Problem with PortB Tris
Results 1 to 10 of 10
    Apr 2011
    Kent, UK
    Default Problem with PortB Tris
    I have a funny problem with driving PortB.6 as a digital io. (18LF 44K22 PBP 2.6c)
    The first 3 flashes work fine using HIGH PORTB.6, but doing the same again using PORTB.6 = 1 doesn't work though the other pins work as expected.
    I have looked through the data sheet and can find no clues. Can anyone point me in the right direction?
    Tim.
    TEMPB		VAR BYTE					'Temporary Byte sized register
    STARTUP:	        ANSELA = 0					'ALL DIGITAL INPUTS
    			ANSELB = 0
    			ANSELC = 0
    			ANSELD = 0
    			ANSELE = 0
    			TRISA = %11011100			'PortA ins & outs
    			TRISB = %00010000			'PortB ins & outs
    			TRISC = %11011110			'PortC ins & outs
    			TRISD = %10000000			'PortD ins & outs
    			TRISE = %00000100			'PortE ins & outs
    			FOR TEMPB = 1 TO 3						'ALL LED'S FLASH STARTUP SIGNAL
    				PORTB.5 = 1
    				HIGH PORTB.6
    				PORTB.7 = 1
    				PAUSE 200
    				PORTB.5 = 0
    				LOW PORTB.6
    				PORTB.7 = 0
    				PAUSE 300
    			NEXT TEMPB
    				PORTB.5 = 1
    				PORTB.6 = 1
    				PORTB.7 = 1
    				PAUSE 200
    				PORTB.5 = 0
    				PORTB.6 = 0
    				PORTB.7 = 0
    				PAUSE 300
    			NEXT TEMPB
    			GOTO MAIN
    May 2006
    Del Rio, TX, USA
    Default Re: Problem with PortB Tris
    I don't have an answer, just a quick suggestion to trouble shoot. Try putting another TRISB = %00010000 between the FOR...NEXT loops and see what that does. Also, if you use PORTB.6 = 1...PORTB.6 = 0 in the first loop instead of HIGH...LOW, does it work properly?
    Apr 2011
    Kent, UK
    Adding an extra TRISb.6 = 0 between loops made no difference.
    Changing to LATb.6 = 1 works. Thanks for that. Problem solved.
    Interestingly, further down the code is ON INTERRUPT. If I put the PORTb.6 = 1 loop after the ON INTERRUPT statement it works fine???
    I usually use DT's instant int's (fantastic by the way) but this programme uses I2CREAD and I2cWRITE and so had to go back to ON INTERRUPT to prevent the timing being upset by the ISR.
    All I can say is sometimes we get lucky....
    Like in the beginning of your code
    the data latch was clear. That evidently is happening in your ISR.
    May 2006
    Del Rio, TX, USA
    Glad to see it get fixed!
    Quote Originally Posted by timmers View Post
    You might look into using the hardware I2C. You'd have to write some routines to deal with the data, but it will work well once you do.
    Apr 2011
    Kent, UK
    I agree, hardware I2c is the way to go, but thats alot of effort to make it work. The I2cREAD/WRITE work so well outside an interrupt environment.
    May 2006
    Del Rio, TX, USA
    FWIW, here is an include file I put together (a long time ago) to use the Hardware I2C. It may be useful. It uses arrays as buffers to input and output data.
    HI2C_Subs.bas
    It uses arrays as buffers to input and output data. This real time clock include shows how the H12C is used.
    RTC_Subs.bas
    It's been a while since I've used/looked at it, so there is likely quite a bit that could be improved. But, it worked when I used it. I just can't remember all the details of how.
    Apr 2011
    Kent, UK
    Interesting.
    I will try and pick it apart to see how you ran the module, then try and write my own interpretation so I will then understand how it works.
    Cheers,
    Tim.
    May 2006
    Del Rio, TX, USA
    Here are some things I’d look into changing or using now that I look at it again. First, some easier changes:
    - Not so much a change to the routines, but in how they are called. Use the new (ish) ARRAYWRITE command to load the array buffer, and the ARRAYREAD command to read the array buffer. The nice thing about these is that they use the modifiers for formatting strings, like DEC and HEX
    - The routines use 2 array buffers, one for input (I2CRDBuff) and one for output (I2CWRBuff). I think this could be reduced to only one array buffer pretty easily. It would save on RAM (may not be an issue) and likely simplify things a little.
    Much bigger changes which would require a more significant amount work:
    - Implement interrupts (via DT’s Instant Interrupts) to do the sending/receive of data ‘behind the scenes’. Basically, load up the array, point the I2C to the correct address, and pull the trigger. The rest will take care of itself while your main program goes on its way doing something else.
    - Implement an assembly macro to execute the routines (similar to how the LCD bar graph macro works). This would simplify coding in the main program module.
    Who knows, maybe I may look into it as well if time permits. Gives me something to stay out of trouble.
  1. Replies: 6
    Last Post: - 12th March 2011, 13:11
  2. 16f886 interrupt on portB problem
    By antonjan in forum mel PIC BASIC Pro
    Last Post: - 8th October 2008, 20:06
  3. 16F689 PORTB.7 Problem
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 5th April 2008, 06:43
  4. Problem With Bootloader And Portb.3
    By bobonapoletano in forum mel PIC BASIC Pro
    Last Post: - 31st December 2005, 16:10
  5. Problem with peek in portB
    By hawk72501 in forum mel PIC BASIC Pro
    Last Post: - 27th August 2005, 12:01
