Shiftout data needs to be sent on rising edge of clock
Results 1 to 10 of 10
    Feb 2012
    Default Shiftout data needs to be sent on rising edge of clock
    I have a chip that needs to read SPI data on the rising edge of the clock. The shiftout command seems to always send the data on the falling edge and I can't find any settings to change that. The Shiftin command allows for read either before or after sending the clock signal. Any Suggestions?
    Jim
    Default Re: Shiftout data needs to be sent on rising edge of clock
    Hi Jim,
    According to the manual both MODE 0 (LSBFIRST) and 1 (MSBFIRST) idles the clock LOW.
    For Modes 0-1, the clock idles low, toggles high to clock in a bit, and then returns low. For Modes 4-5, the clock idles high, toggles low to clock in a bit, and then returns high.
    Are you saying that, when using either MODE 0 or 1, the databit isn't true on the rising edge?
    Feb 2012
    Henrik,
    Yes, on Mode 1 the databit is just starting to climb. Any bit following a zero doesn't register, but if two bits in a row are sent the second one will register since the data stays high.
    I am using Mode 1 (MSB first, Clock idles low). The clock should be low when not in use so I never tried mode 5. The chip I am trying to control echos the data back that it received. When hooked up to a scope I can see the data being sent is on the falling edge and the data I read back from the chip shows a weak signal where it should show high (similar to the rising edge data just starting to climb).
    Shiftin seems to have more options.
    Jim
    The shiftin command has an option to read either before or after sending the clock (Which to me sounds more like the rising or falling edge).
    Hi Jim,
    I just tried it here, 18F25K20 running at 64MHz.
    TRISC = %10000000                       '
    TRISB = %00000000                       '
    Datapin var PortB.7    ;
    Clockpin var PortB.6   ;
    CS var PortB.5
    PortB = %00100000       ' Setup initial pin states.
    Pause 100
    Start:
      CS = 0
      shiftout Datapin, Clockpin, 1, [%10001000]
      CS = 1
      Pause 100
    Goto Start
    As you can see I'm using MODE 1 (clock idles low, MSB first). I captured the result with my logic analyzer:
    As you can see the datapin is indeed true before the rising edge of the clock, throwing some markers on it tells me that the datapin goes true 250nS before the rising edge of the clock signal but that will be different depending on the oscillator speed.
    Do you have anything else on your data output pin (like a LED or, worse, something capacitive) that can possible load output driver making its risetime increase?
    Feb 2012
    Henrik,
    Thanks for helping me with this. I don't know why my setup is showing the data slightly after the rising edge. I am using a similar micro (18f26k22), only I am using the internal Osc at 16MHz. Your output shows that the data should be good on both the rising and falling edge.
    Each SPI line I am using has a 3.9k resistor between the PIC's I/O and the device, but nothing else. (I have a resistor on the Clock, CS, DO, and DI signals)
    I like your logic output. I am using a pickit2 to load the hex file and program the Pic. I am wondering if I am missing out on some decent tools by not using MPLab.
    Hi Jim,
    At 16Mhz you should have even more delay between the datapin going "true" and the rising edge of the clock - have you verified that it's actually running at 16MHz? (Can't see how that would actually make the data go true after the clock but anyway...)
    When capturing the output with your scope, are you measuring on the PIC pins?
    Are the PIC and the other chip both running off the same supply or are you doing some kind of level conversion with the 3.9k resistors?
    Try disconnecting one side of the resistor and measure again to verify that the PIC is actually setting the states correctly.
    I don't use MPLAB myself and the only thing I know I'm missing is source level debugging. As for the logic analyzer it's the Saleae LOGIC (8 channel version) - it's absolutely great for the money, worth every cent.
  1. reducing shiftout clock freq and PS2/PC interfacing ....
    By wireless magic in forum mel PIC BASIC Pro
    Last Post: - 26th February 2008, 20:15
  2. After Shiftout where is the clock signal???
    By makson in forum mel PIC BASIC Pro
    Last Post: - 31st August 2007, 18:27
  3. SHIFTOUT Clock rate
    By Brock in forum mel PIC BASIC Pro
    Last Post: - 8th July 2006, 23:42
  4. Best way to find a rising edge?
    By jcsquire in forum mel PIC BASIC Pro
    Last Post: - 31st May 2006, 15:11
  5. Replies: 2
    Last Post: - 5th June 2005, 19:55
