Remove Text Formatting
Loading...
+ Reply to Thread
Results 1 to 8 of 8
    Jun 2012
    Unhappy Ultrasonic [HC-SR04] + PIC16F877A
    help me Please
    it code don't work
    it's wrong
    INCLUDE "modedefs.bas"
    define osc 4
    w var word
    r var word
    a var word
    tr var PORTA.0 'Trig pin
    ec var PORTA.1 ' Echo pin
    TRISA = %00000010
    TRISB = %00000000
    PORTB = %00000000
    w = 0
    Main :
    low tr
    high tr
    pauseus 10
    low tr
    pulsin ec,1,w
    r = w/58
    if r < 10 then
    PORTB = %11111111
    pause 200
    Sorry I bad eng
    data sheet HC-SR04
    https://www.google.co.th/url?sa=t&rc...55325884,d.bmk
    Oct 2011
    Default Re: Ultrasonic [HC-SR04] + PIC16F877A
    The PortA pins are analogue and you need to set them to digital with the ADCON1 register
    ADCON1 = %00000110 - see datasheet
    Or you could use PortB for trig and echo
    Phil
    Jun 2012
    Quote Originally Posted by Sherbrook View Post
    Phil
    thanks
    but don't work
    Nov 2007
    West Covina, CA
    You will also need to change your oscillator to a higher frequency for two reasons:
    1. PAUSEUS min time is 24us at 4MHz
    2. PULSIN resolution is 10us at 4MHz
    I would suggest changing your crystal or resonator to 20MHz so PAUSEUS 10 will work and PULSIN resolution will be 2us.
    Then try your modified code to see if it works:
    PORTA = %00000000
    TRISA = %00000010       ' Bit 1 set as input
    PORTB = %00000000
    TRISB = %00000000
    ADCON0.0 = 0            ' A/D module disabled
    define osc 20
    w var word
    r var word
    a var word
    tr var PORTA.1 'Trig pin
    ec var PORTA.2 ' Echo pin
    w = 0
    low tr
    Main :
        high tr
        pauseus 10          ' Minimum 3us at 20MHz
        low tr
        pulsin ec,1,w
        r = w/29            ' Divide by 29, PULSIN resolution is 2us. 1 count every 2us
        if r < 10 then
        PORTB = %11111111   ' Turn ON all PORTB outputs
        pause 200
        PORTB = %00000000   ' Turn OFF all PORTB outputs
    Louie
    Oct 2011
    Have you set the configuration of the oscillator correct
    See datasheet - Special features of the CPU
    Oct 2011
    This works on PIC16F873A so should work on PIC16F877A
    Don't forget to pull MCLR high
    @ DEVICE PIC16F873A, HS_OSC 'Xtal OSC
    @ DEVICE PIC16F873A, WDT_OFF 'WDT off
    @ DEVICE PIC16F873A, PWRT_ON 'Power-up timer on
    @ DEVICE PIC16F873A, BOD_OFF 'Brown-out detect off
    ADCON1 = %00000110 'All PORTA digital
    define osc 4
    TRISA = %00000010
    TRISB = %00000000
    PORTB = %00000000
    w var word
    r var word
    a var word
    ec var PORTA.1 'Echo pin
    PORTB = %11111111 'Flash LED on PORTB
    pause 500 'to check PIC running
    PORTB = %00000000
    w = 0
    low tr
    Main :
    high tr
    pauseus 10
    low tr
    pulsin ec,1,w
    r = w/58
    if r < 10 then
    PORTB = %11111111
    PORTB = %00000000
    pause 200
    Jun 2012
    define osc 4
    TRISA = %00000010
    TRISB = %00000000
    PORTB = %00000000
    w var word
    r var word
    a var word
    PORTB = %00000000
    w = 0
    low tr
    Main :
    high tr
    pauseus 10
    low tr
    pulsin ec,1,w
    r = w/58
    if r < 10 then
    PORTB = %11111111
    PORTB = %00000000
    pause 200
    Oh!! Thanks IT work
    But edit code r = w/58 >> r = ((w*10)/58)
    Thank you very much Sherbrook & LinkMTech
    Aug 2014
    Try the following link, it might help you
    Interfacing HC-SR04 Ultrasonic Sensor with PIC Microcontroller
  1. pic16f690 and ultrasonic tranducers
    By Nyaberi in forum Code Examples
    Last Post: - 3rd September 2012, 16:23
  2. Ultrasonic range meter
    By Crista in forum mel PIC BASIC Pro
    Last Post: - 16th June 2008, 18:01
  3. Replies: 9
    Last Post: - 4th February 2008, 20:12
  4. ultrasonic sensor
    By PoTeToJB in forum mel PIC BASIC Pro
    Last Post: - 9th May 2006, 20:26
  5. SRF08 Ultrasonic Rangefinder
    By rad in forum mel PIC BASIC Pro
    Last Post: - 25th July 2003, 21:01
