to wake from sleep?
    By Heckler in forum mel PIC BASIC Pro
    Last Post: - 5th July 2011, 22:07
  3. 16F181: can't wake up from sleep
    By Navaidstech in forum mel PIC BASIC Pro
    Last Post: - 9th January 2010, 04:33
  4. wake up from sleep
    Last Post: - 31st August 2007, 17:09
  5. ? about sleep/wake on pin change and WDT
    By kessral in forum mel PIC BASIC Pro
    Last Post: - 25th January 2007, 23:25
