PBP3.0.6.1 - USBMOUSE.pbp - compile errors.
Results 1 to 2 of 2
    Feb 2007
    Default PBP3.0.6.1 - USBMOUSE.pbp - compile errors.
    after almost 4 years of absence from this forum I'm back again.
    I have just downloaded the PBP3 (15 day trial) and try to run the "USBMOUSE.pbp".
    I will use the 18F4550 with 20 Mhz quartz: PICDEM FSUSB.
    I have on the my working directory the following file:
    hid_desc.bas
    usb_dev.asm
    usb_dev.inc
    usb_mem.asm
    When compiling, I see the following errors:
    Unable to fit variable USBReservedMemory.
    Macro USBINI? not found in macro file.
    Macro USBSERVICE? not found in macro file.
    Macro USBOUT?CBCL not found in macro file.
    hid_desc (7) : Bad BANK number
    I have loose somethings?
    Bye
    Leo
    Feb 2007
    Default Re: PBP3.0.6.1 - USBMOUSE.pbp - compile errors. CLOSED!
    My mistake.
    I do not have see that was set the default to the 16F628.
    I select 18F4550.
    Compile without errors and now the mouse pointer run squarelly.
    Bye
    Leo
  1. Errors with PBP3 and Microcode 5.0.0.3
    By Ceetee in forum mel PIC BASIC Pro
    Last Post: - 21st October 2013, 13:47
  2. How to Figure Out Compile Errors?
    By RossWaddell in forum mel PIC BASIC Pro
    Last Post: - 25th February 2013, 19:54
  3. Replies: 10
    Last Post: - 11th April 2010, 10:12
  4. USB Mpasm Compile errors
    By JBrannan in forum mel PIC BASIC Pro
    Last Post: - 21st December 2007, 19:13
  5. Replies: 2
    Last Post: - 9th February 2006, 23:03
