need code for ir on/off switch 12f629
Results 1 to 11 of 11
    Oct 2011
    Default need code for ir on/off switch 12f629
    please help i need the code that work with 12f629 for the circuit that work as on \off switch using any remote control (i.e it can save ir command from remot ) i think that i use pulsin command in the program but i am not shure ....
    there are many projects on net about that but it is ending with just hex file without orginal source code please.....please ......our friends
    as example this project
    http://www.ivica-novakovic.from.hr/IrOn-Off-eng.htm
Size:  9.6 KBName:  DimmerTsop250.jpg
    Dec 2012
    Default Re: need code for ir on/off switch 12f629
    check out this site, has alot of interestings dealing with ir.
    http://www.rentron.com/PicBasic/IR_Chips.htm
    also, here's a clip from that site for decoding the IR signal, maybe it'll help you in your setup.
    FOR Index = 0 TO 12 '// Setup to read-in 13 pulses
    PULSIN PORTA.7,0,IR_PULSE[Index] '// Read 13 low-going pulses on RA.7
    NEXT Index '// Loop x times
    DBYTE = $FF '// Start with all 1's and find each 0
    FOR Index = 0 TO 7 '// Get 8 "data" bits
    IF IR_PULSE[Index] < 100 THEN DBYTE.0[Index]=0 '// Less than 1mS = 0
    NEXT Index
    ABYTE = $FF '// Start with all 1's and find each 0 in pattern
    X=0 '// Initialize address bit index pointer to bit 0
    FOR Index = 8 TO 12 '// Get 5 address bits from IR_PULSE bits 8-12
    IF IR_PULSE[Index] < 100 THEN ABYTE.0[X]=0
    X = X + 1 '// Increment address bit index pointer
    NEXT Index
    Oct 2011
    Tank you for this help....i think we need in your code to save the captured data in eeprom memory
    you do not need to ask for any code, as the Hex file to load into your Pic is provided within your link ... !!!
    http://www.ivica-novakovic.from.hr/H...s/IrOn-Off.hex
    just copy and paste it into your programmer ... et voilą !
    Oct 2011
    I know that mr .acetronics and thank you to the hint but i need orginal code to insert it inside my own bigger program that contain more functions..and it does not matter what kind of pic but the idea is how can you capture data from any remote and save it inside the micro( any pic)
    Oct 2009
    Utah, USA
    There is a pretty good APP NOTE over on the Parallax Basic Stamp web site.
    I tried to attach the .pdf file here but it fails.
    If you google "parallax remote ir" you will get a couple of hits on IR protocol and implimenting IR comms using BASIC.
    PBP is quite similar to the BASIC used in the Basic Stamp microcontroller. So it should not be too dificult to apply what is contained in those app notes to PBP.
    Certainly if the Basic Stamp can do it then most any PIC can do it better
    Dwight
    Oct 2011
    Thank you mr.heckler ...it is realy good site and i got some good ideas from it ...and i traid to write code .. but the main proplem is that thair codecs depend on known ir protocol like sony or rc5 but my need is treating with unknown ir protocol (from any remot control) .................realy i spend 10 hour in one set on net and i failed ....thair are many projects about ir dimmer circuit depend on the same idea but the programmers execuse about orginal code and offer just hex file
    Download this file. It explains all these IR stuff you need.
    Oct 2011
    It is still not solved.....
