PIC18F26K80 A/D Converter
+ Reply to Thread
Results 1 to 3 of 3
    Jun 2011
    Default PIC18F26K80 A/D Converter
    I think this would be the right place to ask this. I have a 18F26K80 that I'm trying to turn off the A/D on the A ports.
    I tried the following;
    ADCON0=$00 'switch the Analogue A/D pins to Digital I/O mode.
    ADCON1=7 'switch the Analogue A/D pins to Digital I/O mode.
    ADCON2=$00 .
    TRISA = $FF ' set port a to all inputs ' 28
    TRISB = $00 'set port b to all outputs ' 29
    TRISC = $FF 'set port c to all inputs ' 30
    However, the inputs on the A ports are still ignored. What am I doing wrong??
    Default Re: PIC18F26K80 A/D Converter
    I've already tried to help you with this in the other thread where you posted the exact same question yesterday. Why not follow up on that?
    Jun 2011
    Thank you Henrik. When I re-posted here I thought no one had responded to the other thread. I will try your suggestion.
  1. USB to COM converter
    By iugmoh in forum USB
    Last Post: - 20th April 2008, 15:19
  2. 10-Bit D to A Converter
    By Atom058 in forum General
    Last Post: - 14th October 2006, 03:14
  3. A/D converter
    By rocky79 in forum mel PIC BASIC Pro
    Last Post: - 1st October 2005, 07:40
  4. hex to bin converter
    By darkman in forum mel PIC BASIC Pro
    Last Post: - 27th April 2005, 15:41
  5. help D/A converter
    By matelda in forum mel PIC BASIC Pro
    Last Post: - 8th September 2004, 18:25
