basic question about OSCCON and HS_OSC
Results 1 to 6 of 6
    Default basic question about OSCCON and HS_OSC
    this is probably a pretty dumb question, but i have gotten rusty on PBP
    i have a design with the 16F819 chip and it was using INT OSC at 8MHz
    now i have a 20MHz resonator
    when i changed the DEFINE from
    INTRC_OSC_NOCLKOUT
    to
    HS_OSC
    it got me wondering what exactly happens with the OSCCON register ?
    is it now ignored?
    i looked at the data sheet and perhaps missed it but i could not see where it says anything about this the operations of the internal oscillator when an external xtal is used
    (i did determine by other means that the chip is running at 20MHz)
    is the int osc shut down or gated out entirely ?
    do any of the OSCCON bits now matter ?
    also with a 20MHz resonator (w/ internal caps) when i probe either pin with a scope it kills the oscillation, this is not hugely surprising but it got me wondering about whether for a resonator i should be using XT_OSC rather than HS_OSC
    as far as i know the HS is not for speed per se but rather for a drive level more appropriate for a higher freq xtal
    and lastly in the M16F81X.INC file i notice
    EC_OSC
    what is that ? i don't recall that one
    thanks
    Default Re: basic question about OSCCON and HS_OSC
    Quote Originally Posted by dsicon View Post
    As they say, there are no dumb questions.
    INTRC_OSC_NOCLKOUT
    to
    HS_OSC
    is it now ignored?
    Take a look at FIGURE 4-6 in the data sheet. The internal OSC is always running, the WDT works from it. The OSCCON is not ignored when HS is selected, just the internal OSC is not used as the main clock. The OSCCON bits do not matter when anything but the internal OSC is used.
    HS is the correct selection with resonators.
    EC_OSC
    thanks
    EC is for when an external clock source is used. Look at section 4.3 in the data sheet.
    Tip: To prevent killing the OSC with your probe, you want to use a 10x (or more) probe, and monitor the OSC2/CLKO pin.
    Hi Steve
    i do know about those 2 issues, pretty sure it was 10x probe, will double check and use a better scope too, if it actually was 10x that worries me a little about the drive level, will let you know
    Hi Dave and thank
    re EC, got it, rings a bell now, told you i got rusty
    re OSCCON i pretty much got it now but in your reply don't you say something contradictory ?
    you say 'OSCCON is not ignored ... '
    and you also say 'OSCCON bits do not matter ...'
    It is not ignored as far as the chip is concerned, the register is set either by you or by default, if you do not use the register then it does not matter how it is set.
  1. Basic USB question(s)
    By muddy0409 in forum USB
    Last Post: - 20th May 2009, 21:19
  2. @ Device Pic16f84a, Hs_osc
    By chip_select in forum mel PIC BASIC Pro
    Last Post: - 29th March 2008, 17:26
  3. what does OSCCON = $60 mean exactly?
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 20th December 2005, 09:40
  4. I have there once a question to pic-Basic
    By zugvogel1 in forum mel PIC BASIC Pro
    Last Post: - 12th February 2005, 19:06
  5. very basic question
    By scorpion in forum mel PIC BASIC Pro
    Last Post: - 24th November 2004, 10:25