    Feb 2018
    Quote Originally Posted by FADI984 View Post
    Attachment 6834Attachment 6835
    ; IrOn-Off-v2-555.asm
    ; 01feb18
    ; Derived of IrOn-Off.hex from http://www.ivica-novakovic.from.hr/IrOn-Off-eng.htm
    ; Command to compile in Linux:
    ;    gpasm -n IrOn-Off-v2-555.asm -o IrOn-Off-v2-555.hex
        PROCESSOR 12F629
        #INCLUDE p12f629.inc
        ; Watchdog ON
    ;    __CONFIG _CPD_OFF & _CP_OFF & _BODEN_ON & _MCLRE_OFF & _PWRTE_ON & _WDT_ON & _INTRC_OSC_NOCLKOUT
        ; Watchdog OFF
        __CONFIG _CPD_OFF & _CP_OFF & _BODEN_ON & _MCLRE_OFF & _PWRTE_ON & _WDT_OFF & _INTRC_OSC_NOCLKOUT
        ERRORLEVEL -302    ; Don't complain about BANK 1 Registers during assembly
    ; RAM-Variables
    LRAM_0x20 equ 0x20
    LRAM_0x21 equ 0x21
    LRAM_0x22 equ 0x22
    LRAM_0x23 equ 0x23
    LRAM_0x28 equ 0x28
    LRAM_0x32 equ 0x32      ; temporary register to store data (between swapping bytes for example)
    ; Address 0x3A...0x43 (10 bytes) is a buffer that stores the received IR stream code, to handling
    LRAM_0x44 equ 0x44
    LRAM_0x45 equ 0x45
    LRAM_0x46 equ 0x46
    LRAM_0x47 equ 0x47
    LRAM_0x4A equ 0x4A
    LRAM_0x4B equ 0x4B
    LRAM_0x4C equ 0x4C
    LRAM_0x4D equ 0x4D
    LRAM_0x50 equ 0x50       ; bit 0 = NoToggle flag (enable (bit 0 = 0) or disable (bit 0 = 1) the PIC's output invertion)
    LRAM_0x52 equ 0x52
    LRAM_0x53 equ 0x53
    LRAM_0x5D equ 0x5D       ; Counter. Used as byte counter and index by the handler routines of the IR stream
    LRAM_0x5E equ 0x5E
    ; Defines
    #DEFINE selBank0    BCF   STATUS,RP0    ; select RAM bank 0
    #DEFINE selBank1    BSF   STATUS,RP0    ; select RAM bank 1
    #DEFINE ON_OFF      GPIO,0              ; on/off output
    #DEFINE LED         GPIO,2
    #DEFINE PRG_BUTTON  GPIO,4              ; programming button
    #DEFINE IR_RECV     GPIO,5              ; input pin for command received from ir receiver
    ; Constants
    OUT_PIN    equ 0         ; saida para o acionamento/desligamento (GPIO0)
    IRREC_PIN  equ 5         ; entrada do codigo recebido pelo receptor infravermelho (12F629 pin 2 - GPIO5)
    PRG_BTN    equ 4         ; programming button (12F629 pin 3 - GPIO4)
    LED_PIN    equ 2         ; IO do LED indicador da recepcao/programacao (GPIO2)
    ; Start of code
        ORG    H'0000'
    ;   Reset-Vector
        GOTO   LADR_0x005A   ; goes to the beginning of the program
        NOP
        NOP
        NOP
    ;   Interrupt-Vector
        RETFIE               ; ignore interrupts
    ; Reads EEPROM memory
    ; Input: W contains EEPROM address to read
    ; Output: W contains the data read
    LADR_0x0001
        BSF    STATUS,RP0    ; select bank 1
        MOVWF  EEADR         ; copy address in EEADR
        BSF    EECON1,0      ; prepara leitura
        MOVF   EEDATA,W      ; loads data in EEPROM into W register
        GOTO   LADR_0x0055   ; returns to RAM bank 0 and exits of this sub-routine
    ; Writes a data (W value) in internal EEPROM
    LADR_0x0006
        MOVWF  EEDATA        ; copy data in EEDATA
        BSF    EECON1,2      ; enable writing in EEPROM
        ; DO NOT CHANGE THIS INSTRUCTIONS ORDER!
        MOVLW  0x55          ; writing initiate (!!! REQUIRED SEQUENCE #1 !!!)
        MOVWF  EECON2        ; !!! REQUIRED SEQUENCE #2 !!!
        MOVLW  0xAA          ; !!! REQUIRED SEQUENCE #3 !!!
        MOVWF  EECON2        ; !!! REQUIRED SEQUENCE #4 !!!
        BSF    EECON1,1      ; write dada into EEPROM (!!! REQUIRED SEQUENCE #5 !!!)
        BCF    EECON1,2      ; clears WREN flag (!!! REQUIRED !!!)
    ; Waits writting have been finished
    LADR_0x000E
        BTFSC  EECON1,1      ; is the writing completed?
