C library calls with PBP
Results 1 to 3 of 3
    Default C library calls with PBP
    Working on a project with a fellow that uses C on his PIC projects. He has a couple of C library's I want to call in my PBP code. Is that possible? If so where can I go to learn about it? I am assuming I will use the 'INCLUDE' command and a few other tricks.
    Thank you in advance
    Default Re: C library calls with PBP
    Quote Originally Posted by Tobias View Post
    PBP cannot call a C library.
    You would need to port the library to basic.
    Their may be a small chance you could use the compiled assembly of the C library however it's probably going to require some extensive knowledge of assembly .
    Basic is faster and easier however Microchips extensive C libraries aren't available for basic.
    Norm
    Not what I was hoping to hear but non the less thanks for the quick reply
  1. Replies: 3
    Last Post: - 23rd May 2014, 04:43
  2. pbp and linux
    By Chirpy in forum mel PIC BASIC Pro
    Last Post: - 17th December 2012, 23:37
  3. PBP and DT_INTs problems
    By comwarrior in forum mel PIC BASIC Pro
    Last Post: - 14th December 2012, 12:45
  4. Replies: 1
    Last Post: - 30th October 2012, 10:28
  5. Library tools? Library Specs?
    By PickyBiker in forum mel PIC BASIC Pro
    Last Post: - 21st May 2010, 03:54
