Timer 3 config for HPWM using remappable pins
Results 1 to 2 of 2
    Sep 2009
    South Wales (UK)
    Default Timer 3 config for HPWM using remappable pins
    Hi all,
    Hope everyone has their Xmas wishlist prepared for Santa :P
    Quick question... trying to use Timer3 on an 18F26J53 together with HPWM command to make an LED go dim/bright/dim/bright etc...
    Code snippet:
    EECON2 = $55
    EECON2 = $AA
    PPSCON.0 = 0
    RPOR4 = 19
    EECON2 = $55
    EECON2 = $AA
    PPSCON.0 = 1
    CCP2CON = %00001100
    PSTR2CON = %00000010
    CCPTMRS0 = %00001000
    t3con = %01001101
    loop1:
    SEROUT2 Serial_out,84,[$a,$d,dec RPOR4," ",bin8 CCPTMRS0]
    hpwm 2,127,1000
    hpwm 2,255,1000
    goto loop1
    Is there anything obviously wrong? I'm setting the remappable pin B1 for ECCP2, channel 2, etc, just can't get the LED to light using PWM.
    Many thanks in advance
    Jimbo
    Sep 2009
    South Wales (UK)
    Default Re: Timer 3 config for HPWM using remappable pins
    ... perhaps I'm misunderstanding the use of the HPWM command?
    Is 'channel 2' on HPWM the same as using ECCP2?
    - Jimbo -
  1. Timer based PWM with HPWM
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2011, 05:16
  2. 18F25J11 RTCC & remappable pin options
    By jonas2 in forum mel PIC BASIC Pro
    Last Post: - 27th February 2011, 10:20
  3. 18F25J11 RTCC & remappable pin options
    Last Post: - 26th February 2011, 10:51
  4. HPWM and timer 1 on pic16f77
    By n qwerty in forum mel PIC BASIC Pro
    Last Post: - 17th April 2008, 13:30
  5. Setting up 5 HPWM pins on 18F4680
    By tcbcats in forum mel PIC BASIC Pro
    Last Post: - 2nd August 2006, 06:54