        GOTO   LADR_0x000E   ; no, then waits
        GOTO   LADR_0x0055   ; yes, then returns to RAM bank 0 and exits from this sub-routine
    ; Parece ser um timer com W contendo o tempo da pausa
    LADR_0x0013
        MOVWF  LRAM_0x22
    LADR_0x0014
        MOVLW  0xFF          ;   b'11111111'  d'255'
        ADDWF  LRAM_0x22,F
        BTFSS  STATUS,C
        ADDWF  LRAM_0x23,F
        BTFSS  STATUS,C
        GOTO   LADR_0x0055
        MOVLW  0x03          ;   b'00000011'  d'003'
        MOVWF  LRAM_0x21
        MOVLW  0xDF          ;   b'11011111'  d'223'
        CALL   LADR_0x0020
        GOTO   LADR_0x0014
    LADR_0x0020
        ADDLW  0xE8          ;   b'11101000'  d'232'
        MOVWF  LRAM_0x20
        COMF   LRAM_0x21,F
        MOVLW  0xFC          ;   b'11111100'  d'252'
        BTFSS  STATUS,C
        GOTO   LADR_0x0029
    LADR_0x0026
        ADDWF  LRAM_0x20,F
        BTFSC  STATUS,C
        GOTO   LADR_0x0026
    LADR_0x0029
        ADDWF  LRAM_0x20,F
    ;    CLRWDT
        INCFSZ LRAM_0x21,F
        GOTO   LADR_0x0026
    LADR_0x002F
        BTFSS  LRAM_0x20,1
        GOTO   LADR_0x0033
        NOP
        GOTO   LADR_0x0033
    LADR_0x0033
    LADR_0x0034
        BCF    STATUS,C
        RRF    LRAM_0x21,F
        RRF    LRAM_0x20,F
        ADDLW  0xFF          ;   b'11111111'  d'255'
        BTFSC  STATUS,C
        GOTO   LADR_0x0034
        MOVF   LRAM_0x20,W
        GOTO   LADR_0x0055
    LADR_0x003C
        MOVWF  LRAM_0x22
        GOTO   LADR_0x0045
    LADR_0x003F
        MOVWF  LRAM_0x22
        MOVLW  0x01          ;   b'00000001'  d'001'
        GOTO   LADR_0x0045
    SubRout_04
        MOVF   LRAM_0x47,W
        MOVWF  LRAM_0x23
        MOVF   LRAM_0x46,W
    LADR_0x0042
        MOVWF  LRAM_0x22
        MOVLW  0x06          ;   b'00000110'  d'006'
    LADR_0x0045
        MOVWF  LRAM_0x28
        MOVF   LRAM_0x23,W
        SUBWF  LRAM_0x21,W
        BTFSS  STATUS,Z
        GOTO   LADR_0x004C
        MOVF   LRAM_0x22,W
        SUBWF  LRAM_0x20,W
    LADR_0x004C
        MOVLW  0x04          ;   b'00000100'  d'004'
        BTFSC  STATUS,C
        BTFSC  STATUS,Z
        MOVLW  B'00000010'   ; bitmask
        ANDWF  LRAM_0x28,W
        BTFSS  STATUS,Z
    LADR_0x0055
    ;    BCF    STATUS,IRP    ;
    ;    BCF    STATUS,RP0    ;
        BCF    STATUS,RP0    ; returns to RAM bank 0
    ;    CLRWDT               ; resets watchdog timer
    ; Sets up GPIO's and SFR's (program start)
    LADR_0x005A
        CLRF   INTCON        ; disable all interrupts
        CLRF   T1CON         ; stops TMR1
        BCF    PIR1,0        ; clears TMR1 overflow flag
        MOVLW  B'00000111'   ; bitmask
        MOVWF  CMCON         ; disable comparators
        CLRF   GPIO          ; let all outputs pins in low level
        BCF    OPTION_REG,7  ; enable internal pull-up resistors
        MOVLW  B'00110010'   ; bitmask
        MOVWF  WPU           ; internal pull-ups resistors enabled on pins 2, 3 and 6 (IR data, programming button and 555 output)
        MOVWF  GPIO          ; turns pins 2, 3 and 6 as inputs, another all pins as outputs
        CALL   0x03FF        ; gets calibration value
        MOVWF  OSCCAL        ; copy it in OSCCAL
        BCF    STATUS,RP0    ; returns to bank 0
        CLRF   LRAM_0x50     ; o bit 4 deste endereco _PARECE_ conter um flag que indica o recebimento de dados ou nivel baixo pelo pino 2
    ; Program loop?
