PIC16F877A Problem in Display LCD 2x16
Results 1 to 6 of 6
    Apr 2013
    Default PIC16F877A Problem in Display LCD 2x16
    Hi everyone
    I'm beginner in PIC and I have problem to display LCD. Here is the code :
    #include<pic.h> //Define PIC Registers
    #include<stdio.h> //Define I/O Functions
    __CONFIG(0x3f72); //Select HS oscillator, Enable (PWRTE,BOREN),
    //Disable (CPD,CP,WDTEN,In-circuit Debugger)
    #define RS RE0 //LCD Register Select
    #define RW RE1 //LCD Read/Write Pin
    #define EN RE2 //LCD Enable Pin
    #define DATA PORTD //LCD Data Port
    #define DATADIR TRISD //LCD Data Port Direction Register
    #define CNTRLDIR TRISE //RS,RW,EN Direction Register
    void lcdinit(void); //LCD initialization Function
    void lcdclr(void); //LCD Clear Function
    void lcdcomd(unsigned char); //LCD Command Declaring Fucntion
    void lcddata(unsigned char); //LCD Data Display Fucntion
    void DelayMs(unsigned int);
    void main()
    int i;
    unsigned char First[]={" PIC DEV. BOARD "};
    unsigned char Secnd[]={"LCD DEMO PROGRAM"};
    DelayMs(500);
    lcdinit();
    DelayMs(500);
    while(1)
    lcdclr();
    lcdcomd(0x80);
    for(i=0;i<16;i++) //Display the Message
    lcddata(First[i]);
    DelayMs(50);
    lcdcomd(0xc0);
    lcddata(Secnd[i]);
    DelayMs(50);
    DelayMs(500);
    void lcdinit(void)
    int i;
    unsigned char command[]={0x38,0x0c,0x06,0x01};
    //LCD Command set for 8 bit Interface, 2 Lines, 5x7 Dots
    ADCON1 = 0x07; //Make PORTE Pin as Digital
    CNTRLDIR = 0x00; //Make LCD control port (PORTE) as output
    DATADIR = 0x00;
    DelayMs(50); //Make LCD Data Port (PORTD) as output port
    for(i=0;i<4;i++)
    lcdcomd(command[i]); //Send the Initialisation Commands
    DelayMs(5);
    DelayMs(500);
    void lcdclr(void) //Send LCD clear command
    lcdcomd(0x01);
    DelayMs(2);
    void lcdcomd(unsigned char cmd)
    RS=0; RW=0; //Select Command Register, R/W--write enabled
    EN=1; //Enable LCD to accept commands
    DATA=cmd;
    EN=0;
    DelayMs(5); //Give a Pulse via Enable pin
    void lcddata(unsigned char byte)
    RS=1; RW=0; //Select Data register, R/W--write enabled
    EN=1;
    DATA=byte; //Give a Pulse via Enable pin
    EN=0;
    DelayMs(5);
    void DelayMs(unsigned int Ms)
    int delay_cnst;
    while(Ms>0)
    Ms--;
    for(delay_cnst = 0;delay_cnst <220;delay_cnst++);
    The code is successfully compile in MPLAB, and also success to display in simulator (proteus). But, I try in real PIC, it can't show anything.
    I really confused about that. I have checked the wiring and I'm sure that it is true. Somebody please.. I need your help.
    Thank you
    May 2007
    Default Re: PIC16F877A Problem in Display LCD 2x16
    C is not understood here.
    Apr 2013
    ah? really?
    picbasic mean pic using basic language?
    oh sorry, fool me.
    I think it's basic level from pic.
    Sep 2010
    Las Vegas, NV
    Try this link http://www.mikroe.com/products/view/...gramming-in-c/. I think it will answer all your questions and maybe you'll vindicate rmteo at the same time.
    Apr 2013
    Okeee thanks ya AvionicsMaster1
    i'll read and search another source of PIC using C
    russellperry's Avatar
    russellperry Guest
    Place a while(true) at the end of main.
    void main()
    lcd_init();
    lcd_putc("\fTesting");
    while(true)
  1. Replies: 3
    Last Post: - 18th September 2012, 08:21
  2. Need advice with LCD 2x16
    By fratello in forum mel PIC BASIC Pro
    Last Post: - 26th April 2011, 06:58
  3. 2x16 lcd problem
    By k3v1nP in forum mel PIC BASIC
    Last Post: - 30th October 2008, 04:46
  4. small 2X16 LCD
    By Ron Marcus in forum Off Topic
    Last Post: - 26th October 2007, 20:37
  5. Problem with 2x16 LCD on 16F630
    By Falcon in forum mel PIC BASIC Pro
    Last Post: - 10th June 2005, 03:25
