define OSC 16
include "HPWM10_L.pbp"
CONFIG FOSC = INTIO67
CONFIG PLLCFG = OFF
CONFIG PRICLKEN = ON
CONFIG FCMEN = OFF
CONFIG IESO = OFF
CONFIG PWRTEN = ON
CONFIG BOREN = OFF
CONFIG BORV = 285
CONFIG WDTEN = OFF
CONFIG WDTPS = 32768
CONFIG CCP2MX = PORTB3
CONFIG PBADEN = OFF
CONFIG CCP3MX = PORTB5
CONFIG HFOFST = ON
CONFIG T3CMX = PORTB5
CONFIG P2BMX = PORTB5
CONFIG MCLRE = INTMCLR
CONFIG STVREN = ON
CONFIG LVP = OFF
CONFIG XINST = OFF
CONFIG CP0 = ON
CONFIG CP1 = ON
CONFIG CP2 = ON
CONFIG CP3 = ON
CONFIG CPB = ON
CONFIG CPD = OFF
CONFIG WRT0 = OFF
CONFIG WRT1 = OFF
CONFIG WRT2 = OFF
CONFIG WRT3 = OFF
CONFIG WRTC = OFF
CONFIG WRTB = OFF
CONFIG WRTD = OFF
CONFIG EBTR0 = OFF
CONFIG EBTR1 = OFF
CONFIG EBTR2 = OFF
CONFIG EBTR3 = OFF
CONFIG EBTRB = OFF
DEFINE LCD_DREG PORTA
DEFINE LCD_DBIT 0
DEFINE LCD_RSREG PORTA
DEFINE LCD_RSBIT 5
DEFINE LCD_EREG PORTA
DEFINE LCD_EBIT 4
DEFINE LCD_BITS 4
DEFINE LCD_LINE 2
DEFINE I2C_SCLOUT 1
OSCCON = %01110000
OSCCON2 = %0000000
OSCTUNE = %10000000
T1CON = %00000111
ANSELA = 0
ANSELB = 0
ANSELC = 0
ADCON0 = 0
pause 200
RTC con %10100010
EPROM CON %10100000
LM75 CON %10010000
Strelica con 126
OUTPUT PORTC.2
OUTPUT PORTB.0
OUTPUT PORTB.5
OUTPUT PORTB.3
symbol BCKLIGHT = PORTC.3
symbol SDA = PORTC.0
symbol SCL = PORTC.1
symbol RELEJ1 = PORTB.7
symbol RELEJ2 = PORTC.4
symbol TASTLEVO = PORTC.5
symbol TASTOK = PORTC.6
symbol TASTDESNO = PORTC.7
symbol TASTGORE = PORTA.7
symbol TASTDOLE = PORTE.3
symbol TASTODRZAVANJE = PORTA.6
low bcklight
low relej1
low relej2
input tastlevo
input tastdesno
input tastdole
input tastgore
input tastodrzavanje
input tastok
'PROMENJIVE
X VAR BYTE
Seconds var byte
Minutes var byte
Hours var byte
Days var byte
Years var byte
Month var byte
Temp var byte
Temperatura var byte
Potenciometar VAR word
Frequency VAR WORD
DutyCycleL VAR WORD
LMcnt var byte
Frequency = 30000
low relej1
low relej2
gosub UpisiVreme
DutyCycleL=100
@ HPWM10 4, _DutyCycleL, _Frequency
@ HPWM10 3, _DutyCycleL, _Frequency
@ HPWM10 2, _DutyCycleL, _Frequency
@ HPWM10 1, _DutyCycleL, _Frequency
BCKLIGHT = 1
'relej1 = 1
'relej2 = 1
'Lcdout $fe, 1,hex2 hours,":",hex2 minutes,":",hex2 seconds, " ", dec3 Temperatura
lcdout $fe,$c0, dec TASTLEVO,dec TASTOK,dec TASTDESNO, dec TASTGORE ,dec TASTDOLE, dec TASTODRZAVANJE
gosub UzmiVreme
gosub OcitajTemperaturu
Goto Main
UpisiVreme:
Seconds = $00
Minutes = $15
Hours = $23
Days = $01
Years = $01
Month = $01
I2cwrite sda,scl,rtc,$02,[seconds,minutes,hours,days,$02,month,years]
PAUSE 10
UzmiVreme:
i2cread sda,scl,rtc,$02,[seconds,minutes,hours,days,temp,month,years]
minutes.7=0:hours.7=0:hours.6=0:days.7=0:days.6=0:month.7=0:month.6=0:month.5=0
OcitajTemperaturu:
LMcnt = LMcnt + 1
if LMcnt = 4 then
I2CREAD sda, scl, lm75, 0,[Temperatura]
lmcnt = 0