    LADR_0x007C
        CALL   LADR_0x0203   ; checks if programming button has been pressed
        CALL   LADR_0x0122   ; checks if remote controler was actived
    ;    CLRWDT               ; keeps WDT reseted
        BTFSC  LRAM_0x50,4   ; this is a flag?
        CALL   LADR_0x0084
        GOTO   LADR_0x007C
    LADR_0x0084
        BSF    GPIO,2        ; turn on LED on 12F629 pin 5 (indicating that the remote control has been pressed)
        CALL   Upd_LED       ; updates 12F629 pin 5
        CLRF   LRAM_0x5D     ; EEPROM initial address
    LADR_0x0089
        CALL   Counter_Test
        BTFSC  STATUS,C      ; is index < 10?
        GOTO   LADR_0x009E   ; no, the last byte in EEPROM and RAM was compared and are equals
        MOVF   LRAM_0x5D,W   ; yes, then copy index value to W
        CALL   LADR_0x0001   ; gets byte in EEPROM
        MOVWF  LRAM_0x53     ; copy it in address 0x53
        MOVF   LRAM_0x5D,W   ; restore index value in W register
        ADDLW  0x3A          ; pointer to IR stream data address in RAM
        MOVWF  FSR
        MOVF   INDF,W        ; gets byte in address indicated by FSR
        MOVWF  LRAM_0x32     ; copy it to address 0x32
    ;    CLRWDT
        MOVF   LRAM_0x53,W
        SUBWF  LRAM_0x32,W   ; compares byte stored in EEPROM IR stream data with the byte written in RAM IR stream data
        BTFSS  STATUS,Z      ; bytes are equal?
        GOTO   LADR_0x00A3   ; bytes are different (wrong IR code)
    LADR_0x009C
        INCFSZ LRAM_0x5D,F   ; increments index (next byte)
        GOTO   LADR_0x0089   ; gets next byte to compare
    ; If IR stream code is right, then toggle output
    LADR_0x009E
        CALL   Toggle_Output ; inverts output (pin 7) status
    LADR_0x00A3
        BCF    LRAM_0x50,4
        MOVLW  0x01
        MOVWF  LRAM_0x44     ;   b'00000001'  d'001'
        CLRF   LRAM_0x45     ;   b'00000000'  d'000'
    LADR_0x00A7
        CALL   SubRout_02
        BTFSS  STATUS,Z
        GOTO   LADR_0x00B9
    ;    CLRWDT
        BTFSS  GPIO,5
        BSF    LRAM_0x50,4
    LADR_0x00B5
        ; incrementa 16 bits contido em 0x45,0x44 (MSB,LSB)
        INCF   LRAM_0x44,F
        BTFSC  STATUS,Z      ; testa 256
        INCFSZ LRAM_0x45,F   ; incrementa 0x45 (byte high) se 0x44 (byte low) = 256
        GOTO   LADR_0x00A7
    LADR_0x00B9
    ;    CLRWDT
        BTFSC  LRAM_0x50,4
        GOTO   LADR_0x00A3
    LADR_0x00BD
        MOVWF  LRAM_0x44
        CLRF   LRAM_0x45
    LADR_0x00C0
        CALL   SubRout_02
        BTFSS  STATUS,Z
        GOTO   LADR_0x00D2
    ;    CLRWDT
        BTFSS  GPIO,5
        GOTO   LADR_0x00A3   ;
    LADR_0x00CE
        INCF   LRAM_0x44,F
        BTFSC  STATUS,Z
        INCFSZ LRAM_0x45,F
        GOTO   LADR_0x00C0
    LADR_0x00D2
        BCF    GPIO,2        ; turn off LED on pin 5
        GOTO   Upd_LED       ; updates LED status
    LADR_0x00D7
        CLRF   LRAM_0x5D     ; initializes index counter with 0
    ; Fills 10 bytes in RAM (IR stream data buffer) with 0xFF
    LADR_0x00D8
        CALL   Counter_Test  ; stream end test
        BTFSC  STATUS,C
        GOTO   LADR_0x00E4
        MOVF   LRAM_0x5D,W
        ADDLW  0x3A          ; pointer to IR stream data in RAM
        MOVWF  FSR           ; FSR now has the address to write
        MOVLW  0xFF          ; value to fill stream data into RAM
        MOVWF  INDF          ; write 0xFF into address indicated by FSR
        INCFSZ LRAM_0x5D,F   ; index++
        GOTO   LADR_0x00D8   ; next write (to until 10 bytes)
    LADR_0x00E4
        CLRF   LRAM_0x44
        CLRF   LRAM_0x45
    LADR_0x00E6
        INCF   LRAM_0x44,F
        BTFSC  STATUS,Z
        INCF   LRAM_0x45,F
        CALL   LADR_0x0122
    ;    CLRWDT               ; for debug only
        BTFSC  LRAM_0x50,4
        GOTO   LADR_0x00FA
        MOVF   LRAM_0x44,W
        MOVWF  LRAM_0x20
        MOVF   LRAM_0x45,W
        MOVWF  LRAM_0x21
        MOVLW  0xFD          ;   b'11111101'  d'253'
        MOVWF  LRAM_0x23
        MOVLW  0xE8          ;   b'11101000'  d'232'
        CALL   LADR_0x003C
        BTFSS  STATUS,Z
        GOTO   LADR_0x0119
        GOTO   LADR_0x00E6
    ; Starts the stream writing (copy) from RAM to the EEPROM
    LADR_0x00FA
        CALL   Upd_LED       ; updates LED status
        CLRF   LRAM_0x5D     ; initializes index/byte counter with zero
    ; Copy 10 bytes from RAM (address 3Ah up to 43h) to EEPROM
    LADR_0x00FF
        CALL   Counter_Test  ; checks if index/byte counter reached the end (LRAM_0x5D = 10)
        BTFSC  STATUS,C      ; skip if no
        GOTO   LADR_0x0111   ; writing has ended
        MOVF   LRAM_0x5D,W
        ADDLW  0x3A          ; adds counter value with address of the first stream byte in RAM, to get the address of byte to read
        MOVWF  FSR
        MOVF   INDF,W        ; gets byte to copy
        MOVWF  LRAM_0x32     ; copy it to address 32h
        MOVF   LRAM_0x5D,W   ; copy counter value (index) to W register
        MOVWF  EEADR         ; copy counter value (index) to EEADR
        MOVF   LRAM_0x32,W
        CALL   LADR_0x0006   ; writes byte in EEPROM
        INCFSZ LRAM_0x5D,F   ; next byte
        GOTO   LADR_0x00FF
    LADR_0x0111
        MOVWF  LRAM_0x23
        MOVLW  0xF4          ;   b'11110100'  d'244'
        CALL   LADR_0x0013
        BSF    GPIO,2        ; turn on LED on pin 5
    LADR_0x0119
        MOVWF  LRAM_0x23
        CALL   LADR_0x0013
    LADR_0x0122
        BCF    LRAM_0x50,4   ; resets stream end flag
        BTFSC  GPIO,5        ;
        RETURN               ;
    LADR_0x0128
        CALL   Start_TMR1
        CALL   Wait_IRHigh   ; waits IR pin to return for level high
        CALL   Stop_TMR1     ; stops TMR1 and copy it to LRAM_0x4A/LRAM_0x4B and LRAM_0x20/LRAM_0x21
        MOVWF  LRAM_0x23
        MOVLW  0x5E          ;   b'01011110'  d'094'  "^"
        CALL   LADR_0x003C
        BTFSC  STATUS,Z
    LADR_0x0144
        CALL   SubRout_03
        MOVWF  LRAM_0x23
        MOVLW  0xE2          ;   b'11100010'  d'226'
        CALL   LADR_0x003C
        BTFSS  STATUS,Z
        GOTO   LADR_0x0153
        MOVWF  LRAM_0x46
        MOVWF  LRAM_0x47
        GOTO   LADR_0x0180
    LADR_0x0153
        CALL   SubRout_03
        MOVLW  0x0A          ;   b'00001010'  d'010'
        MOVWF  LRAM_0x23
        MOVLW  0x8C          ;   b'10001100'  d'140'
        CALL   LADR_0x003C
        BTFSS  STATUS,Z
        GOTO   LADR_0x0162
        MOVLW  0x84          ;   b'10000100'  d'132'
        MOVWF  LRAM_0x46
        MOVWF  LRAM_0x47
        GOTO   LADR_0x0190
    LADR_0x0162
        CALL   SubRout_03
        MOVLW  0x0C          ;   b'00001100'  d'012'
        MOVWF  LRAM_0x23
        MOVLW  0xE4          ;   b'11100100'  d'228'
        CALL   LADR_0x003C
        BTFSS  STATUS,Z
        GOTO   LADR_0x0171
        MOVLW  0xEE          ;   b'11101110'  d'238'
        MOVWF  LRAM_0x46
        MOVLW  0x02          ;   b'00000010'  d'002'
        MOVWF  LRAM_0x47
        GOTO   LADR_0x0190
    LADR_0x0171
        CALL   SubRout_03
        MOVWF  LRAM_0x23
        CALL   LADR_0x0042
        BTFSS  STATUS,Z
        GOTO   LADR_0x0180
        MOVLW  0xB0          ;   b'10110000'  d'176'
        MOVWF  LRAM_0x46
        MOVWF  LRAM_0x47
        GOTO   LADR_0x0188
    LADR_0x0180
        CALL  Wait_IRLow
        CALL  Wait_IRHigh
    LADR_0x0188
        CALL  Wait_IRLow
        CALL  Wait_IRHigh
    LADR_0x0190
    LADR_0x0191
        CALL   Counter_Test  ; test for stream data end
        BTFSC  STATUS,C      ; has stream data ended?
        GOTO   LADR_0x0201   ; no,
        MOVLW  0x01
        MOVWF  LRAM_0x5E
    LADR_0x0198
        MOVLW  0x05          ;   b'00000101'  d'005'
        SUBWF  LRAM_0x5E,W
        BTFSC  STATUS,C
        GOTO   LADR_0x01FF
        CALL   Start_TMR1
    ; Checks end of IR command
    LADR_0x01A5
        BTFSS  GPIO,5        ; checks if pin 2 of 12F629 is high
        GOTO   LADR_0x01B0   ; pin 2 of 12F629 is low
        MOVLW  0x07          ; test for de TMR1 byte high
        SUBWF  TMR1H,W       ; the carry flag will be set if TMR1H >= 7
        BTFSS  STATUS,C      ;
        GOTO   LADR_0x01A5   ;
    LADR_0x01B0
        CALL   SubRout_04
        BTFSS  STATUS,Z
        GOTO   LADR_0x01C8
        BSF    LRAM_0x52,7
        GOTO   Jump_01
    LADR_0x01C8
        BCF    LRAM_0x52,7
    Jump_01
        CALL   SubRout_01
    ; Starts length measuring, in TMR1, of level low on 12F629 pin 2
        CALL   Start_TMR1
        CALL   Wait_IRHigh
        CALL   Stop_TMR1
        CALL   SubRout_04
        BTFSS  STATUS,Z
        GOTO   LADR_0x01F5
        BSF    LRAM_0x52,7
        GOTO   Jump_02
    LADR_0x01F5
        BCF    LRAM_0x52,7
    Jump_02
        CALL   SubRout_01
        INCFSZ LRAM_0x5E,F
        GOTO   LADR_0x0198
    LADR_0x01FF
        INCFSZ LRAM_0x5D,F
        GOTO   LADR_0x0191
    LADR_0x0201
        BSF    LRAM_0x50,4
    ; Checks if programming button is pressed
    LADR_0x0203
        BTFSC  GPIO,4        ; is pressed the programming button?
        RETURN               ; no
    ; Starts programming procedure
    LADR_0x0207
        MOVWF  LRAM_0x4C
        CLRF   LRAM_0x4D
    LADR_0x020A
        MOVF   LRAM_0x4C,W
        MOVWF  LRAM_0x20
        MOVF   LRAM_0x4D,W
        MOVWF  LRAM_0x21
        MOVLW  0x13          ;   b'00010011'  d'019'
        MOVWF  LRAM_0x23
        MOVLW  0x88          ;   b'10001000'  d'136'
        CALL   LADR_0x003F
        BTFSS  STATUS,Z
        GOTO   LADR_0x021C
        GOTO   LADR_0x0203   ; no
        INCF   LRAM_0x4C,F   ; yes
        BTFSC  STATUS,Z
        INCFSZ LRAM_0x4D,F
        GOTO   LADR_0x020A
    LADR_0x021C
        CALL   Upd_LED       ; updates LED status on 12F629 pin 5
        CALL   LADR_0x00D7
        BCF    GPIO,2        ; turn off LED on 12F629 pin 5
    ; Updates LED status
    Upd_LED
        BCF    GPIO,2
    ; Dois pontos do programa usa esta sub-rotina
    SubRout_01
        MOVF   LRAM_0x5D,W
        ADDLW  0x3A          ;   b'00111010'  d'058'  ":"
        MOVWF  FSR
        MOVF   LRAM_0x52,W
        MOVWF  INDF
        BCF    STATUS,C      ; clears bit
        RRF    LRAM_0x52,F   ; read bit in carry flag
    SubRout_02
        MOVF   LRAM_0x44,W
        MOVWF  LRAM_0x20
        MOVF   LRAM_0x45,W
        MOVWF  LRAM_0x21
        MOVWF  LRAM_0x23
        GOTO   LADR_0x003F
    ; Clears TMR1 and LRAM_0x4A/LRAM_0x4B and starts TMR1
    Start_TMR1
        BCF    PIR1,0        ; clears the TMR1 overflow flag
        MOVLW  0x00
        MOVWF  LRAM_0x4A     ; clears LRAM_0x4A
        MOVWF  LRAM_0x4B     ; clears LRAM_0x4B
        MOVWF  TMR1L         ; clears TMR1L
        MOVWF  TMR1H         ; clears TMR1H
        BSF    T1CON,0       ; enable TMR1 counting
    ; Stops TMR1, copy it to LRAM_0x4A/LRAM_0x4B and LRAM_0x20/LRAM_0x21
    Stop_TMR1
        BCF    T1CON,0       ; stops TMR1
        MOVF   TMR1L,W
        MOVWF  LRAM_0x4A     ; copy TMR1L in LRAM_0x4A
        MOVF   TMR1H,W
        MOVWF  LRAM_0x4B     ; copy TMR1H in LRAM_0x4B
    ; Copy LRAM_0x4A/LRAM_0x4B in LRAM_0x20/LRAM_0x21
    SubRout_03
        MOVF   LRAM_0x4A,W
        MOVWF  LRAM_0x20
        MOVF   LRAM_0x4B,W
        MOVWF  LRAM_0x21
    ; Waits IR pin go to level low
    Wait_IRLow
        BTFSC  GPIO,5        ; is IR out pin low?
        GOTO   Wait_IRLow    ; no
        RETURN               ; yes
    ; Waits IR pin go to level high
    Wait_IRHigh
        BTFSS  GPIO,5        ; is IR out pin high?
        GOTO   Wait_IRHigh   ; no
        RETURN               ; yes
    ; Checks if counter reached the end (.10)
    ; Returns carry flag = 1 if yes
    Counter_Test
        MOVLW  .10           ; counter end limit
        SUBWF  LRAM_0x5D,W   ; compares LRAM_0x5D with .10
    ; Inverts PIC12F629 output (pin 7) state
    Toggle_Output
        MOVLW  B'00000001'   ; bitmask
        XORWF  GPIO,F        ; toggle output state
        BCF    GPIO,0        ; updates the output with the new level
    vanmgman's Avatar
    vanmgman Guest
    Hello all, I am also on the Lookout for CODE similar to what the original Poster Asks..
    Seems Alot of confused replies, pointing to a HEX file to program, that is NOT what I or the Original Poster is looking for.
    FADI984 posted Code, which is VERY close to the Required CODE to operate the circuit that is at :
    However FADI984's Code appears to be only 1 channel Control Likely the "IrOn-Off" one channel at the above site.
    I am looking for CODE for the IrOn-Off v.2 infrared control (Same Site, lower down.. )
    I would like to make some small modifications to the Code, a simple Maximum On Time limit / relay, and as well a Make / Break (Only 1 relay on.. ) function change..
    The Importance of the CODE to learn / store the IR code is what is asked in the original post, that is also Tantamount for my modification.
    D.
  1. Toggle switch (latching switch) state
    By craigwb in forum General
    Last Post: - 6th November 2011, 14:18
  2. Switch sensor vs. switch PIC pin
    By fratello in forum Schematics
    Last Post: - 4th August 2011, 11:17
  3. Replies: 6
    Last Post: - 9th January 2011, 15:26
  4. Replies: 6
    Last Post: - 20th September 2008, 12:28
  5. Rotary Hex Dip Switch Code???
    By dangill in forum mel PIC BASIC Pro
    Last Post: - 13th March 2008, 13:30
